Results 1 to 40 of 43
    Veteran Member Four Rings dparm's Avatar
    Apr 24 2009
    Chicago, IL
    Lightbulb Audi oil reference - all you ever wanted to know
    Intro
    This guide is here to help you understand motor oil. Motor oil plays a key role in lubrication, cooling, fuel economy, and emissions yet is one of the most misunderstood things in a car. I wrote this guide after doing a lot of research and talking to folks on the Bob Is The Oil Guy forums. My experiences talking to various chemists, racers, and other enthusiasts are also included.
    Read this guide if you’re about to change your motor oil or are simply interested about what’s been coursing through your car’s veins all this time. This guide is somewhat techy but nothing that the average car enthusiast can’t follow along with. I’ve tried to pick the best bits of information for this article.
    Be an educated consumer! Know what you are spending your hard-earned money on. Understand the concepts behind motor oil so you can make educated decisions instead of blindly buying into hype.
    Terminology
    PAO: “polyalphaolefin”, a man-made (synthetic) version of mineral oils. This is sometimes known as a group 4 oil, not to be confused with GL-4.
    Ester: for all intensive purposes, they’re fats. These are a synthetic item used in extremely high-end lubricants. Variations include diesters and polyesters. This is sometimes known as a group 5 oil, not to be confused with GL-5. Esters happen to be very stable at high pressure and high temperature, which is important for motor oil.
    Synthetic: in the US, this doesn’t mean much. Throughout the rest of the world, this equates to “man-made”.
    Semi-synthetic: a mineral/conventional/dino oil that contains no more than 30% synthetic oil mixed in. The thinking here was you can get the best-of-both-worlds.
    Mineral/conventional/dino: naturally-occurring oil that is refined and processed into various lubricants, such as engine oil, gear lube, MTF, etc. The “dino” portion comes from the fact that the oils are the byproduct of decomposing dinosaur remains.
    Motor Oil: A Hard Worker
    Motor oil serves many purposes in the motor. Its primary purpose is of course lubrication (and protection) of all the moving parts and surfaces. We don’t need to go into too much detail on this right now because it should be fairly obvious that we want to avoid metal-to-metal contact in the motor. Let’s take a look at the other things that you may not know motor oil does.
    Another role motor oil plays is that of cooling. While it’s true that the cooling system is the primary system in charge of keeping temperatures under control, the motor oil is closely related to this as well. As oil is pumped through the motor, it comes in contact with the hot metal surfaces. Through conduction it absorbs some of that heat and carries it away from the valvetrain, pistons, etc. The enormous oil capacity of these motors is what provides additional cooling above and beyond what the car’s fans, radiators, and coolant already provide. More oil means more mass to absorb the large amounts of heat this engine generates.
    Motor oil is also important to fuel economy. This is an extension of how it lubricates. A motor that is better lubricated will of course require less effort to run and therefore provide better gas mileage. It is true that different oil viscosities and weights will actually impact fuel economy. Changing oil types will not make our lousy 14mpg turn into 24, but it may bump city economy up by 1-2mpg. There are also special additives in oil that improve fuel economy by further reducing friction. More on this later.
    Lastly, motor oil plays a part in emissions. There are additives in gasoline and motor oil designed to reduce certain byproducts of combustion. Some oils are better at this than others. To some this will not matter, but if you are making efforts to be more “green”, you can make smarter choices about the oil you purchases.
    Multi-Grade Oil
    First, let’s take a look at one of the most misunderstood specifications oil carries: the viscosity rating. This is a numerical system was developed by the SAE to designate how viscous it is. Viscosity is a “property of a fluid that resists the force tending to cause the fluid to flow”. The test is a measure of how fast a certain quantity of oil takes to flow through a certain size opening. To apply this to what we’re talking about here, think of it in terms of how quickly it can squeeze between the metal parts of your engine.
    There are two basic grades of oil: single-grade and multi-grade. Single grade has no viscosity modifiers. You’ll see this marked as simply “30 weight” or “straight 30” oil. Our cars cannot use this so we won’t spend too much time talking about it.
    Multi-grade is what we’re interested in. Multi-grade means that the oil performs across a wide-range of temperatures. The viscosity will be very high when cold and very low at operating temperature. It’s a lot like running two separate oils. This is accomplished via proprietary viscosity modifier additives. Multigrade oils are listed with numbers like 0w40, 5w30, 10w30, 20w50, and so on. Let’s break down what these two numbers mean.
    We will use 5w40 for our example. The first component, “5w” describes the oil’s viscosity at cold temperatures. The W is short for “winter” and NOT “weight”. This is a common mistake. The second component, “40”, describes the oil’s viscosity at operating temperature. So 5w40 means that at cold temperature it behaves like a 5-weight, and at operating temperature it performs like a 40-weight. Remember the test we talked about up top? A 5w40 would pass both the 5 AND 40 tests!
    So why does this matter? Well, for vehicles driven year round and across a wide range of temperatures, we want an oil that pumps quickly and protects well when it’s cold, and still lubricates well when it’s very hot. A 0w40 will do much better in cold temperatures than a 5w40, for example. A 20w50 will perform poorly at low temperatures versus a 5w40, but will do very well at high temperatures. A significant amount of engine wear occurs when the motor is very cold so we want maximum protection there.
    Audi specified a 5w40 as factory-fill since it’s a good balance between cold and warm temperature performance. A 5w40 will pump well when temperatures are below zero but won’t suffer when you’re at redline in the middle of a summer day. 5w30 is also acceptable and could yield slightly better gas mileage.
    Something to note is that the given viscosities are going to be a range, as evidenced by the chart below. Not all 5w40s are the same viscosity. Some will be “heavy” and some will be “light”. In fact, one of the OEM oils, Castrol SLX Professional OE, is a “heavy” 5w30 that’s almost a 5w40.
    Basestocks
    Basestocks are the starting point for all motor oil. The basestock is refined and mixed with other chemicals to turn out the final product. Not all motor oil uses the same basestock. Fortunately, there is a classification system that categorizes the various bases and defines where they come from and what they contain. This was created by the API (American Petroleum Institute).
    Group 1 and 2 oils are the low-grade conventional oils. These come from lower quality basestocks and are not synthetic. This is the cheap oil you see for $1-2/qt at the local auto parts stores. We sometimes call these dino or conventional or mineral oils.
    Group 3 oils are where things get hazy. Group 3 is still conventional oil – but it’s marketed as synthetic in the United States. How is this possible? Well, let’s just keep it simple and say that after a lawsuit many years ago, it was decided that synthetic does not refer to the source of the oil. Group 3 oil is still very good and is essentially the highest grade of conventional oil available. It is classified as a synthetic because it undergoes a process known as hydrocracking or hydroisomerizing. Again we’ll keep it simple and just say that the oil undergoes special processes that further improve its properties and performance. Sometimes grade 4 or 5 oils are mixed in to boost it even further. Group 3 oils will run you about $4-6 a quart.
    Group 4 oils are true synthetics. They’re often called “PAOs”, or polyalphaolefins. Now we are talking about the truly excellent oils. Expect to pay $5-9 a quart.
    Group 5 oils are the top-of-the-line lubricants. These often use things like synthetic esters (fats) for even better performance than a PAO oil. Prices here are even higher, usually above $9 a quart.
    Again let’s ask ourselves why this matters. It matters because synthetic oils are not all created equal. As it is, the term synthetic can be a bit of a misnomer in the United States. Generally speaking, better basestocks mean better oil…and an empty wallet.
    The VW 502.00 specification
    Like most other manufacturers, VW/Audi developed some specifications for how motor oils used in their cars should perform. If you’re under warranty, I suggest you stick with oils that explicitly meet these specifications and are approved. There are plenty of choices out there – you do not need to run the dealer-supplied oil. There are even oils out there made just to this spec. Motul, for example, sells something called “Specific 502” that was made just for VW/Audi. They do the same for BMW as well.
    The 502.00 specification lists a 10,000 mile change interval and a 5w30 or 5w40 rating. This means that in general, a 502.00 approved oil is good out to 10,000 miles. Continue reading as we dive into change intervals a bit more.
    You can find current lists of approved oils by doing some quick Google searches. The list changes periodically as old oils are dropped and new oils are released.
    There is a difference between “meets/exceeds VW 502.00” and “VW 502.00 approved”. The oil may technically meet VW’s requirements, but VW may not approve it. The approval means VW has specifically said “yes, we certify this oil for our cars”. There’s tons of oils that may not be certified but could outperform the certification too!
    Change Intervals, aka “Why You Want Synthetic Oil”
    Let me guess – your dad, Jiffy Lube, the oil companies, and everyone you ever knew told you to change your motor oil every 3,000 miles or 3 months, right? Sadly, this is somewhat of a myth. 40 years ago when motor oils were pretty much all conventional group 1/2 10w40, the oil didn’t hold up well after 3,000 miles. Hence the 3,000 mile myth was born.
    Then why is it still around? Basically because Jiffy Lube and the oil companies love taking your money. They’ll continue to explain that oil doesn’t work past 3,000 miles, it gets too dirty, engines are getting very complicated, and so on. This is a lot of exaggeration and conjecture. Note how many cars actually have an interval of 4,500, 5,000, 10,000 or more these days.
    The reason we change oil is two-fold. The first is that the oil breaks down. Repeated heat cycles, burn-off, and contamination actually change the chemistry of the oil. Conventional oil does so very quickly. Synthetics do this at a much slower rate. The other reason we change oil is because it gets dirty. Assorted metals, minerals, gas, coolant, and moisture get in the oil. The oil filter will catch most of this but it is not 100% effective. The rate at which oil gets dirty is largely determined by the engine and not the oil itself.
    Let’s say we have two identical cars. One runs full synthetic oil and the other runs conventional oil, and both cars have the exact same filters. By 3,000 miles, the synthetic and conventional oil will be about the same in terms of dirtiness. If we were to test the viscosity at this point, there would be a significant difference. The synthetic oil would still test as the exact same viscosity as when it was new (or extremely close). The conventional oil will have started to break down and actually change viscosity. It may have lost its multi-grade rating or could have sheared to behave like completely different oil (for example, a 10w30 could become a straight 30 or worse).
    So by that 3,000 mile mark, the conventional oil should probably be changed. The synthetic, although dirty, is still performing like it should. This is why the change intervals for synthetic are often longer.
    Can you use conventional oil? The caveat is that the oil will not stand up to abuse for as long and will need to be replaced much more frequently. For a motor of this complexity and performance, I would stick with synthetic per VW’s recommendation.
    Oil Analysis
    How do we know when to change the oil? Is the manufacturer specification of 10,000 miles or 12 months adequate? Is that too cautious, or not cautious enough? The best way to tell is to get the oil analyzed.
    Companies like Blackstone Labs and Dyson Analysis will run a small quantity of your used motor oil through machines that spit out exact reports of what the oil looks like. You will receive a breakdown of all the contaminants in parts per million, the oil’s viscosity, how much additive is left, etc. From this you can determine if the oil was “used up” or if it could’ve been left in longer. Unfortunately the first change you make might have been too soon. But spending $25 on the analysis could help you save a lot more down the road.
    So is Audi’s 10,000 mile/12 month recommendation a good one? The easy answer is yes, for the typical driver. The car’s large oil capacity means there is a lot of oil to absorb those contaminants and it will take longer to start breaking down. Quality synthetic oil should be able to withstand the 10,000 miles of use.
    For atypical use, such as racing and repeated short trips, the 10,000 mile mark might not be often enough. To be safe, some owners change twice as often (every 5,000 miles or 6 months). Again, the only way to know is to get a sample analyzed.
    An interesting bit of info the analysis will give is something known as the TBN, or total base number. This value is a measure of how much reserve alkalinity the oil had. Through the process of combustion, acids are formed. The TBN of a particular oil tells you how good that oil is at neutralizing the acids. As the oil is used, the TBN slowly drops. It may start with a value around 9 and fall to 3.8 by the time you change it. As the number approaches the range of 1-2, it means the oil is going to be unable to control acid formation and it should be changed. Quality oils will generally have a TBN of 7 or better, with some being as high as 12. If your report shows a TBN of <2, you probably needed to change the oil sooner. If it was above 2, you could probably have left the oil in longer.
    Oil analysis is often misused to measure the motor’s overall health. While it is true that you can get some insight as to what’s happening in the motor, it should not be the sole tool used to diagnose a problem. Your report might show high aluminum content – scary, since that could mean the pistons are wearing excessively. But it could also just be some leftover aluminum from the transport container.
    Relating this back to the 502.00 specification, it means that the oil is sufficiently resilient to withstand 10,000 miles of punishment. A 502.00 oil also has a higher TBN so that it can continue to neutralize acids until 10,000 miles.
    Specifications and what they mean to you
    There are several specs that I’ve selected to catalogue since they’re most indicative of the fluid’s performance. I wouldn’t advocate selecting an oil based on a single number, but rather, a weighted-average method. I’ll explain that later.
    Viscosity index is how well the oil resists a change in viscosity across the temperature range. A higher number is better here. As the oil heats up, we want it to stay as close to its original viscosity as possible. The lower that number, the more wear that occurs. This is a unit-less value. One caveat to this number is that it only shows you the viscosity/temperature relationship between 40 and 100 C. Performance at 0 C may be very different in two oils that have the same VI. VI can be derived from the next two values, actually. The VI can be improved by adding those “VI improvers” (VIIs) but that comes with a caveat: the VIIs often break down at very high temperatures and this causes the oil to shear. Shearing means the oil’s viscosity begins changing. In general, better oils need fewer VI improvers.
    Viscosity @ 40 C is the kinematic viscosity of the fluid at 40 degrees Celsius (104 Fahrenheit). The kinematic viscosity is essentially “the amount of time, in centistokes, that it takes for a specified volume of the lubricant to flow through a fixed diameter orifice at a given temperature”. A lower number is better here. A low number means the oil flows more freely at the given temperature.
    Viscosity @ 100 C is the same as above, only measured at 100 C (212 Fahrenheit). The chart above actually shows you the acceptable range for a given oil viscosity. A 40-weight oil, for example, must have a KV @ 100C between 12.5 and 16.3. For a 30-weight, it is actually 9.3-12.5. So not all 5w40s are created equal.
    Selecting an oil purely because of a single value is going to lead to problems. If you select the oil purely based on its viscosity at 100 C, ignoring all other values, you could be in for a world of hurt. It might perform horribly at lower temps, meaning that the motor will wear excessively until its warmed up. Conversely, selecting it based only on the 40 C value means that it may protect well when cold, but will cause excessive wear at very high temperatures.
    You need to try and balance these numbers with your usage patterns. Does the car see lots of track time? You may want to give more weight to the 100 C figure since that’s an indicator of high-temp performance. Does the car just see light duty around town? Perhaps the 40 C number is more useful since you’re not thrashing the transmission and running it near its limits for 20+ minutes.
    If you’re like me, and you want the best all-around fluid, get the lubricant that has the highest viscosity index and the lowest kinematic viscosity values. Open your wallet wide for this.
    There are a few other figures worth discussing such as HTHS, TBN, and NOACK. We already talked about TBN up top in the change interval section.
    HTHS is “high temp high shear”. This is another SAE test that measures oil viscosity under high temperature high shear conditions. In particular, this relates to valvetrain and bearing regions. Higher is better; much like the VI rating, this is a strong measure of how well the oil resists changing viscosity. Again, the SAE sets a minimum value. For a 40-weight, it must have a minimum value of 2.9 (3.7 is the minimum for 15w40 and some other less common viscosities). For 30-weight, the value is also set at a minimum of 2.9. Whereas the VI can be artificially boosted with additives, the HTHS number is much more difficult to inflate. Sadly, many oil manufacturers do not publish this data. If you are interested in it, you may need to contact them directly.
    The last figure is also very elusive: NOACK volatility. This is an ASTM test that determines evaporation loss of oils under high temperatures. As temperatures rise, oil will begin to boil off some of its lighter weight molecules. This leaves behind the heavier stuff. Once this begins happening, oil consumption goes up and the viscosity goes up as well. In turn, the oil does not circulate as well. Lower values are better, as it again means the oil resists changing viscosity under extreme temps (150 C for this test). Lower values mean the oil retains its performance well under stress.
    To wrap this section up, keep in mind that these numbers don’t paint the whole picture about a given oil. What separates one oil from another is the additive pack it has. Some additive packs are loaded with VIIs that just artificially improve the viscosity index. Others may have components that are particularly good at resisting burnoff. The additive packs are a trade secret, though you can often speculate on their formulations based on various test data. Don’t just buy an oil because it has an amazing KV value or because it has an insanely low pour point.
    now: 2011.5 BMW M3 sedan ZCP
    past: 2005 Audi S4 sedan, 2011 Audi S4 sedan
    Apr 24 2009
    Chicago, IL
    Lightbulb
    Bringing It All Together
    Now we understand the idea of viscosity, basestocks, change intervals, the duties oil must perform, and what the VW specification is. We need to bring this all together to draw some solid conclusions on which oil to use.
    Let’s revisit the manufacturer specification: replace the oil and filter every 10,000 miles/12 months with 9.5 quarts of VW 502.00 approved oil. Quite a mouthful, right?
    • 10,000 mile/12 month interval: this is probably fine for most drivers if you use quality oil. I recommend getting an analysis done at your next change to see if the oil was still good at that mark. You might be surprised – some might need it changed sooner, others can go longer.
    • 9.5 quarts: it’s a lot of oil. Complain all you want about the quantity, but this motor benefits greatly from it. If the analysis proves you’re good for 10,000 miles, think of this as a 5 quart change every 5,000 miles…about on par with many other vehicles.
    • VW 502.00 approved oil: self-explanatory. If it’s approved, it will be in the product data sheet. Do NOT trust the label on the bottle as this is written by some marketing guy and not the chemists. 502.00 is going to be 5w40 or 5w30.
    Here’s my recommendation for a typical driver and/or someone in warranty:
    • Run your current oil to 10,000 miles for the next change. Send a sample in for analysis. This will determine if you can go to 10,000 again.
    • Stick with something from the VW 502.00 approval list. There’s a ton of choices, many of which are available locally or from various speed shops/Internet retailers. Your dealer will stock a very good OEM oil (Belgian-made Castrol Syntec or Castrol SLX Professional OE).
    Here’s my recommendation for someone wanting to move up to something better:
    • Run your current oil to 10,000 miles for the next change. Send a sample in for analysis. This will determine if you can go to 10,000 again. You might need to change more frequently if the car is driven particularly hard (track days, repeated WOT runs, excessive idling, etc).
    • Move up to a group 4 or 5 oil. Red Line, Motul 8100, Motul 300V, and Amsoil European Car Formula are a few of the good ones.
    • Get the oil analyzed each time you change it and keep a database of the results.
    Here’s my recommendation for someone more budget-conscious:
    • Try one of the diesel truck oils like Shell Rotella T6 or Mobil Delvac 1. These are available at most auto parts stores in large gallon jugs for about $20-25. They’re very stout oils and are perfectly safe to run in a gasoline motor. Another alternative is Mobil 1 Turbo Diesel Truck, but this is only sold in the quart bottles. Sadly these are not VW 502.00 approved but they are still a stout oil that’s built to take the abuse of a huge diesel engine. There are plenty of good analyses to show this oil works across a broad spectrum of motors and conditions.
    Locating This Information
    Most of the information we talked about here is readily available to you as a consumer. It must be made available via the material safety data sheet (MSDS) and/or product data sheet (PDS). Key figures may be available on the bottle label, but most of this is actually available directly from the manufacturer’s website. In some instances I have had to call or email the technical support group to request the data. You may need to verify you have a current PDS too; sometimes formulations are changed and the old sheets are still floating around.
    Some companies are very forthcoming about the formulation of the oil and how it performs. Others are not. In fact, it can be difficult to tell if a given oil is a group 3, 4, or 5 basestock. Don’t make any assumptions here.
    Typically some Googling will help you find those lost bits of information. You’re likely not the first person to wonder about the oil’s composition.
    Closing Thoughts and Miscellanea
    Motor oil is a complicated thing. It is essential for the motor to run, stay clean, stay cool, and keep emissions down. With the information presented here, I hope you’ve learned how to be more leery about what oils you put in the car.
    When in doubt, stick to the OEM stuff. OEM oil is either Castrol Syntec (Belgian) or Castrol SLX Professional OE, both of which are very high quality. Audi does not use garbage oil in their cars, nor does the 502.00 spec call for anything low quality.
    I encourage you to post in this thread with questions and comments. Share your oil analysis results. Talk about new oils.
    Oil chart
    I make no guarantees about the validity of this data. Manufacturers often reformulate oils, have typos in their datasheets, or simply neglect to share certain information. When in doubt, please verify these figures. Certifications are the most sensitive to accuracy since they can be dropped or added year-to-year. If you find an error, please PM or email me.
    If anyone is interested in hosting the Excel file, PM me.
    The two OEM (dealer) oils are highlighted in yellow. Note that everything on this list is 5w40 with the exception of the SLX Pro OE.
    Forum Moderator Four Rings SoCalS4Avant's Avatar
    Jan 24 2008
    California
    Copied to tech, so as not to get lost! http://www.audizine.com/forum/showth...wanted-to-know
    Moderator/Wiseguy
    Veteran Member Four Rings jfunkey's Avatar
    Jan 21 2009
    R32 B7/S4....2000 2.7t gone :(
    putting you into the wall
    more good information to follow this up
    http://www.audizine.com/forum/showth...al#post5613286
    Kinda clif notes
    This might help the more noobish oil guys..
    Viscosity rating: The thicker (higher viscosity) of an oil, the slower it will flow or the thicker the oil is IE. 5w.xx & 10w.xx....the 10w..will flow slower then the 5w. people like the thicker oil for componment coverage
    You will see oil viscosity measurement in lube articles stated in kinematic (kv) and absolute (cSt) terms. These are translated into the easier to understand SAE viscosity numbers you see on an oil bottle.
    When you see a W on a viscosity rating it means that this oil viscosity has been tested at a Colder temperature.. Ie. The 5w.xx
    The numbers without the W are all tested at 210° F or 100° C which is considered an approximation of engine operating temperature. Ie. xx.30.
    So why don't you just get a good synthetic oil with a good rateing..
    Oil companys put additives in the oil to try and bring up the...For lack of a better term Synthetic Viscosity Improving additive. These additves tend to hinder the oils ability under certian conditions.. So not all oils are equal.. but The OP will explain more of why.. this was just a inbetween post for maybe people who don't know lots about the terms.
    JHM war machine. Total transformation. JHM/Tune/headers/intake manifold.
    My B7S4. Faster then my old RS4 and First B7 S4 in the 12's
    AMA member
    USMC member (active)
    Facts first member. Built and supported by many
    Apr 24 2009
    Chicago, IL
    If you are curious about the science behind esters (group 5 basestock):
    http://www.bobistheoilguy.com/forums...94#Post1252272
    Jun 13 2010
    Ithaca, NY
    Amazing, thank you dparm!
    Jan 28 2008
    Germany
    You state that running the same oil up to 10,000 miles is OK. What about the duration? I run about 6000 miles per year. 50% around town 50% long haul. The town driving never exceeds 20 mies for a round trip. Often much less. With this in mind does the same oil change philosophy apply? Would the oil break down quicker due to condenstion and the fact that the any moisutre is not fully evaporated due to the town driving and the engine not running very hot?
    Thanks in advance
    Apr 24 2009
    Chicago, IL
    It *should* be okay if it's VW 502.00 approved, but I've seen analyses of OEM oil that doesn't look so hot at 7500. Best way to tell is to pull a sample at 5,000 miles and have it analyzed.
    And yes, driving cycle will affect the oil. Lots of short trips will wear the oil out more. Highway stuff is fairly easy on the oil and actually helps take advantage of some of its cleaning properties.
    Apr 24 2009
    Chicago, IL
    For example, here's my motor with a 5,000 mile change on Lubro-Moly Synthoil Premium 5w40. Bear in mind that the car had seen about 6 autocrosses and 2 track days so the oil had really taken a beating. I've since switched to a stronger oil. I'll be pulling a sample next weekend at the 1,000 mile mark to see if this stuff will last to 5,000.
    Could I have stretched the LM out longer? Yes, as evidenced by the TBN still being above 1.0. I probably could've gone to 7,500 but the oil was getting contaminated with wear metals from the hard driving.
    Oct 11 2007
    09' DG R8 4.2 18' Q3 BO S+ 03' Forester XS 5spd.
    Suburbia
    Funny how LiquiMoly isn't approved, I thought it was rated as one of the better oils... Either way, good read. Thanks Parm.
    09' R8 Daytona/CF 4.2 V8
    ~Avior exhaust & black tips~LEDs~10mm Spulen spacers~OEM euro mirrors~CF S-wheel~
    ~FeynLab ceramic~Xpel'd~35%Tints~Black rings/grille~3 pedals~No questions asked~
    08' Daytona/Ti RS4 (dearly missed)
    05.5' Dolphin S4
    Apr 24 2009
    Chicago, IL
    It's not on the list that was published earlier this year. There are other LM oils that are, however (I believe the Energy 0w40 is). It's still a decent oil, no need to avoid it. For me, it's not a strong enough oil unless I want to change it every 3-5k.
    My goal is to get the Motul 300V that's in right now to the 5k mark without getting nervous about excessive contamination or acid formation.
    Veteran Member Four Rings SquiddyB6S4's Avatar
    Apr 24 2010
    B6S4, CD5, Gen4 T4R, NA8 aka ugly track slut
    Teh!cks-us
    You sure Castrol Syntec is actually approved? I just checked my spare bottle, and it only says "recommended for" blah blah blah. I also checked online, and it says the same thing. Makes me think it's not approved, or used to be but isn't any more.
    -Jason
    2004 B6S4 6MT - Apikol Snub Mount, Piggie Pipes, Magnaflow Cat-Back, JHM Tune with Launch Assist, Squid Rear LSD #01 20lb wheels + Michelin PSS
    2013 Veloster Turbo 6MT - For sale
    1996 Miata - DE car; every moving part new or rebuilt, almost stock
    1995 Accord Wagon - Beautiful, stock, DD Duty, trip-mobile, track day support wagon
    LifeWithSquid
    Apr 24 2009
    Chicago, IL
    There are many versions of Syntec. It's possible the cert is only for certain varieties.
    Apr 24 2009
    Chicago, IL
    Good read about why you can't look solely at the KV figures when picking an oil:
    http://www.bobistheoilguy.com/forums...16#Post1988816
    The importance of the message is that the KV @ 100 value is only part of the whole picture. Crappy basestocks typically mean lots of VIIs (via the additive package). So cheap oils with a very high VI and/or KV are probably going to shear under extreme loads and become 5w30 or worse.
    Apr 24 2010
    Teh!cks-us
    Quote Originally Posted by dparm View Post
    Well, I've only done one oil change since I bought the car (shows how much driving I do), and I used the specific VW/Audi stuff they sell, but it doesn't specifically say "approved". It's kinda bugging me now. I was figuring if I kept changing with fully-approved shit, I'd have something to defend myself with if I ever had to sweet talk AoA into pitching in with engine work if the need ever arose.
    -Jason
    LifeWithSquid
    Apr 24 2009
    Chicago, IL
    It's on their list. Don't trust the label ** the marketing guys could've forgotten to list it or decided not to.
    Apr 24 2010
    Teh!cks-us
    Good to know. Does Audi post this list somewhere?
    -Jason
    LifeWithSquid
    Apr 24 2009
    Chicago, IL
    Dec 31 2008
    PA
    great info
    thanks for the effort
    Apr 24 2010
    Teh!cks-us
    Ri ruv roo raggy
    -Jason
    LifeWithSquid
    Apr 24 2009
    Chicago, IL
    I'm curious to see how the list changes over the next few years with GM's new DEXOS 1/2 certs. The new formulations might not meet VW 502/505 afterwards. Only time will tell...
    Dec 31 2008
    PA
    so the 5W40 LubroMoly is not 'approved'?
    only recommended VW502/505? (as listed on the bottle)
    it's also listed as synthetic technology, not fully synthetic (older ottles were)
    but on the webiste it's listed under 'fully synthetic'
    http://www.liqui-moly.de/liquimoly/p.../usa_2040.html
    not 'part synthetic'
    but the 0W40 says 'fully synthetic' on the bottle
    http://www.liqui-moly.de/liquimoly/p.../usa_2049.html
    but also only 'recommended', same verbage as the 5W40
    confusing as heck...
    Apr 24 2010
    Teh!cks-us
    I know what you mean. What I really want is a Group IV/V oil that *IS* approved, but I'm having a hard time verifying that there are ANY such oils. Even some that say they are, or who people say they are, but yet only cost $7-$9 a quart, which makes me really wonder if they really are, since the few that I can absolutely verify that ARE Group IV/V are at least $13/qt. It's frustrating.
    -Jason
    LifeWithSquid
    Aug 13 2009
    Quote Originally Posted by SquiddyB6S4 View Post
    ......and their names are?
    Dec 31 2008
    PA
    I might try this stuff
    Pennzoil 5W40 Euro Ultra full synthetic
    Ferrari, VW 502/505 and others
    http://www.pennzoil.com/#/motor-oil/pennzoil-ultra
    http://www.pennzoil.com/sites/pennzo...ropean5W40.pdf
    Senior Member Three Rings Mr Hyde's Avatar
    Oct 20 2009
    Long Island
    Quote Originally Posted by ArthurPE View Post
    That's what I planned on using for my next change; thought it would be one of the best OTC oils for our engine, but had no luck finding it in any store. I did contact someone mentioned on BITOG who works for Pennzoil, and may have some being shipped my way, and plan on putting it in on my next change.
    Just call me.............Mr Hyde
    2007 Mugello Blue Pearl RS4
    JHM 2.75" HFC // JHM Resonated Exhaust // APR 93 // KW V3 // RS6 Flatbottom // V1// LI-S4 Concealed Display // Stoptech Aerohats // Carbotech Pads // Ventureshield // Apikol Diff Mount // ECS Diff Carrier Mount inserts // 034 Tranny Mount // 034 Rear Sway //RS5 20x9" Titan Rotors
    Aug 13 2009
    A group III oil, AKA made with synthetic technology in Germany.
    Apr 24 2009
    Chicago, IL
    Why are you so concerned about the approval? If you look at the specs for Motul 300V, for example, it actually surpasses all the 502/505 approved oils. Motul didn't bother to get it approved/certified due to cost or time. Same can be said for Red Line.
    And poo-poo this all you want, but Royal Purple is a group 4 that can be had for $7/qt or less. It's not VW approved though.
    Aug 13 2009
    I must say that has always puzzled me. I suspect, however, that the reason that they are not approved is because they would or have failed to do so (get approval). Why would Motul bother to get some oils approved and not others and lose out on sales? Motul 300V is formulated as a racing oil and likely unsuitable for extended use.
    Apr 24 2009
    Chicago, IL
    300V is classified as a race oil. It's not marketed to the average driver so they didn't bother getting it approved. It's perfectly fine to run in a street car though. I'm running it now and will get it analyzed to see if it can go past 5,000 miles.
    Veteran Member Four Rings P0234's Avatar
    Jan 11 2010
    Need a B5 Avant!!!!
    NoVA
    Quote Originally Posted by Mr Hyde View Post
    I've been buying it from here:
    http://oilstore.stores.yahoo.net/pesy5weufoca.html
    Though I'm going back to Castrol Syntec, its so cheap when Advance has their specials, that its just not worth paying 2x for something else that might be marginally better.
    Apr 24 2009
    Chicago, IL
    Pennz Plat Euro and Ultra Euro are two excellent oils. The price is right for sure.
    You can run the 5w30 versions of each without problems. They're available at just about every auto parts store. Wal-Mart sometimes has it too.
    Jan 11 2010
    Need a B5 Avant!!!!
    NoVA
    Hmm, you sure the 5w-30 versions are VW502? I'm sure you won't nuke and engine because of one, but I think most of us prefer to use an approved oil.
    Apr 24 2009
    Chicago, IL
    I don't know if the 5w30 is 502/505, but it's still a very good oil. Check for approval here:
    http://www.google.com/url?sa=t&sourc...xH51TGA_RXEQLA
    Dec 31 2008
    PA
    looks like the 5W30's are approved (502)
    I know the Ultra 5W40 is, just too new to be on the list
    Jan 11 2010
    Need a B5 Avant!!!!
    NoVA
    The "Euro" formula is approved, but that isn't generally available, at least not at my WalMart/Advance/Autozone/etc.
    Apr 24 2010
    Teh!cks-us
    The one time I used RP in an engine, that engine started burning just a little oil from then on, and never stopped even after I stopped using RP oil. I was all gung ho about it until after a couple oil changes, and then for the rest of the life of that motor it needed topping off, when it never did before I started using the stuff.
    And I just want the approval on it so that if I do ever have timing chain issues, I can point to the AoA service quote and my strict adherence to AoA oils (and some documentation at first notice of any noises, complete with Audi tech saying "it's normal") and try to get them to pony up [by shamelessly bitching] for part or all of the engine work required. Honestly. Not sure what the chances really are, but none of the approved oils are really that bad (at least Castrol Syntec, which is what I'm using, isn't really a bad oil), so it's not like I'm risking some kind of engine damage by using the 99-cent crap from the auto parts store.
    Funny story, I actually found a quart of that shit in the trunk of the 240SX I bought. I didn't mind, since I bought the car non-running just to do an engine swap. I ended up using that bottle to dip drill bits in as tool oil, and I still do several years later. I figure that's about the only thing that crap could possibly be good for.
    -Jason
    LifeWithSquid
    Apr 24 2009
    Chicago, IL
    Royal Purple's motor oils get a lot of bad press for some reason. If you look at their formula and the performance figures, it's actually really good stuff. There is certainly better stuff out there but RP is a step up from most other lubricants at the auto parts stores.
    The additive pack in RP might not be the best for your particular motor. This is why I always advocate people try different oils until they find one they like. Availability, price, how the motor runs, how much it burns, MPG increase...everyone has their priorities.
    Apr 24 2009
    Chicago, IL
    Quote Originally Posted by P0234 View Post
    Yep. A lot of Wal-Marts are dropping Ultra, actually ** just wasn't selling as well as Platinum. I think people got confused and thought Platinum was the best.
    Regardless, there are online retailers that sell cases for a fair price.
    Oct 20 2009
    Long Island
    I actually ran the PP 5w-30 in my 2 other cars, but want something a little thicker for the RS which is rarely driven on short trips, and always gets up to full operating temps when it is driven.
    I have a large stash of German Castrol 0w-30 leftover from when I owned my 540. I debated using it in the RS, but for now, I am going to use it up in the other 2 cars, and stick with the 5w-40 for the RS.
