2.0T/FSI Coil Pack Conversion
EDIT 01-05-16
Current coil pack are Red Tops -> 06E905115E (use these but keeping old info below in this post anyway)
If you don't prefer the boot cut method, there are OEM spacers that can be slightly modified to work as well. OEM Spacers 077905390
As more than a few of you guys have already made the switch to the 2.0 coils and had positive results, it was only a matter of time before I did so myself. Jace's comments concerning improvements in off-boost power, overall smoothness and better MPG was the final convincing I needed to do so.
For some time now I've been running NGK BKR7EIX's (#2667) with no complains and positive results. So those were going to stay for the time being. Picked up a new set the old one's were due for a swap anyway.
I opted to remove the rubber sleeves from a set of old CPs so I dove into my emergency trunk bag for my extras. Turns out, the pantry was overstocked!
I had a full set of R's and two brand new D's that I bought last year when CP's dropped to ~$10. If you didn't own a B5 or never had the old rev CP's this might seem a tad excessive. Funny now, but back then pretty standard.
First, here's what the previous gen R's (upper) look like against the D's (lower). I never compared them closely and it's pretty easy to see the changes. I was more concerned about the rubber sleeves as they'd become my adapters and was ready to cut up my D's (which BTW are still looking/running fine after 2+ yrs). But as you can see, the sleeves on the R's are a bit shorter but lot thicker, especially at the base... perfect for this application.
Top down: R - D - 06H 905 115 A
Height / boot differences between the R D and FSI
Took some measurements,
and then started cutting. The rubber is pretty easy to get through, just use a sharp, exact instrument like this. Razor blade should be fine too.
Sleeves from the R's on the FSI's. I also added some dielectric grease to the base of the coil packs to aid in connection to the spark plugs.
Installing here. As you can see, the extra rubber sleeve provides both a perfect base outside of the chamber for the new CP and also completely fills the diameter of the opening.
Again, added dielectric grease to each of the coil pack plugs too.
Each one moved into place and made the same *click* sound when connecting with the spark plugs, no play or movement thus far.
Initially while driving around, I didn't feel much of a difference. Acceleration was smoother and idle was dead silent + dropped ~200rpm but not much more. Figured, eh maybe this one will be more about better MPGs.
But after a TBA + code clear (to reset fuel trims), and some driving around town things started to change a bit. There was a bit more pickup than before, albeit minor.
Yesterday I got on the freeway for the 1st time and was very surprised to feel a noticeable increase in off-boost power and what I'll call cleaner acceleration. It's like the mechanism of the engine has been refined and polished.
I was really stoked on it and can only imagine how these characteristics might be even more significant for those with more powerful setups. Bottom line, this mod is a win.
Since these CP's are here to stay, I'll now be picking up a set of
Integrated Engineering's beautiful red adapters as well, especially when I finally get closer to going big turbo.
EDIT 01-05-16
As for the different coil packs out there, there are no differences - just numbers and colors. The most current at the time of this post = 06H905115A
RED MKV FSI Coil Packs - 06E 905 115
BLACK MKV FSI Coil Packs - 07K 905 715 F
BLACK MKV TSI Coil Packs - 06F 905 115 F (now supersedes to 07K)
BLACK MKVI TSI Coil Packs - 06H 905 115 A (*115B = stop sell in favor of A)
As for spark plug gap...
NGK (2667) BKR7EIX Iridium -> .032" gap from factory
NGK (3764) BKR6EIX-11 Iridium -> .044" gap from factory
I'm now considering trying out the 11's to utilize the increased gap. Wanted to see how the 7's felt first before making the jump.
Some might not agree with me on this one, but as I understand it the gap on Iridium / Platinum plugs is more finite in order for the plug to work properly. Hence, the gap from the factory is set far more accurately than coppers. Additionally, b/c the material on these plugs is more sensitive, there's a far greater chance in harming the plug tip when attempting to re-gap. But for most, that doesn't really seem necessary as the 11's are .044 out of the box, exactly what we need.
