Results 1 to 6 of 6
    Nov 04 2009
    Vienna VA
    Wink Coolant question...
    Hi, so i replaced my old thermostat with a new one and during the process the old coolant just drained all out.
    I was wondering if anyone knows how to do a proper flush or like what type of techniques are used to wash out the lines before filling it up with new coolant
    Also,
    I have 3 leters of G12 coolant, i was wondering do i mix this with 50% distilled water and 50% of this g12 coolant or how does that go?
    Thanks for any help
    Active Member Two Rings Racerx220's Avatar
    May 05 2010
    Philadelphia , PA
    Nov 04 2009
    Vienna VA
    Thanks a LOT! thats probably what i was looking for, i will try to do this process tomorrow, i knew there was a way to do it before filling up new coolant
    Thanks
    Established Member Two Rings chitownsports's Avatar
    Mar 28 2010
    I need $$$ for cars
    Houghton, MI
    I just followed that diy yesterday, and it worked perfect (I found out that I had brown coolant so I had to do a complete flush, and everything is pink now!!)
    !!!Denim Blue Baby!!!
    Nov 04 2009
    Vienna VA
    so did you end up using the whole 1 Gallon of G12 coolant and you had to mix that with 1 Gallon of Distilled water?
    Veteran Member Three Rings 2001A4QUATTRO's Avatar
    Jun 05 2007
    2001.5 A4 1.8TQMS
    Get another container. Mix the G12 50/50 with distilled water and then fill
    Engine : Carbonio V2 Intake - RAI 3" TP - APR cat-back w/glass pack - APR TIP - Forge 007P - 00Black1.8T Heat shield - GIAC-X - APR Snub mount - RS4 motor mounts - SB Stage 4 w/DMFW - 034 Street trans mounts - Evolution Motorsports Phenolic spacer
    Braking : Centric Cryo Black Zinc / Hawk HPS (F+R)
    Exterior : Ultrasport 18" ET43 235/40/18 - RS4 grill - Debadged - S4 sideskirts and rear lip - E-codes/Philips+ HID
    Interior : AWE boost guage / vent
