Results 1 to 2 of 2
    Jun 06 2005
    Montana
    A bit of an odd request, anybody have an air compressor I could borrow?
    I need something for painting, which requires more than the compressor in my basement. The specs state I need 8 CFM at 50-60 psi. So, I guess ideally this would be a compressor that is rated around 6-7 CFM at 90-100. I don't suppose anybody has one of these lying around or know anybody that does? I wouldn't mind paying a reasonable expense to let me use it, or buy you some beer, make some cookies, or whatever. Let me know, thanks!
    Veteran Member Three Rings audikidS4's Avatar
    Sep 03 2008
    2001.5 S4 Avant 6spd - Sil/Blk, 1995 S6 Avant - Blk/Ercu
    Wareham, MA 02571
    Try Taylor Rental Center...rent one...
    The original audikid! Coined as ebay username spring 1999.
    **MTM ECU, Piggies, ASP Tru-Duel, Stratmo ss kit, Stern sm, AWE DTS, Voltgland GT2, Neuspeed 19mm RSB, full Samco kit, drilled and slotted rotors, PODI/S-W boost gauge, Sportec pedals, 30% Huper optik, CCMod, stubby antenna, VMR 708s 18X8.5 32mm**
