Results 1 to 40 of 42
    Veteran Member Four Rings EuroA4's Avatar
    Feb 12 2004
    PA-NJ
    Quote Originally Posted by VMRWheels View Post
    You're spot on. The B8's use a TPMS that is built into the car and not installed onto the wheel. The OP's best bet is to swap his current TPMS over to the new wheels.
    Or just get a VAG-Com to turn off TPMS! They are useless unless they actually give you the pressure in the MFD like Porsche.
    Veteran Member Four Rings GA42.0T's Avatar
    Jul 26 2010
    Atlanta, GA
    Quote Originally Posted by EuroA4 View Post
    What's MFD? And are you saying the Audi B7 TPMS doesn't do this and so I should bother installing the sensors on new wheels?
    Jamie | 2008 2.0T FWD 6MT Brilliant Black S-like
    S-line Suspension+B5 Spring Perchs | RAI HFC | ER SMIC | 034 TIP | B8 18X8 Sport Wheels | Spacers: 10/12.5mm | RS4 Sway | "D" DV | De-badge | S4 Blackout Grill | Euro RNS-E | OEM Ecode Xenons | Clear Side Markers | Cupra Lip | S4 Mirror Caps | ECS Slotted/Drilled Front Rotors | Ceramic Pads | Poser S-line Door Badges | Podi | 034 Catch Can. Go: Still Stage Zero
    Established Member Two Rings jma57's Avatar
    Jun 20 2010
    Pa
    Quote Originally Posted by GA42.0T View Post
    If I'm not mistaken Audi's TPMS lights up at a preset lower air pressure, Porsche's system shows actual pressure on the Nav display, I think...
    Feb 12 2004
    PA-NJ
    B7s display icon only in the driver information display (or MFD: multi-function display). No specifics at all.
    new Audi's with MMI navs display like this...pretty awesome!!
