car is b5 s4 2.7 just purchased had cel and an bad sensor code no activity.
looked through records and found it had been replaced in last few months. so i was not optmistic but replaced it with a new sensor still have little to no activity
in replacing it i looked into the spark plugs and air filter general stuff...
also :
it hasent been tuned up recently and i found a bank 1 cat below effiency code
so i have a wild guess and allready have pipes so i may be able to fix..
i wonder if the pre cat is bad and partialy clogged causing a pool of gasses to gather its stuck at .434 volts and will move about .003 + or - from this number other side is responsive
so if its in a chamber of slow moving gasses it would have a damping effect on readings like the no fowler mod traps a small amount around the tip and it exchanges slowly so the readings are lazy to change possible???
any other ideas.
