Results 1 to 40 of 72
Thread: Armrest lid
    Established Member Two Rings VegasUSP's Avatar
    Apr 21 2010
    North Las Vegas
    Armrest lid
    So the lid on my armrest broke, I went to audi but they want to charge me 300 bucks for the damn thing! What other places might I find one of these?
    Established Member Two Rings jimbro's Avatar
    Mar 05 2010
    02 Denim Blue Avant
    HI State
    whats the part number?
    Senior Member Two Rings PurpleNerple's Avatar
    Jan 06 2010
    Pacific Northwest
    If its the hing I'd just fix it yourself. I broke mine and fixed it using some type of (two part) plastic bond. I suggest screwing a tiny hole in each side of the hing and then using wire to bind the pieces together. Then mix your bond and slap it on there nice and good with lots of coverage. Then sand, paint black, and it will look and work good as new. Just make sure the hing is straight before applying adhesive. I also advise you remove the lid before doing this and I put bond on the other side too to prevent it from breaking aswell. Trust me though, JB weld wont work. I used a plastic adhesive/bond that looked like a double barrel syringe. Got it from shucks/orielly. Goodluck!
    -Anthony
    Established Member Two Rings LTizzil's Avatar
    May 07 2010
    B8.5 S4/K6 GSX-R1000
    ND
    This and the glove box hinge are a common problem on the B6. Mine are broken also but I just fixed the glove box with brackets from Fritz. Armrest still broken, bc $300 for a new one that is going to break also is ridiculous.
    B8.5 S4
    034 Stage 2+
    Vorsteiner V-FF 103 19x9.5
    Veteran Member Four Rings fatbrembos's Avatar
    Sep 30 2009
    b7 s4 avant/ c6 avant
    Orlando
    sorry to thread jack
    but do you guys know how much itll cost to get the front piece fixed
    its the little part that you push on to open the armrest
    heres a picture
    For Sale:
    HRE 943R Wheels
    Full B8.5 S4 Interior (black leather/black alacantara)
    Current Cars:
    B7 RS4 Widebody Avant
    D3 A8L - for sale
    MK5 GLI - for sale
    MK4 GLI
    Jan 06 2010
    Pacific Northwest
    Quote Originally Posted by fatbrembos View Post
    heres a picture
    Thats broken on mine too. It still is springy but on side pops in like a bottom and prevents it from closing unless i unpop it. If the spring feature on it is broken, you can fix the spring yourself if you still have it or if you can source it from audi. Just attach the spring on one side and around the clip in the middle, then take a paper clip and bend the end into a tiny hook. Hook the other side of the spring and pull it through and onto the other side. Fixed! Again good luck!
    -Anthony
    Sep 30 2009
    Orlando
    Quote Originally Posted by PurpleNerple View Post
    thanks man
    the problem is im not too sure if thats the case, i felt something break, and the entire little lever came of, so im not too sure if its something plastic in there that broke or if it is just the spring, but thanks for the tip ill have a look and see what i can do
    For Sale:
    HRE 943R Wheels
    Current Cars:
    D3 A8L - for sale
    MK5 GLI - for sale
    MK4 GLI
    Senior Member Three Rings Dake's Avatar
    Jul 20 2009
    Full of Germans
    Missouri
    Mine was broken when I bought the car. It was functioning with one of those two-sided adhesive velcro rigs, which actually works perfectly fine for how much the cupholder ever gets used. However the leather started coming out of the passenger side of the armrest, so I found a shop around that parts out A4s that sold me a used entire armrest for $25. It took me about four mintues to install it.
    Shop around and see if you can't buy a center console off a guy parting out Audis.
    2002 Audi A4 | Milltek exhaust | Valeo bi-xenon E-codes | short throw | 220k+
    1989 Audi 200 Avant
    1979 Audi Fox sedan
    1979 Volkswagen Rabbit diesel
    OEM+ #60; Ozark Mountain Region SCCA; Honda rider.
    Veteran Member Three Rings Scrwedtxboy31's Avatar
    Oct 19 2008
    2004 A4 1.8TQM (6sp)
    VA
    Quote Originally Posted by jimbro View Post
    X2
    -Eric
    R 1 3 5
    2 4 6
    Jan 06 2010
    Pacific Northwest
    -Anthony
    Senior Member Two Rings jjaram's Avatar
    Apr 06 2007
    Rio Rancho, NM
    heres a picture
    I just fixed this on my wife's car. You can't buy the latch alone, the only thing you can do is buy the whole lid piece. Try geniunevwaudiparts.com. I think you can get it for $60-$90 there. Or you could do what I did. I found someone that had a broken armrest due to the hinges in the back (another common problem) and bought that from him. You can seperate the leather piece from the plastic piece on the lid and remove the latch. It takes some effort but comes apart just fine. Hope that helps. Hit me up if you have any further questions.
    Established Member Two Rings slow&low's Avatar
    Mar 15 2008
    Spokane, WA
    I've got one to sell. Black in color. You can have the whole assy or just the lid for $100 plus shipping. I'll ship for free if just the lid. Let me know.
    Apr 21 2010
    North Las Vegas
    Yeah it's not the hinge, the actual plastic that the leather wraps around broke (I have no idea how it happened). The part number that audi gave me is 8E0 864 245P. Slow&low check your pm's.
    Veteran Member Four Rings Peacob's Avatar
    Jul 08 2009
    Bicycles
    Detroit MI
    Quote Originally Posted by slow&low View Post
    the whole assy for 100 or just the lid? i'd consider the lid if you'd go lower
    -Brian
    B6 A4 USP OEM+
    B8.5 SQ5
    B8 A4 Avant S-Line Prestige
    Oct 02 2006
    Wadsworth,OH
    We have new lids for less than 100 bucks! Remember, if you have a part number you can put it in our system and pull up any OEM part. At any rate, the 8E0 864 245P part number returns these results - Click here for various arm rest lids. Don't be alarmed with the digits following 8E0 864 245P as those indicate color codes but are otherwise the same part.
    Established Member Two Rings neil08's Avatar
    Jul 20 2010
    hartford ct
    Quote Originally Posted by Chris@ECSTuning View Post
    I cant find them on your site for less than $100
    2004 A4 1.8T | GIAC Stage 1 | RNS-D W/ VIM | DICE iPod Interface | 18" Hypersilver RS4's | Sport Suspension
    Car is gone, so are all my parts
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by neil08 View Post
    That was a couple month ago when I made that post. We now have a wider selection available at this link - click me for B6 A4 armrests including armrest options under 100 dollars.
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    i need one in black and one in beige, guess i'll add it to the list of shit.
    May 21 2007
    Florida
    Quote Originally Posted by Pete@ECSTuning View Post
    that is fanfuckintastic! so pumped. now only if you guys had a glovebox lid for that cheap lol
    2018 Navarro Blue Q5
    Sep 16 2010
    Central Wash
    http://www.weberbrothersauto.com/
    Call them, ask for Dan. The other guys that work there are assholes. He sent me an entire B7 center console for $50 with the armrest.
    Apr 21 2010
    North Las Vegas
    Quote Originally Posted by rollerton View Post
    The entire center console cup holders and all or just the armrest? 50 bucks is great for the whole center console.
    Sep 16 2010
    Central Wash
    The whole enchilada from a B7 in new condition- Armrest, Console, Ebrake, AND ashtrays with aluminum trim. Might have been a one-time deal/mistake at that price. But they sold me the Grey Avant cargo cover from the same car for $50 too!
    Dec 17 2011
    celje
    Anyone think, this will fit: http://www.ebay.com/itm/110798986537...225d29&vxp=mtr
    I think it's a leather, or not. Any info if some one bought it, will be great. Probably the catch comes along.
    Sep 16 2010
    Central Wash
    Quote Originally Posted by krajnc View Post
    Hm. That's not bad...but china? Ehhhh. Not sure I like it.
    I have some spare parts I'll sell you, same tan color too, the lid needs recovered, you can easily swap your cover to it, nothing broken. Cheap.
    fWiW the C5 A6 armrest is very nearly identical. It is about 3/4" shorter when installed. But otherwise interchangeable.
    Dec 18 2011
    Colorado Springs
    Both my armrest lid and my glove box are broken...audi said $1000 for the glove box and $198 for the armrest lid...just btw
    Im living with it till I find a wrecked one.
    Dec 17 2011
    celje
    What about china made headlight switch. Cost 100€ less then original and are better looking then original. People did say is way better.
    It was about time someone did a copy of armrest lid for a4 b6. That thing is breaking and costing a fortune for a plastic piece.
    Dec 18 2007
    nj
    i have been meaning to just glue both of mine shut, so sick of the lid sliding off the damn armrest every time i put my elbow on it.
    that is one of my missions for this weekend.
    Sep 16 2010
    Central Wash
    Yep. I have the china headlight switch with the chrome. Works fine.
    Pm if you want a armrest lid cheap. Or buy one from an A6, exact same part.
    Dec 17 2011
    celje
    rollerton thx on offer, but i only need a catch on the lid. btw i'm form EU
    I posted ebay link, because i know a lot of people have broken lid hinges or catch. Hard to repair plastic, not enough room (lid to thin) to bolt anything down. So if this fits on armrest, i'm happy to help someone saving money.
    Dec 17 2011
    celje
    lol: from the link that i posted: "15 set sell out. we will get new stock after 20 days ...sorry . Price jumped from 25$ to 200$
    Active Member Two Rings KM4N's Avatar
    Nov 23 2009
    mountain bikes, snowboard, tools, rubbish
    Kitchener
    Quote Originally Posted by jjaram View Post
    exact same problem on mine. the latch piece broke right off.
    thanks for all solutions offered here
    2005 A4 1.8tqm - black on black - FRANKENTURBO, 440cc, 034 HFC, stealth exhaust, 18" enkei EKM3, Bilstein sport/H&R, RS4 rear sway, Precision FMIC w custom piping, Stg2 Bully clutch w LWFW, HP2, Podi, R1DV
    Dec 28 2011
    F-150
    san francisco, ca
    Try Shokan.com.. they sell Audi parts. I just got mind from there for $85... good luck.
    Established Member Two Rings bronx car guy's Avatar
    Dec 21 2010
    CORRADO G60? dune buggy
    bronx, ny
    ECS sells them in every flavor I wanted a new one because whoever you get one from they would probably be brittle and if it is good condition it might last you a few months from the leaning pressure you might put on it.
    Oct 02 2006
    Wadsworth,OH
    If you need something feel free to shoot me a PM with your VIN and I'll make sure you get the arm rest lid that matches your interior perfectly!
    Jason
    Veteran Member Three Rings jalcom1's Avatar
    Feb 23 2009
    '01 S4, '69 Camaro SS
    IL
    I have a spare beige armrest lid if anyone is interested
    Jun 06 2012
    KC/MO/USA
    Quote Originally Posted by jalcom1 View Post
    Do you still have this part?
    Nov 16 2012
    Łódź, Poland
    Guys
    could you be more specific and tell me how can I unattach the leather top of the lid from its plastic bottom? I would be even more pissed if I broke something else in the armrest and I am counting on you to help me.
    Veteran Member Three Rings Osher67's Avatar
    Nov 03 2012
    California/so cal
    My armrest lid was warn out and the latch broke off.
    I know it's the cheep route but I bought one off eBay for 20$, and works perfect. You can tell the Cushion and leather is not of the finest quality but for 20$ not going to argue and ill see how it lasts
    -Josh
    2002 01A Quattro
    K04-15 (Unitronic)
    Veteran Member Three Rings AutoUnionLov3r's Avatar
    Mar 03 2011
    MK4 Jetta 2.slow-sold, MK4 GTI 1.8t-dead, TT225-sold
    Pittsburgh
    Armrest lid
    Quote Originally Posted by 1/2millionmiles View Post
    X2! Shokan has 1,000's of anything random you may ever want or need. They are usually short on USP cosmetics tho...
    '04 USP
    Test Pipe, SAI Delete, Custom Intake, APR Snub Mount, 710P, Joey Mod Headlights.
