Results 1 to 37 of 37
    native launch control on me7 ecu. includes proof of concept video.
    here is native launch control hack built in to me7 ecu.
    VNMX The vehicle speed for activating the raised (normal) rev limit. We set this as low at it goes (1.25 km/h) so the launch control shuts off as soon as you start moving off the line.
    DNMAX This is the RPM above rev limit when the fuel cut comes on. Tweaking this helps make more boost on the limiter. I use 50 RPM
    ITNMXH Dwell time under lower limit before activating the upper limit. We set this to 0 seconds
    NMAX Ends up being the launch RPM. I've found 4500 RPM works well.
    NMAXOG This is the raised RPM limit which becomes the standard limit. Mine is set at 7100 RPM
    TMOTNMX Coolant temp for activating raised (normal) rev limit. We set this at -48 so that it can activate at any coolant temp.
    TNMXH This is the time duration of the raised (normal) rev limit. We set this at it's maximum value of 655.3500 seconds. I haven't had a problem yet with this and have been testing for months.
    these are the addresses for my b5 1.8t ecu, 4b0 906 018ch. should be pretty close for a b6 ecu. just search the hex.
    Code:
    vnmx 11afb 8bit 1x1 1.25 factor
    dnmaxh 16494 16bit 1x1 .25 factor
    itnmxh 16498 16bit 1x1 .01 factor
    nmax 1649a 16bit 1x1 .25 factor
    nmaxog 164a2 16bit 1x1 .25 factor
    tmotnmx 1f9ea 8bit 1x1 .75 factor
    tnmxh 164a6 16bit 1x1 .01 factor
    and the proof:
    credits to brandon @ pathfindermotorsports for posting the original hack on s4 mbox.
    credits to evan @ absolute for helping me find the last missing piece of the puzzle.
    credits to me for porting it to my 018ch ecu. lol. :p
    native me7 1.8t b5 quattro launch control:
    http://www.youtube.com/watch?v=nDHxPhNPE8s
    contact via email please.
    Jan 25 2006
    A4 2.0T
    MD
    Good work Ian.
    Sep 12 2008
    South Central PA
    You are amazing
    EFR | 7163
    268/260 cams
    I.E. Intake Manifold / 70mm
    BoostManager+
    Meth Head
    eh? i thought b6 people would be more interested in this.
    Veteran Member Four Rings MmmBoost's Avatar
    Nov 29 2005
    10 A4 Avant S-line, 07 Suzuki GSX-R600, '69 VW Beetle w/ 1.9L aircooled turbo
    Edmonton, AB
    I've got launch control with my Maestro tune :P
    ~Chris
    I sold my Audis and bought a Touareg... Catch me over at Club Touareg
    My B6 Avant GT2871R build
    Tumblr
    "Robert Bosch don't fuck around"
    Jun 22 2009
    Dundalk, MD
    haha Ian 80% of people have no idea what's going on
    Jun 21 2005
    Milton, Ontario
    So does this inject more fuel to increase engine load?
    – Steve
    2021 Tesla Model Y
    2020 Tesla Model 3
    2014 Dodge Grand Caravan
    Quote Originally Posted by SleeperAvant View Post
    no. it cuts fuel when the rev limit is hit. i changed the fuel cut off from 50rpm past limit to 0 past limit. so now fuel cut hits and produces a lot more load. before it just seemed to hang at the rev limit and not hit fuel cut.
    Quote Originally Posted by MmmBoost View Post
    bah. its more fun to do it manually. :p
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    Is that thing stock or something? The revs dropped so far down you are just bog, well unless you have power to keep the wheels going from actually having boost and a more powerful engine, then it could be cool. Just have to see if it is as easy to do it to the B6 ecu as the B5. And when does this work? Always? As in if I just tried revving my car in neutral it wouldn't rev but do that instead? Or does the clutch need to be pushed in for it to work? And then how about if I was in neutral with clutch pushed in?
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Jun 22 2009
    Dundalk, MD
    Ian, how much boost are you seeing?
    Quote Originally Posted by A4 TSCHUSS View Post
    the car is completely stock engine wise except for my ecu flash. and i made that video super fast this morning right outside of my neighborhood because i had to get back home. i know it sucks. i just wanted to show it actually works.
    its active as long as the car is going <1.25km/h. so sitting still basically. once youre rolling, the higher limit is active. clutch shouldnt matter.
    Quote Originally Posted by [email protected]. View Post
    i dont really know. as cheesy as this sounds, i have no in-car boost gauge. ive only ever logged with vagcom. i have a gauge and a pod, i just never made it around to installing it. i guess im lazy.
    Jun 22 2009
    Dundalk, MD
    so it basically sets a rev limiter at idle?
    Apr 24 2005
    E55 AMG, CTS-V
    So this is both cool and sucks at the same time. I am now stuck with a (whatever I set it at) rev limiter for this launch control and cant actually rev my car to say 7000rpm if I wanted to blaze the tires or just rev it while not moving. But then it is cool that you can have the launch control type feature but it is (either/or) not both. Maybe if there was a flip of a switch or something that could activate, that would be cool.
    ~David~
    CTS-V 9.6@148
    no. youre using the standard rev limiter as the launch limiter. and tricking the ecu in to letting you use a speed based limiter as the normal limiter.
    so nmax (standard limiter) is set to launch rpm, in this case 4500rpm. then nmaxog (speed based limiter) is set to be active after 1.25km/h, which is set to whatever you want (7100 in the example above).
    read the descriptions and explanations of the values. is a pretty good hack.
    edit: i see what you mean. it basically sets a rev limiter as long as youre not moving. long and short of it.
    set the limiter at 7000 then. 7k + boost launch. :p
    Apr 24 2005
    E55 AMG, CTS-V
    That would not be good.
    ~David~
    CTS-V 9.6@148
    just an idea. haha. i need to make a new video when i have some time.
    Veteran Member Four Rings drjonez's Avatar
    Oct 27 2009
    2011 Q7 TDI Prestige, '72 Nova
    The Cheese State
    Well done. If/when I ever get more time in life I'll have to drop you a line...
    '11 Q7 TDI Prestige
    Function > Form
    Senior Member Two Rings lave3k's Avatar
    Apr 30 2009
    03 A4 1.8t, 03 Honda 954rr
    FTC, Colorado
    Anyone replicated this on a B6 yet?
    I took a brief look at my file in those locations and nothing jumped out at me
    When I altered the dtc's and immo on this ECU the locations were very similar to examples posted by K0mpresd (you da man)
    Looking at it in decimal (base 10)
    [IMG][/IMG]
    Veteran Member Four Rings aLeXliu911's Avatar
    Sep 14 2006
    2003 A4 1.8T QM
    Vancouver
    i want to know what boost you are holding at 4500rpm. please put the boost gauge on your car.
    i hope someone can hack our ECU and put anti lag feature on it. i hate the turbo lag, it's wayyyyyyy to long.
    BetaAlphaTau member #11
    2003 A4 1.8T 5SpdMQ Black
    545awhp, 477.4awtq
    Stasis Motorsport C/O
    Stasis Center Diff
    Stasis Rear LSD
    Stasis Alcon BBK
    Status Carbon Fiber Seats. ER Comp FMIC
    2008cc, AWM, Ported AEB Head, HTA GT3582R,Full Race Exhaust Manifold, INE Intake Manifold
    Quote Originally Posted by lave3k View Post
    i sent you a pm. where is your standard nmax located (normal rev limiter)?
    Apr 24 2005
    E55 AMG, CTS-V
    Quote Originally Posted by aLeXliu911 View Post
    This doesn't really makes sense. Why you ask, because you don't deal with turbo lag when you are launching the car. You rev it high where you are going to get boost when you let the clutch out and rip away with tires blazing. This anti-lag feature is only used when not moving to help with a more consistent launch at a good rpm which can also be used for someone who isn't so good at launching the car. But once again, there isn't any turbo lag when launching!!
    ~David~
    CTS-V 9.6@148
    here is a quick look at 8e0909518ak ecu.
    11d8e cwnmaxmd
    11d9e vnmx
    168dc dnmaxh
    168e0 itnmxh
    16900 nmax
    16908 nmaxog
    1690c tnmxh
    2b964 tmotnmx
    no guarantees but it looks right. or close enough. :p
    want to do some digging? download a stock 018ch file, download the file i posted in my thread in the b5 forum. look at the hex, compare the differences, and compare the hex around the addresses to find the best guess at where your data is located.
    btw, i found those in a 75 6E 69 74 72 6F 6E 69 63 20 63 68 69 70 70 65 64 file. ;)
    Sep 14 2006
    2003 A4 1.8T QM
    Vancouver
    i mean put anti lag while driving, not on launching, so means about 1 psi at idle(900 rpm), and about 5 psi without any load thru out the rpm, and about 10 psi while you let off the gas shifting gears with clutch in. i was doing some rolling race with a 335xi coupe has about 380awhp, and i lost him every single time coz the turbo lag, i get closer when in the boost, but he just keep walking me away once i shift, coz i have to rebuild the boost again, btw, the bmw is automatic.
    545awhp, 477.4awtq
    Stasis Center Diff
    Stasis Rear LSD
    Stasis Alcon BBK
    Dec 03 2005
    2 pedals 1FG
    connecticut
    good job ian.
    this is really need to be able to do such a thing with motronic.
    -Doug
    what you need is a diesel. it has boooooooost all the time.
    Sep 14 2006
    2003 A4 1.8T QM
    Vancouver
    Quote Originally Posted by k0mpresd View Post
    my friend's STI use vi-pec v88 ecu, idling with anti-lag it makes 1-2 psi already. 3-4k rpm decel around 10-15 psi. 5-7k around 15-20psi decel. it's REALLY loud.
    i just hope we can get that anti lag feature too on our ECU.
    545awhp, 477.4awtq
    Stasis Center Diff
    Stasis Rear LSD
    Stasis Alcon BBK
    Veteran Member Three Rings bl0wn3ur0's Avatar
    Jul 22 2008
    NY/PA
    Isnt anti-lag bad for the engine? I remember reading something that said the way the car builds boost while under no load was very harmful to the engine internals over a long period of time........
    I love the launch control idea tho, i will be keeping an eye on this to see what needs to be done on a B6
    i need to amend this. clutch does matter. if you bounce of the lc limiter without the clutch depressed then the ecu throws an epc light and shuts the throttle down. a key cycle is required to get things back to normal.
    Veteran Member Four Rings FORCE_FED_DUB's Avatar
    Aug 10 2008
    Denver, Colorado
    For those with small port heads, keep the SAI functional and modify the software parameters to have it running any time the car is making less than x boost. The extra air from the pump going straight into the turbo would help out a bit. Much easier said than done, I do admit. Also, it isn't nearly as volatile on engine components as running a retarded spark anti-lag.
    BT/BAT build threads make me happy I have a stock turbo
    -Cam
    Jun 08 2008
    Calgary AB Canada
    Quote Originally Posted by bl0wn3ur0 View Post
    All anti lag does is retard the timing SOO far that there is combustion when the exhaust valve starts opening, this exhaust gas then escapes past the exhaust valve and helps spool the turbo
    2011 Audi A4 Avant // quattro // Garnet Red
    Stock. For now...
    1989 Porsche Carrera 4 // 5 Speed // Guards Red
    i sent you a pm but figured id post it as well.
    here is 8e0909518af:
    Code:
    12071 cwnmaxmd, this bit must be set to 01 to activate the limiters.
    12081 vnmx
    17410 dnmaxh
    17414 itnmxh
    17434 nmax
    1743c nmaxog
    17440 tnmxh
    291ee tmotnmx
    bit map and factor data is the same as what i originally posted.
    Veteran Member Four Rings 613B6's Avatar
    Jul 29 2009
    Street racing in Ottawa
    Quote Originally Posted by FORCE_FED_DUB View Post
    New diesel trucks are starting to use this method instead of the harsh anti lag. They use the extra air from the parking/brakes system and dump it directly into the exhaust housing as soon as you touch the pedal for instant boost without all the negative effects of an anti lag.
    A3 8V | 10.89@129 | Boss700 | Eurodyne
    Nov 04 2011
    Vilnius, Lithuania
    Hey everyone! :)
    I was trying to port launch control over to 1.8T AWT (4B0906018DC), but without any success. I've managed to identify maps locations (or atleast it looks like them), but I dunno why it doesn't work (car doesn't limit rpm @ 4500 while standing still). Looking for any input ;)
    MEMORY LOCATIONS I've FOUND:
    VNMX 11B15
    CWDNMAX 12219
    DNMAXH 16562
    ITNMXH 16566
    NMAX 16568
    NMAXOG 16570
    TMOTNMX 16574
    TMNXH 16578
    BEFORE LAUNCH CONTROL BIN FILE:
    http://www57.zippyshare.com/v/95082208/file.html
    AFTER LAUNCH CONTROL BIN FILE:
    http://www57.zippyshare.com/v/48419024/file.html
    Veteran Member Three Rings Trev's Avatar
    Nov 25 2007
    b6 a4tq, 95 Eagle Talon (Rip)
    British Columbia, Canada
    Some Go, No show
    02 Qtip, Apr II+ 93Oct, tt-225 injectors, Ecode fmic, W/M Injection, Magnaflow 16601,TT225 Down Pipe, VMR test pipe, APR TIP, Forge 007, Vag-Com, Podi V2, RS4 LSB, ECS Snub, USP front lower, S4 Front Brakes, Slotted/Dimpled Rotors f/r, SS Lines f/r, 19x8.5 & 19x9.5 RPM 505's, RNS-E
    Wish List
    Custom fab intake heat shield, Custom fab system in trunk, Adjustable Coilovers, S4 blades, DTH side skirts
