Page 1 of 9 123 ... LastLast
Results 1 to 40 of 325
    Stage 2 Banner Advertiser Four Rings
    Jul 11 2005
    04 Audi S4, 04 VW R32, etc....
    Auburn
    Some dyno graphs.........
    Enjoy!
    Same day, Same Dyno, Same Car using APR's Engineering Test Methods.
    We are sharing uncorrected all wheel data, SAE corrected all wheel data, estimated crank data and the delta between each dyno.
    Testing days were in the 90+F.
    The APR RSC Exhaust was used during the stock and APR Beta ECU dynos.
    Veteran Member Three Rings drvolkl's Avatar
    300ZX TT, NSX, S2000, Tacoma, X3
    Cool. Sell it to me. :)
    C5 S6
    B6 S4
    B8 S4
    B6 S4 Avant
    B8 RS5
    C8 RS6
    C8 RS6 Performance
    Aug 10 2004
    Boca Raton, Fl
    Enough empirical data for me. Ill be buying the day it comes out.
    Feb 10 2004
    2009 A4 2.0T Sedan
    Why am I feeling so giddy!?
    Now if I heard that AoA was bringing the B8 S4 Avant to the States by the end of the year...I think my head would literally explode!
    Veteran Member Four Rings madmadS4's Avatar
    Jul 21 2010
    Westchester, NY
    Damn I gotta wash my shorts now.....
    Sprint Blue 2011 S4/S-Tronic/Alu-Optic/CF Inlays/Sport Diff
    VAG-COM Mods/Tinted/Front Plate Filler/BFI Spacers/H&R Sport Springs/RS5 Pedals/Ceramic Pads/AWE Intake/GIAC Tune/RS4 Grill
    Shoot me a PM if you need VAG-COM mods done...
    Veteran Member Three Rings rktskicar's Avatar
    Dec 12 2009
    Quote Originally Posted by Keith@APR View Post
    Enjoy!
    Keith-
    Cool! it It looks like your tune is set up for the high end of the RPM range. What's the reason for this? Isn't that technically a stage 2 run that you are posting (chip + cat-back), with stage 0+ (stock with cat-back)? How much boost is this running on this tune?
    Thanks,
    Bruce
    "I think the car is too damn quiet and smooth. It doesn't seem like you're hauling ass until you look down at the speedometer."
    Stock ECU, Sprint Blue 6MT 010 B8 S4, Premium +, B&O, sport diff, black Nappa, BBS CH, 255/40/18 Bridgestone RE960 AS
    Milltek resonated cat-back & DPs
    01.5 6MT ASP Stage 3 B5 S4 (4/01 to 9/09)
    Stage 2 Banner Advertiser Four Rings Arin@APR's Avatar
    Aug 23 2008
    Auburn, AL
    Technically no, it's not a stage 2 program. Stage 2 programming requires the removal of the catalytic converters. In these graphs the stock catalytic converters are still on the car.
    The reason you don't see a huge gain in the mid range is because most of the gains will come from adding boost. There's not much to add in the mid range but boost dramatically bleeds off towards redline which is why we have such a large hammer to throw towards redline. :)
    GoAPR.com | Facebook | YouTube | Twitter | Instagram
    Phone: (800) 680-7921 Local Phone: +1 (334) 502-5181 Fax: +1 (334) 502-5180
    Address: APR LLC, 4800 US HWY 280 West, Opelika, AL 36801
    Mar 27 2008
    San Diego
    Wow I was dead wrong! Marginal gains through the band but some serious power after 5k rpms! That's going to make for some big gains at the strip.
    Now not to be greedy but are completely stock vs. stage 1 dyno results in the queue to be done? :)
    Jul 21 2010
    Westchester, NY
    Yeah I missed that. The gains really take off after 5200 rpm or so. That's great though... to beat the M3 at the top end. Wonder what the max speed is for this car.
    Established Member Two Rings csauer52's Avatar
    Jul 14 2010
    Lehigh Valley PA
    Quote Originally Posted by mmart6545 View Post
    Works for me too. Congrats APR/Keith et al. I'll have you know I'm washing down my serving of crow with a cold Sam Adams.
    Thanks for sharing.
    Jan 24 2008
    West Coast
    Yes. This. For sure!
    Moderator
    Senior Member Three Rings krunko's Avatar
    May 24 2010
    a broom, old CDs I never listen to, cockroaches
    Los Angeles, CA
    Geez, huge gains over 5000 rpm.
    2011 Audi S4 / S-tronic / Prestige / Ceramic Tint / Stasis ECU Tune / H&R OE Springs / Fast Intentions full exhaust FOR SALE / 5mm Spacers / Stramosphere Intake / Interior LEDs
    Mar 01 2010
    BC
    am I wrong to be a little dissapointed to not see big gains earlier in the torque curve?
    2010 S4 6MT
    Aug 23 2008
    Auburn, AL
    Quote Originally Posted by Un1k View Post
    Yes because that's simply not possible. The Supercharger system is designed to run near maximum RPM's at all times and to simply bleed off boost. Lots of boost will give you lots of power. Since lots of boost isn't available down low (running near max), there isn't much room to go up. We can only run as much boost as possible, play with timing, air fuel, cams and a few other things to make more power.
    Towards redline is where the factory bleeds off boost heavily. There we are able to make loads more power. :D
    Jul 21 2010
    Westchester, NY
    Yeah I'd say half the low end gains could be attributed to the catback exhaust.
    Mar 01 2010
    BC
    Quote Originally Posted by Arin@APR View Post
    I understand, and am not saying you guys did a great job. But I just felt that it's not the best curve for everyday-fun. It'll just eat up my gas that mch quicker
    so am I correct to assume that to gain more power(boost) down low, we need a supercharger upgrade in the future?
    2010 S4 6MT
    May 24 2010
    Los Angeles, CA
    Does this mean with similar driving behaviors we should see a huge falloff in MPG as long as we're keeping it under 4k RPMs?
    Forum Moderator Four Rings blacka4's Avatar
    Dodge RAM 1500
    Pittsburgh Area
    aww shit...this makes me want to rob a back and steal the S4 at my local dealer
    -Rob - Moderator - PM Me!
    RIP:1999.5 Audi A4 1.8TQ Tip Brillant Black
    2009 Dodge RAM 1500 Crew Cab Sport - AZ Plate Frame - Bone Stock otherwise
    2014 Jeep Grand Cherokee Summit
    Jan 25 2010
    90 Corrado 20v 1.8 T
    Central pa
    Quote Originally Posted by blacka4 View Post
    i know how you feel, fortunately you can always pick up a b6 s4 and call it a day
    Registered User Four Rings primetime's Avatar
    Mar 05 2010
    5 four ring cars and 1 P-car...
    So.... the blower is running near max boost down low? boost is what 11-13ish with the tune? What is it up top? Nothing a smaller pulley won't cure....
    May 15 2010
    2012 E92 M3 Space Grey, DCT
    Montreal , Quebec
    This is actually a VERY good gain. I raced a buddy of mine in his modded 335 and I found that there was no pull on the S4 at round 5800 rpm... Now with this graph you will have pull to redline which is amazing. The worst part is when I have it on Dynamic and floor it the computer runs it to redline which was not optimal stock. I did quicker runs shifting at about 6k.
    Also the tq line is nice and smooth with gains throughout the RPM range.
    Wish I could see the numbers with JUST the ECU tune and no catback exhaust.
    2011 Audi S4 Black/Magma Red (Daily Driver)
    2012 E-92 M3 Space Grey on Fox red, M-Drive, conv pkg, exec pkg, Competition pkg, DCT, 18" Volk TE37 Super Laps
    2008 E-92 M3 GONE ,Brembos, AA CAtless X-Pipe, AA Exhaust, AA ECU, AA Pulley
    Veteran Member Four Rings nick71692's Avatar
    Jan 16 2008
    2010 S4, 2005 A4 USP, 2008 BMW 650I Conv. Sport, 2013 Jetta GLI
    Ohio and GTA
    Damn, now let us buy!
    2005 Dolphin Grey USP
    USP CLUB MEMBER #210
    2008 Ibis White S-Line A4 6mt, Stasis Exhaust (Gone)
    2010: S4, Ibis White, S-Tronic (Gone)
    2011 MKVI GTI 4 Door, Carbon, DSG (Gone)
    2012 S4, Monsoon Gray, 6MT (Gone)
    2014 S4, Glacier White - fully loaded (Gone)
    2019 S4, Glacier White - Prestige
    Jun 02 2009
    San Francisco
    Ditto.
    Veteran Member Four Rings drew's Avatar
    Jul 27 2004
    E60 M5 Gone: 996TT stage 3, E46 M3, B6 S4
    Orange County
    lol...its just dyno numbers. let's see how well it does in the real world before you blow your loads....
    Veteran Member Three Rings Legacykid's Avatar
    Mar 05 2010
    ATL
    Id like to see a video of maybe one of your s4's with the exhaust(camera car showing gauge cluster so no one can say you dogged it or not) and one s4 with exhaust an stg 1??? talk about a teaser!
    Maybe asking to much, but im excited great job guys this is just the beginning
    May 24 2010
    Los Angeles, CA
    I'm also curious to how an intake would effect these numbers.
    May 15 2010
    Montreal , Quebec
    One thing Im not getting are the stock with Cat Back exhaust numbers....
    Ideally a cat back exhaust is lucky to get you 10 to 15 hp so lets be optimistic and use 15. APR is saying the stock ecu with exhaust only is 438 hp so take out 15 hell even 20 for the exhaust and we are getting 419 HP stock??? I thought all previous dynos estimated the car to be in the 380 to 390 range stock. I can understand understating by a manufacturer but understating by 90hp seems a hell of a lot.
    Am I the only one that sees this or am I making a mistake reading the corrected at engine graph???
    Veteran Member Four Rings NWS4Guy's Avatar
    Sep 29 2009
    2015 Range Rover Evoque 2010 Audi S4
    Those numbers are at the crank, corrected, taking into account a 23% drivetrain loss.
    Like a surgeon with a scalpel, my S4 is a precision instrument, with which I carve and dissect my way through traffic.
    2010 S4 Prem+, Quartz Gray, S-tronic, Sport Diff, B&O, Nav, Gray Birch
    StopTech ST-60 BBK - Stratmosphere intake - APR v2.2 Stage 2 w/pulley + exhaust, v2 Coolant System
    Alu-Kreuz, Apikol rear diff mount, 034 transmission mount
    May 15 2010
    Montreal , Quebec
    Quote Originally Posted by NWS4Guy View Post
    That's exactly my point... They are saying the S4 stock is about 420hp at the crank and hence saying that Audi understated HP by about 90!!?? lol thats huge if its true.
    Jul 14 2010
    Lehigh Valley PA
    Quote Originally Posted by M3 Montreal View Post
    What I don't get is that in the corrected all wheel figures "beta ecu upgrade vs stock ecu", it shows a HP gain of 337 vs. 377 = +40hp and 338tq vs. 354tq = +16.
    In the corrected all wheel figures "gains over stock" it shows +73awhp & +55 awtq.
    Am I reading this incorrectly or is the second graph a peak to trough difference?
    Jul 11 2005
    Auburn
    We aren't saying anything. We are showing what we measured at the wheels with a stock S4 and the APR RSC vs. What we measured with our ecu calibration added to the same car plus an arguable aftermarket industry standard of 23%. Audi knows best how to rate their cars, not APR.
    Sep 29 2009
    This is still corrected numbers, it was 90 degrees that day. I agree that there is not likely that much at the crank stock, however since they are using the same formulas, car, dyno, and everything else, the focus is not on the totals so much as it is on the deltas of the numbers. This shows real world amounts of gains.
    http://www.land-and-sea.com/dyno-tec...horsepower.htm
    Aug 23 2008
    Auburn, AL
    Quote Originally Posted by madmadS4 View Post
    The exhaust is a constant. The graph compares stock + exahust vs chipped + exhaust so it's not the exhaust.
    More or less yes, that's correct.
    Quote Originally Posted by krunko View Post
    Under 4k a lot of playing around with air fuel ratio and timing gets you more power. Because of this the system as a whole should be more efficient.
    Quote Originally Posted by primetime View Post
    We haven't released boost figures yet but as soon as I'm able to post them up, I'll show everyone what it does. :
    BTW, the charger is already running near it's max RPM at redline so it's not quite as simple as throwing on a really small pulley for more boost.
    When we release the software we'll have a full analysis for you complete with bone stock vs chip only. I'll post all back to back same day data to. :)
    It's best to compare data collected on the same day or same conditions using the exact same collection methods. I don't have any data for the stock exhaust vs APR exhaust on the same day as the data we posted in this thread. You can see the gains from the exhaust only from data on our website!
    The crank figures I showed everyone are just simply an estimate using a fixed 23% drive train loss. That seems to be the 'tuner' norm for a quattro car. I also showed all wheel so there is no guess work. Is 23% correct? You decide! You have the wheel numbers so you can use whatever you feel is correct. :)
    Audi may have estimated low. Audi may have simply taken the worse possible conditions using the worse gas ever and said "use those figures" so no one would ever dyno under what they say it should make. Bottom line I think we can all safely say this car is making a lot of power from the factory and a lot more chipped.
    Aug 23 2008
    Auburn, AL
    Quote Originally Posted by csauer52 View Post
    Take a look at the graph:
    It shows HP and TQ gains at every RPM.
    Peak power is not the same as peak gains. Peak power is the highest HP the car made. Peak gain is the highest gain it made over the other run.
    Jul 21 2010
    Westchester, NY
    yeah. it concerns me that the 7th chart suggests that the S4+exhaust peaks at 438 hp. subtract out their highest figure claimed for gain on the APR - which is 18 and you get 420 hp for the stock S4. sounds fishy...
    Senior Member Two Rings rx7ven's Avatar
    May 14 2010
    2007 Mazda Miata
    San Francisco
    thanks APR. good work. are you able to share with us if this will be an OBDII upgrade or will we need to ship out our ECU?
    Sep 29 2009
    Like has been said, a dyno is a tool, it's not an exact and precision "read out the data and this is exaclty what is what." Don't focus so much on the end numbers, look at the overall delta.
    Aug 23 2008
    Auburn, AL
    What exactly is fishy?
    We said the car made 377 All wheel HP using SAE correction. If you were to assume 23% drive train loss (which many people seem to feel is correct), you get 489 hp at the crank.
    377 / .77 = 489.
    Active Member Two Rings simulacrum's Avatar
    May 21 2010
    Phila PA
    Price
    Anyone have any intel on price, or comparative speculation given cost of prev model upgrades of this nature? New to audi so stumped on probable cost range.....
    ETA: ok so i did my homework...$600ish? Really? Time to use the search function to learn abt warranty impacts....
    Last edited by simulacrum; 08-18-2010 at 07:50 PM. Reason: Used the $&@! Search function
    Jul 14 2010
    Lehigh Valley PA
    Got it. Thanks Arin. How many data points are collected in the series in order to make that graph and how do you choose which runs to display? Is the standard to usually plot current vs. previous run or is it at the discretion of the tech to choose which runs are comped and ultimately displayed?
