Results 1 to 11 of 11
    Established Member Two Rings Gunnerzwolf's Avatar
    Feb 04 2010
    '01 AR
    New Hope, MN
    Can I manually adjust my headlights?
    I recently had 6k bulbs put in and now my driver side light is higher then my passenger side. My OEM lights were aimed at the same spot, so I'm just curious.
    2001 Audi allroad 2.7T / 6K HID / h-sports
    ...stock for now/wanting a sleeper!
    Veteran Member Three Rings Aye6's Avatar
    Feb 28 2010
    2000 A6 2.7T
    Chicago (DP), IL
    yeah just pop the hood and adjust them using the adjustment screws on top of each headlight. at least I think that it works the same way on the AR as it does on the A6.
    Veteran Member Three Rings ccomengee86's Avatar
    Feb 17 2009
    '03 allroad 2.7T
    Dayton, OH
    Yup, they're located right behind the headlight housing.
    Feb 04 2010
    '01 AR
    New Hope, MN
    Thank you very much. Spotted easily!
    Feb 06 2010
    Albuquerque NM
    Im in need of manual adjustment as well but only see one adjustment screw. I recently installed allroad xenons into my a6 and it seems they are the right height but a bit too spread out. is there a second adjustment screw Im not seeing?
    Feb 17 2009
    '03 allroad 2.7T
    Dayton, OH
    There should be two 'white' adjustment screws and you can only adjust the height of the beam. It's impossible to install the bulbs in wrong way.
    Veteran Member Three Rings ride1157's Avatar
    Jan 18 2010
    71 280sl, 16 g550, 22 RS6, 997.2 911T, 16 E63s AMG
    Palmer Woods Detroit
    Quote Originally Posted by Gunnerzwolf View Post
    Have you fixed it yet? if not and you didn't really bump anything putting the bulbs in, make sure you double check the way you put the bulbs in cause sometimes if you accidentally put one in with the cord stick thingy facing the sky and other facing the ground then that could be the reason why they are off. Double check cause i have done this before.
    Feb 04 2010
    '01 AR
    New Hope, MN
    I tried to fix it. I found out the adjustment screw for the drivers side won't raise or lower the light. The bigger part is lose where the smaller cog won't touch it. I was pressing in the larger part to make contact and found that it still doesn't move the light....
    Veteran Member Four Rings EinSchnellAudi's Avatar
    Oct 24 2009
    2011 X3
    CT / RI
    fixed ^^
    '24 CX-90 PHEV | '68 GTO 4MT | '20 GMC Canyon (No rings to be seen :/ )
    Previous - G01 LCI X3 | F25 X3 | '14 Ibis White B8 A4 6MT | '03 B6 3.0 6MT | '00 C5 4.2
    Feb 04 2010
    '01 AR
    New Hope, MN
    Thanks! ^^
    Still unable to adjust the headlight. The top picture is when I push it in and the bottom is obviously pulled out. I tried the passenger side and it doesn't budge one way or another. Any thoughts?
    Jul 11 2011
    Boston
    Headlight Adjustment Fix
    I had the same problem with my 2001 A6. The cog for adjusting the passenger light went missing - apparently it came loose like in the EinSchnellAudi photos. I had one droopy headlight. It seems as though the cog must fit tight to the toothed shaft (it looks a little like small version of a rasp used in woodworking) that comes out of the headlight housing to bind the headlight housing to the adjustment motor mechanism.
    Here's what I did and it seems to have solved my problem. With the headlights off, I pivoted the housing to the up position. This moves the toothed shaft to it extends out of the headlight housing as far as possible. I slipped a piece of rubber tubing over the shaft - cut just long enough to cover. I then tightened a small hose clamp over the rubber tubing, placing the hose clamp up against the headlight housing. This held the housing in the "upright" position. When I turned my headlights back on, they self-leveled right back into place and have been working fine since (about 5 months).
    Good luck with yours.
    Has anyone found a source for the replacement adjustment cogs on the back of the housings?
