Results 1 to 4 of 4
    Veteran Member Four Rings Audi S4 Turbo's Avatar
    Feb 11 2005
    E46 Bmw M3
    Encinitas,San Diego,California
    Quick ecu question/trying to pass smog
    I'm on my phone so I can't search (efficienty), as I know this has been asked and the answer is out there.
    I have a 2001 6 speed and my current set up failed smog. I am currently putting my car back to stock fueling and need to find out which ecu is compatible with my h box. I only have my hands on an m box and t box. Will either of those work JUST to pass smog? If not which ones will.
    -Justin
    EVT 700 997 Turbo 6MT
    TDI A3 Prestige
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    M box will work
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Feb 28 2007
    S4 Stage 3+
    Las Vegas
    m-box, but you as far as I knew you had to recode the cluster with vag-com. Do stage 3's typically pass smog in CA? I have to smog mine in a couple weeks. Do you think it's worth trying if I have cats?
    Apr 05 2007
    hey what's up justin - long time man how goes it?
    your sig says 'no cats' ** do you mean piggie pipes (only pre cats gutted - still has back cats) or do you literally have no cats? Also are you a 01.5 or pre? If u want to come up to Fullerton and you're 01.5 you can borrow my M-Box (your regional post was asking for H-box..so maybe you are pre 01.5) but thought I'd check to make sure.
    if u have cats you should pass even stage 3. Did you go for a loooong highway cruise and really 'blow her out' (Italian tune up) before pulling into the smog station?
