Results 1 to 17 of 17
    Junior Member One Ring
    Feb 13 2009
    06 A4 2.0 S-line (gone at 190K), 2011 A6 3.0T, 96 3000GTVR4
    Marblehead MA
    Won't start after filling gas
    First off, I think I remember seeing a thread about this long ago, but after much searching, can't find it... sorry.
    2006 A4 2.0 S-Line 6 sp manual
    So I've been blowing this off for a while now, if I shut the car off when I fill with gas it takes 20 sec of cranking to get it to restart. So I leave it running, but it's tossed various CEL codes.
    When this started, I had P0507 P2187 P1093 P119A
    Now time for a state inspection, and they scanned P0507 P0171 P0441.
    Of course, any suggestions would be greatly appreciated!
    thanks,
    hal
    Veteran Member Four Rings rxer311's Avatar
    Dec 27 2009
    Nissan Rouge
    Mount Joy, Pa
    Sounds like a fuel pump issue to me. Maybe a fuel pressure regualtor. Did they tell you what the codes meant when they pulled them?
    I know that P0171 means that your o2 sensor before your cat is running lean so it could also just be an o2 sensor. If you really are running lean though...this could seriously reduce the longevity of your motor. (I had a P0171 code on my sti and it ended up being a tuning issue, but not likely with your audi...my subie was highly modded.)
    P0441 is most likely a gas cap.
    I think P0507 is a high idle code...most likely related to the P0171 code.
    If I helped you...Rep me!
    Dec 27 2009
    Nissan Rouge
    Mount Joy, Pa
    Did you ever figure this out?
    Dec 07 2008
    Harrisburg, PA
    Evaporative Emission
    (EVAP) Canister Purge
    Regulator Valve N80
    Senior Member Two Rings Grada89's Avatar
    May 04 2009
    B7 A4
    Ft.Lauderdale
    My car is in the shop right now for the same issue. I got a CEL also but they called me and told me that its most likely the purge valve. I'm glad i have extended warranty on my car becuase he said the repair might be somewhere in the thousands. I don't have much info yet as they're still diagnosing the car. But then again i never believe what they tell me.
    On the bright side they did give me a 2010 A4 with only 800 miles on the odometer. :) I still like my B7 more. jk. I'm lieing.
    Veteran Member Four Rings beantown's Avatar
    Jul 27 2009
    '15 S3
    Boston
    Quote Originally Posted by Grada89 View Post
    What did the dealership end up fixing?
    Veteran Member Four Rings shiro1745's Avatar
    Jul 26 2009
    DMV Area
    It would be a good ideea to keep this thread updated. This seems like an issue that anybody could have. I'm still CPO but if it really is a few thousand to fix I feel sorry for those out of warranty. I have the sense that these cars are not reliable at all. I almost regret sometimes that I bought this car. For so expensive car to have so many problems... F&$k
    Sep 18 2007
    nevada,vegas
    Quote Originally Posted by shiro1745 View Post
    This , my car is making me paranoid. I'm just thinking of the future and trying to be optimistic. Its hard to with all the stupid things these cars encounter. Especially with the rediculous part and labor charges. My friends a4 has way to many problems, not one of his windows works and that's the least of it.
    Veteran Member Three Rings IllusionalTA's Avatar
    Aug 16 2009
    06 A4 2.0T Sline M6
    Long island ny
    I Replaced my n80 cause it was bad and when I filled car up
    It wouldn't start.. Wtf.. Any update on the fix?
    Jun 27 2011
    Quote Originally Posted by IllusionalTA View Post
    Did you put it in backwards? Just replacing an N80 shouldn't cause a no-start issue. Look elsewhere for the cause...
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Aug 16 2009
    06 A4 2.0T Sline M6
    Long island ny
    Naa I'm chasing this p0441 code around, next Is the n115 I guess.. N80 was in fact bad btw..
    Jun 27 2011
    I got that. I actually replaced mine last weekend, I was just saying replacing it wouldn't cause the non-start issue, as even a broken one won't cause a non-start. Does your car crank, it just doesn't start?
    -CP
    2017 Q7 3.0t
    Veteran Member Four Rings 80sGuy's Avatar
    Oct 09 2007
    Miele S7
    You're saying that the dealer will charge thousand$ of dollars just to replace a $15 part??? Let's hope they give you more than just the N80 Purge Valve.
    2008 A4 2.0T | Dolphin Gray Metallic/Dk Gray | multitronic | Bluetooth | Dk Wood | Convenience. | Premium. | Sprt Susp. | Bare-bone 100% factory stock!
    Jun 27 2011
    Quote Originally Posted by 80sGuy View Post
    You're saying that the dealer will charge thousand$ of dollars just to replace a $15 part??? Let's just hope they give more than just the N80 Purge Valve.
    This. I swapped mine out in all of 20 minutes.
    -CP
    2017 Q7 3.0t
    Aug 16 2009
    06 A4 2.0T Sline M6
    Long island ny
    Just after filling up, I hate evap codes their nightmares.. Runs fine, just gotta find out why I'm still chucking this code
    Jul 19 2011
    Northern Minneapolis, MN
    yup, it's about the easier thing to do. Easier than changing an air filter!
    Back on topic, Will it crank over? I assume it will. And do you hear the LPFP prime when you open your door?
    Jun 27 2011
    I fell like there was a thread on here about this same issue but I can't find it. I think it had to do with the fuel tank level sender or the level equalizer thing that keeps the two sides of the tank equal. Haha, I'm not making much sense, hopefully you know what i mean.
    -CP
    2017 Q7 3.0t
