Two ways:
1) replace entire engine wiring harness (easy way but more expensive)
2) study wiring diagrams and rewire the connectors (time consuming but cheap and effective)
Reverse light switch should be in the Tiptronic shifter like you found. You'll then have to connect the wiring on the trans with the wiring in the console so the revers light will work.
The vehicle speed switch is one of the wires in the engine harness. You need to find the ECU pin-out and trace that back to the plug for your tiptronic trans. Then take the appropriate wires and put them into the appropriate plug for the 5spd trans (I think I might have that plug).
You will also need to recode your Engine's ECu and will need a log-in for the engine controller via VAG-Com (The real deal cable, not the ebay ones). Typically done by a dealership or a licensed repair facility.
You will also have to either a) wire in the clutch pedal switch for engine start or b) bypass the relay. I can show you how to bypass the relay. Took me 10mins after reading the wiring diagram.
On the right of this image you'll have a relay (says 395 on it). Remove that and jump terminals 3 and 5 as shown. This bypasses the starter interrupt (clutch pedal switch) and you'll be able to start the car with the key in the ignition and not pushing the clutch pedal in place.
Installed in ECU box.
ECU installed.
