Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 121 to 160 of 278
  1. #121
    Veteran Member Three Rings Calimus's Avatar
    Oct 26 2010
    88' Scirocco, 89' Cabriolet, 16' A3 E-Tron, 05' FJR1300
    NW Georgia
    Good luck. With the plugs out, turning the motor over from the crank with a 1/2" ratchet should take very little effort. Anything that feels like you have to put some elbowe grease into it should pretty much be a sign that things are not well and to stop. Best of luck to ya.
    William
    12' 3.0T A6 Prestige - The white whale
    02' 2.7t A6 - Gone but not forgotten
  2. #122
    Senior Member Three Rings PluschakovP's Avatar
    Jul 05 2010
    NW Washington
    Quote Originally Posted by Calimus View Post
    yep, i rotated the crank the first time i put the timing belt on and it rotated easily. so this time, i just gotta do the same exact thing right? put the new belt on, and rotate it by hand. if it's freely rotating then it's safe to try and crank it with the starter right?
  3. #123
    Oct 26 2010
    NW Georgia
    Safe would be used very loosely in this case, but aside from just diving in to a head pull, yea, it's about as close as you get. Remember to keep the spark plugs out, even when/if you make it to trying to turn the car over with the starter. Also remember to pull the fuse for the fuel pump less you get 6 fuel sprinklers which will make a hell of a mess.
    If by some chance you don't feel any resistance and you give it a try with the starter, don't do it a lot until you have the compression tester. If there is some minor damage, you want to try and limit it as much as possible. So try and keep it to doing the compression test. The engine will spin over at a higher rate with the plugs out as it won't be building compression so just a short 2-3 second turn of the key will spin the motor over several revolutions. Just do it enough to to get a reading per cyl (again, a count to 5 once you hit the key should be enough to get an accurate reading on the tester). Write down the readings so you can keep track and compare. Post up the results here and we'll see what you have.
    Again, check the entire path for the timing belt as well. Make sure nothing is touching it that shouldn't be and make sure all tensioner/idler pulley's are turning smoothly. If you managed to dodge a bullet the first time, I don't think you want to chance it a second time. I'm not sure there are enough rabbit's feet out there to pull it off. :)
    William
  4. #124
    Jul 05 2010
    NW Washington
    She's alive again.
    Put my new Timing Belt on. Hand cranked it couple times. Seemed fine. Started it. See for yourself.
    http://www.youtube.com/watch?v=lOO209W7h_g
    I am happy.
  5. #125
    Jun 30 2008
    Erie, Pennsylvania
    You definitely lucked out big time. Having it fail at idle is about the best scenario you can hope for as it is just about the only time that you can get away without damage. Still a slim chance, though. Also, realizing what happened and not trying to restart the engine with a broken belt *really* helped. You almost surely would have bent valves if you had done that.
    Glad this turned out to be just a learning experience and not an expensive or project-ending disaster.
    Now be super careful from now on, because I think you used up all of your luck for quite a while. ;)
  6. #126
    Oct 26 2010
    NW Georgia
    Yup, big time luck on this, but glad it turned out that way. If you were a cat, you would have just used up 8 lives for sure. Can't wait for the next update to be that you're driving it full time. My hats off to you for taking on such a project in the first place at your age and even more so for not giving up despite the potential damage that could have been done. Now, put the rest of that machine together and get some road time.
    William
  7. #127
    Jul 05 2010
    NW Washington
    thanks guys! yeah im definitely taking all my time now putting it back together. i broke the pvc pipe looking thing that connects to the vacuum check valve so ill need to replace that. also the dumb breather hose cracked and now im either gunna just reconnect it with another piece or just buy a whole new one...
    anyhow, im so happy that i got lucky. lol and yeah i realize that i used up all my luck.
    im surprised that this project went this well, because this is the first time ive ever dealt with a motor :)
  8. #128
    Jan 31 2010
    S-Line A6
    East Haven, CT
    oh thank god it worked out for you
    i started to feel really bad for you and your project, lol
    hope to see her on the road soon doing some snow donuts
  9. #129
    Jul 05 2010
    NW Washington
    I'll be working on the A6 all of this week guys. Hopefully I'll get some major progress on it.
  10. #130
    Oct 17 2010
    NorCal Represent
    Congrats!
  11. #131
    Jul 05 2010
    NW Washington
    Good News and Bad News
    Good:
    The car is running really smoothly :)
    Bad:
    I think I forgot to tighten a bolt on one of the turbos. Antifreeze is slowly trickling down from the turbo. Does anyone have a diagram of what turbo lines carry antifreeze, oil, and air? I need to tighten that sucker up! I haven't looked under. It's prolly pretty obvious, but I haven't got on my hands and knees yet.
    Okay, so besides the leaky turbo line, the last thing I need is gaskets for the axles to tranny, and tranny to drive line gasket. Anyone know what I'm talking about? ... and know where I can get them? The dealer can't find what I'm talking about so I'm on my own to find those gaskets, or at least know the exact name of them, if they have a special name.
    Thanks for all the help guys. This has been one crazy project, I must admit... I think it's because of the fact this is my first motor build though so hopefully it'll go more smoothly when I reseal my A4 2.8L motor.
  12. #132
    Nov 04 2010
    GA
    why did u remove the video I wanted to see it
  13. #133
    Jul 05 2010
    NW Washington
    Quote Originally Posted by Asmir02 View Post
    ill repost tomorrow and put links on first post of this thread. had some problems.
  14. #134
    Active Member Two Rings BigBlack315's Avatar
    Nov 30 2010
    Queens/NY/east
    I applaud you on this rebuild you are dedicated
  15. #135
    Jul 05 2010
    NW Washington
    Quote Originally Posted by BigBlack315 View Post
    thank you :) it's been challenging heh
  16. #136
    Jul 05 2010
    NW Washington
    Need These Gaskets, anyone know where to get them?
    For 2002 A6 2.7T 6 speed MT.
    2 of these, axle to tranny
    And 1 of these, driveline to center diff
  17. #137
    Oct 26 2010
    NW Georgia
    Unless Audi does something different, there are no gaskets for the CV shaft connection to the drive cups. You repack some axle grease into the cup (don't fill up though) and then bolt them back together. Now, there are seals on the inside of those cups that are still connected to the trans. However, unless you removed them (they look like a funky bottle cap), they should still be there and unless you are leaking gear oil out of them, they should be fine.
    As for the drive shaft, I don't know anything about that as of yet. Hopefully someone that's been in there before can speak up.
    William
  18. #138
    Jul 05 2010
    NW Washington
    I think I might've found what I was looking for at JHM.
    http://jhmotorsports.com/shop/catalo...ec08d9d471f593
    They seem a little expensive though...
  19. #139
    Oct 26 2010
    NW Georgia
    I'll be damned. I've never seen gaskets for the drive axles. 30 bones does seem pricey, but if it's needed, might as well do it right.
    William
  20. #140
    Jul 05 2010
    NW Washington
    That's true! I learned my lesson of going the cheap way (hence the timing belt) lol. I'll double check and probably get those ordered soon. Gotta tighten a few bolts then I'll get the gaskets and bring the project to an end.
    I need to schedule a State Patrol Inspection to get my Title and License Plates still! I almost forgot...
  21. #141
    Oct 26 2010
    NW Georgia
    Good deal. I myself have some wrenching to do over the holidays myself. PS rack that was leaking a bit totally let go on Monday. Replacement rack arrived this morning. Gonna freeze my ass off since the garage is currently full of a cabriolet and 4 motorcycles, so I get to work in the driveway and for the first time since 93', we are looking to get snow for Xmas. Good times.
    William
  22. #142
    Jul 05 2010
    NW Washington
    haha oh man. if you had a truck i could borrow i'd clean out the second half of my garage and u can park that sucker in it! but you live way out in Georgia lol. you seriously havent gotten snow in 17 years?? im so sorry :( i couldnt live without snow.
    well im off to tighten that loose line on the turbo and see what else needs to be done. I'll try and get some pics.
  23. #143
    Jul 05 2010
    NW Washington
    Merry Christmas everyone!
    I got the chance to climb under and there was no bolt loose. All it was, was my exhaust leaking a little bit of water because it's not fully tightened still. It was like a rusty light brown/green color which made me think it was antifreeze from the turbo, because there was a little bit of antifreeze over the turbo cuz I was clumsy and spilled some while I was pouring it in. Man I scared myself.
    Here's the progress so far guys. Just a couple more things to do and I can lower it down and drive it a little bit. Such a mess in my garage, sheeshh... I'm embarrassed lol.
    -MERRY CHRISTMAS-
    Missing Fog Light :s it got broken when the previous owner crashed it.
  24. #144
    Oct 26 2010
    NW Georgia
    Awesome progress! Trust me, once you really get a chance to drive it for a few days, you will love it.
    An yea, I live in the northern part of Ga and we have had snow over the years, but we generally get it in late Jan to Feb. So white Christmas's are very rare. I really do need to unjunk my garage though. I've gotten slack over the last 3-4 years and it's time I got back to serious business where that's concerned. Besides, with as long as it takes the A6 to warm up in the winter, I'd rather it have a head start from being in the garage.
    William
  25. #145
    Jul 05 2010
    NW Washington
    lol yeah i know what you mean.. expect none of the junk in the garage is mine. at least i was able to get the job done so i'm thankful :)
    can't wait to get the gaskets ordered and get her on the road...
    What's a good break in period for the Rod/Main Bearings? 1,000 miles?
  26. #146
    Oct 26 2010
    NW Georgia
    The bearings should be fine after 200-400. Those are generally a work or don't work type of item from my experience. But give them a bit before you flog the car much at all.
    William
  27. #147
    Jul 05 2010
    NW Washington
    Ooh I hope it's a work type situation for me lol. I would really hate taking this motor apart again. I'm anxious to get into my A4 2.8L already lol.
  28. #148
    Jul 05 2010
    NW Washington
    Found the Axle gaskets. They're Technically called, CV Joint Gaskets, or CV Shaft Flange Gaskets. Weird...
    http://www.usautoparts.net/catalog/i...v+joint+gasket
    Anyways, I've ordered from US Auto Parts before, and they're fabulous. $25.40 for both gaskets+shipping. Not bad at all.
  29. #149
    Oct 26 2010
    NW Georgia
    Good deal. I'll add them to my parts source list. An am I getting this right that you've picked up two Audi's with various issues? If so, props to you for taking on that much challenge. If you're smart, you will stop at two though. I'm a glutton for punishment with 5 VW's, 1 Audi and 2 Yamaha's. It's like a never ending cycle of repairs. However, some of that work is fun and most of is is rewarding.
    William
  30. #150
    Jul 05 2010
    NW Washington
    well my daily driver is the a4. the second gear went out on me and the motor is a little leaky so after the a6, im going to reseal a4 and i'll probably be done with working on Audis. i got the a6 just to have another car but it broke down. so then this thread happened because of it :)
  31. #151
    Oct 26 2010
    NW Georgia
    Ahh, got ya. Well, with 2 audi's, you'll always ride in style but no doubt, they require more maint then your average bear. However, with they will last virtually forever if you keep them taken care of.
    If I had those two, I'd use the A4 for most daily duties and winter beater and use the A6 for some of the summer months and long trips since that's what it's really designed for. I really liked my jetta for taking long trips, but the A6 is a whole 'nother level for sure. Taken a few medium length trips in it and can't wait to do a nice long trip.
    William
  32. #152
    Jul 05 2010
    NW Washington
    yeah the A6 definitely drives more smoothly than the A4.
    So while I wait for the gaskets for the CV Joints, I ordered something for myself just for fun. Figure it'd be fun to install a Boost Gauge into this A6. Found it on eBay. Got a pretty good deal. Looks like it'll be nice, and it matches the color scheme of the interior of the A6. I think I'm going to take out the vent on the far left, by the steering wheel, and custom fit a hole and put it right there. any other ideas where to put it?
  33. #153
    Oct 26 2010
    NW Georgia
    I've been thinking about where to stick a boost gauge as well. I'm not a fan of removing an air vent. Down here in the south, you want all the air-ways you can get. I think when I do the rack replacement this week I'll be looking for a good mounting point.
    William
  34. #154
    Jul 05 2010
    NW Washington
    very true! i dont really want to tinker around with vents but it seems like the cleanest place to put it. if you find a good spot, let me know :)
    what kind of gauge are you going to install?
  35. #155
    Oct 26 2010
    NW Georgia
    I have a New South Indigo in my wife's Turbo S Beetle, so I'm thinking of going with that again. It's a blue light gauge so it's going to stand out a lot against the red in the Audi. I might search around for something different, not sure yet.
    William
  36. #156
    Jul 05 2010
    NW Washington
    that's awesome. do you know what Fuse I should connect the power to if i want it to be on at all times?
    i figure it's best if it's on at all times.
  37. #157
    Oct 26 2010
    NW Georgia
    Not in the A6 I don't, I haven't looked yet. I'll try to have a look at the fuse panel tomorrow.
    William
  38. #158
    Jul 05 2010
    NW Washington
    ok thank you! of all things, i am dumb-founded when it comes to dealing with electrical type things... i dont know very much about that stuff at all.
  39. #159
    Jul 05 2010
    NW Washington
    Here's a video of a B8 S4 with a vent gauge, kind of how I'm thinking of doing mine.
    http://www.youtube.com/watch?v=rf0tllIr7VA
  40. #160
    Jul 05 2010
    NW Washington
    Took the car out on the road for the first time in almost a year!
    The car runs great. Gears switch perfectly. Since the tires have been sitting for nearly a year they are not a perfect circle so the car is jumpy. I hear a little rattle somewhere like something is rubbing but I'm not sure. I will check it out when I get time this Thursday. At least the car runs, tranny works, tires spin. No CEL's. I'm happy.
    Here's what I did today...
    Didn't get a picture of how I connected the axles to the tranny completely.
    But she's all done, for the most part. Just going to lift her up again, make sure everything is Perfect-O, and hope for the best.
