Results 1 to 40 of 42
    Established Member Two Rings jma57's Avatar
    Jun 20 2010
    Pa
    Question for the wheel experts (updated pics)
    I'll be looking at basically a new set of wheels and tires(well, used 150 miles) that came off a 2010 A4 Avant S-line, 18x8 et47, tires are 245/40/zr18.
    My car is an 07 B7 2.0t quattro with 17 in. stock wheels, I think that set will fit, may have to get some centering rings from 66.1 ?? to 57.1.
    Can anyone verify this? I'm sure some of you have done it.
    Thank you very much!
    Veteran Member Four Rings fatbrembos's Avatar
    Sep 30 2009
    b7 s4 avant/ c6 avant
    Orlando
    Quote Originally Posted by jma57 View Post
    yep you will need hub rings due to the b8 has a bigger hub size
    they should fit fine, but will tuck a good about because the offset is pretty high, but thats nothing some spacers cant fix
    For Sale:
    HRE 943R Wheels
    Full B8.5 S4 Interior (black leather/black alacantara)
    Current Cars:
    B7 RS4 Widebody Avant
    D3 A8L - for sale
    MK5 GLI - for sale
    MK4 GLI
    Veteran Member Four Rings vbrad26's Avatar
    Oct 17 2009
    MK7 VW GTI
    St. Pete, FL
    +47?
    that will clear everything?
    Veteran Member Four Rings GA42.0T's Avatar
    Jul 26 2010
    Atlanta, GA
    I'm going to do the same thing. I guess those B8 guys don't like the 18" sport wheels. I got the hub rings from ECS for like $18. Haven't installed them yet - waiting on Koni/Eibach kit to arrive!
    I'm hoping they won't tuck too much, offset is only 2mm from stock, right?
    Jamie | 2008 2.0T FWD 6MT Brilliant Black S-like
    S-line Suspension+B5 Spring Perchs | RAI HFC | ER SMIC | 034 TIP | B8 18X8 Sport Wheels | Spacers: 10/12.5mm | RS4 Sway | "D" DV | De-badge | S4 Blackout Grill | Euro RNS-E | OEM Ecode Xenons | Clear Side Markers | Cupra Lip | S4 Mirror Caps | ECS Slotted/Drilled Front Rotors | Ceramic Pads | Poser S-line Door Badges | Podi | 034 Catch Can. Go: Still Stage Zero
    Jun 14 2005
    Anaheim, CA
    You'll want the hub centric rings to be 66.6 to 57.1
    Brandon @ VMR Wheels
    Jun 20 2010
    Pa
    Quote Originally Posted by vbrad26 View Post
    +47?
    That's what I'm worried about, maybe the seller posted the wrong offset. Maybe he meant 37 which would be perfect. Most 18 in wheels I've come across for the 2010 Avant are listed with offsets from 35 to 40. I'm just not sure how to find out exactly what the offset is for those wheels, they are Audi OEM, the seller upgraded to 19 in just after he bought the car.
    Jun 20 2010
    Pa
    Quote Originally Posted by VMRWheels View Post
    Thank you Jacob!
    Jun 14 2005
    Anaheim, CA
    An et37 would fit perfectly..just not as flush as you can get. The et47 should still clear without spacers.
    Oct 17 2009
    MK7 VW GTI
    St. Pete, FL
    i'd double check the offset...you are correct in thinking that it seems very high...
    and a set of spacers would not hurt anyway in this case...just make sure you get hubcentric spacers so you can still slip your hub rings over the spacer...
    Jun 14 2005
    Anaheim, CA
    Just to give you an idea, we've had customers fit our 9.5 et33 wheels without spacers. The 8 et47 will have about 5mm more clearance on the inside.
    Jun 20 2010
    Pa
    Thank you everyone,
    I'll be checking them out this Sunday, I'll post results.
    Jul 26 2010
    Atlanta, GA
    Also, anohter thing to consider is TPMS. I was told the B8's don't use TPMS, so the wheels won't have the sensors in them. If you car has TPMS (not sure if all B7's have it, but mine does), then you'll have to figure out what to do. Could try to VAG the tire pressure system off or pull the sensors from your stok 17s and install on the 18s. When you plan to install your new wheels?
    Jun 14 2005
    Anaheim, CA
    Quote Originally Posted by GA42.0T View Post
    You're spot on. The B8's use a TPMS that is built into the car and not installed onto the wheel. The OP's best bet is to swap his current TPMS over to the new wheels.
    Jun 20 2010
    Pa
    Audizine to the rescue! Totally forgot about TPMS, wasn't sure and called AUDI. My car has no TPMS, it monitors low pressure via the ABS system, one less headache to worry about.
    Jacob is pretty sure they'll fit. I know I need centering rings, if they tuck in too much I'll use spacers. I already have 12.5mm in the rear with the stockers, we''ll see on Sunday.
    Again, thanks everyone.
    Senior Member Two Rings rowyourown's Avatar
    Jan 13 2010
    New York
    try to get it to around +30 to +32 with spacers, then it'll be nice and flush with the fender. sexahh
    Eibach springs, Bilstein sport shocks, GIAC, 034 HFC, RS4 rear sway, V710s, Hankook Ventus V12 235/40/18
    Jul 26 2010
    Atlanta, GA
    Quote Originally Posted by rowyourown View Post
    So how's the math work on that? If the wheels are 47mm and you think 32 would be nice and flush with fender, does that mean 15mm spacers are needed?
    And how's the center bore work out with wheels being 66.6 and hub being 57.1? Do spacers come with different center bore, and if so, do you match the wheel at 66.6, or the hub at 57.1? Just asking cause I've got the same wheels and plan to put them on in a few weeks.
    Thanks.
    Oct 17 2009
    MK7 VW GTI
    St. Pete, FL
    you are correct with the offset math...the lower the number the more poke...so subtract the width of the spacer from the original offset
    and if you are going to run spacers you need to get hubcentric spacers...so buy 57.1 spacers then buy 66.6 hubcentric rings to slip on the spacer
    Jul 26 2010
    Atlanta, GA
    Sweet, thanks! I've got the hubcentric rings, so all set there. If I want little more conservative look, but don't want the wheels burried in the fender, I'll maybe shoot for +34 or +36. So 10mm spacer on the front and 12.5mm on the back would net a +37 poke on the front and +34.5 in the back.
    Veteran Member Four Rings EuroA4's Avatar
    Feb 12 2004
    PA-NJ
    Or just get a VAG-Com to turn off TPMS! They are useless unless they actually give you the pressure in the MFD like Porsche.
    Jul 26 2010
    Atlanta, GA
    Quote Originally Posted by EuroA4 View Post
    What's MFD? And are you saying the Audi B7 TPMS doesn't do this and so I should bother installing the sensors on new wheels?
    Jun 20 2010
    Pa
    If I'm not mistaken Audi's TPMS lights up at a preset lower air pressure, Porsche's system shows actual pressure on the Nav display, I think...
    Jul 26 2010
    Atlanta, GA
    Thank you everyone,
    Dying to see some pics.
    Feb 12 2004
    PA-NJ
    B7s display icon only in the driver information display (or MFD: multi-function display). No specifics at all.
    new Audi's with MMI navs display like this...pretty awesome!!
    Jun 20 2010
    Pa
    Me too, of my car. Unfortunately life got in the way, hope next weekend works.
    Jul 26 2010
    Atlanta, GA
    Ha! OK. Let's see who can be the first to post pics of 18" B8 sport wheels on a B7.
    Senior Member Two Rings unh112's Avatar
    Jan 18 2008
    06 A4 2.0TQ Manual
    Boston, MA
    I had 8mm all around but I think I better go with 12
    06 B7 Quattro Silver MT
    RS4 Sway Bar | RS4 pedals | S4 Door blades | Votex front spoiler | Votex rear spoiler | revo stage 1 | Forge DV | clear side markers | VAG-COM mod | Eibach pro kit | Koni FSD | 40% Llumar axcess tint | LED license plate light | 6000K HID | 18's B8 wheels 245/40/18 tires with 8/12mm H&R spacers front and back
    Jun 20 2010
    Pa
    Well, finally got around to do it. Looks decent in my opinion, of course you're welcome to flame and comment away.
    GA42.0T did the same thing down South, now there's one up north. I used centering rings, 10mm spacers up front and 12.5mm at the rear. They would have fit fine without them but the car looks better with them.
    Now if I can just make the pics show up........can't
    http://picasaweb.google.com/lh/photo...eat=directlink
    Oct 17 2009
    MK7 VW GTI
    St. Pete, FL
    they look good...very OEM lol
    Veteran Member Four Rings ryanworth's Avatar
    Nov 16 2009
    Los Angeles, CA
    Yeah I like them too! I bet they'd like really good gunmetal.
    Ford Focus - 2.0 Gray Four Banger Bad Ass Hatchback - Current
    B7 S4 - 6MT Dolphin Gray Avant - Old
    B7 A4 - 2.0T 6MT Quattro Brilliant Black Titanium S-Line - Old
    -Ryan
    F.T.W.L.T.B.D.W.I.C.T.W
    Jul 26 2010
    Atlanta, GA
    Huzzah! Looks great man. Friggin fantastic in fact. Super jealous. Best looking wheels I've seen on a B7.
    For real, congrats jma57. Looking good. 66.56 **> 57.1 rings working wel?. No wobble? I'm out of town this weekend but plan to put on correct rings and get alignment Monday. Had to take the wife's Camry :(
    Jun 20 2010
    Pa
    Quote Originally Posted by ryanworth View Post
    Mind reader!
    Thank you Sir, check your PMs and thank you vbrad26 for posting the pics. I'm a dumb ass obviously, tried unsuccessfully a few times, no go.
    Veteran Member Four Rings eskimopunk's Avatar
    Mar 26 2008
    63 Ford Falcon Futura Convertible
    Las Vegas
    Nice man, looks great. Love me some oem. That paint is looking pretty damn fresh.
    flickr
    "ALL I REMEMBER IS ARGURFIN WITH DRCURITY AND THEM KICKING me out of neptunes i ve had like 6 LIT's biches is crazy my backj fucking hurts" - El_Chapusca
    SBSC Designer
    For awesomeness. Thanks Pat.
    Veteran Member Four Rings fordyoz's Avatar
    Apr 20 2011
    Philadelphia
    would these be a good alternative to spacers + rings?
    http://www.ecstuning.com/Audi-B7_A4-...All/ES1899553/
    Oct 17 2009
    MK7 VW GTI
    St. Pete, FL
    yeah because some of the time spacers+rings dont work out correctly...
    Apr 20 2011
    Philadelphia
    yea - i am new to spacers and rings. im trying to see how a ring would even work with a spacer on the wheel?
    I am picking up a set of the B8 S4 18" Y spoke wheels with 245/40 et47. Im trying to figure out what size spacers/rings to get.
    Oct 17 2009
    MK7 VW GTI
    St. Pete, FL
    those 10s would be sufficient if you dont want a very aggressive look
    10-15mm would give you a pretty flush look...nothing crazy...just pretty much right to the fender...maybe just recessed in there a little
    Apr 20 2011
    Philadelphia
    thanks brad.
    could I do regular hub rings + regular spacers? that would be cheaper
    http://www.ecstuning.com/Audi-B7_A4-...ngs/ES2185353/
    http://www.ecstuning.com/Audi-B7_A4-...pacers/ES1990/
    would that suffice?
    thanks for your help
    Oct 17 2009
    MK7 VW GTI
    St. Pete, FL
    yeah that should work
    i currently have plastic 66.6-57.1 rings fitted to my 11mm spacers
    its a really tight fit but it works for me
    you will also need longer lugs
    Apr 20 2011
    Philadelphia
    ah ok. If you get a minute could you point me in the right direction for proper lugs I would need from ECS with that set up?
    Oct 17 2009
    MK7 VW GTI
    St. Pete, FL
    well the rule with that is take stock lug length then just add the width of the spacer to that
    i think OEM is like 27mm...so add 10mm spacer and you get 37mm obviously
    so get 40mm bolts?
    http://www.ecstuning.com/Audi-B7_A4-...ECS/ES2130070/
    the next closest size is 35mm and you would rather have more threads than less
    i dont think the 40mm bolts would be to long
    maybe someone else could chime in or you can just give ECS a call to double check
