Originally Posted by
overjagi
Thanks NuVega, I have found here in audizine several pages with the A5 Coupe RoW Adaptation for new LEDs as:
http://www.audizine.com/forum/showth...=1#post9590889
Question now is if this is the same setup for the J lights (NA) than for the H (amber RoW lights)?
regards
Here is my car w/ the refresh LED tail lights I just added about a week or so ago. The harness I was sent was European spec:
https://www.youtube.com/watch?v=vsJw...ature=youtu.be
When I plugged in the Kufatec dongle, they worked but the reverse lights would blink with the turn signals. So I got the security code, went in and modified that, while in there I modified the lights too so that they would behave in part US, part RoW...as you see in the video, there are three LEDs tied into the brake light for the US spec lights, reason why you can't code them to work properly as RoW, so when I used the turn signals the very top part, like RoW, would blink except for those three LEDs, it just looked ghetto...so I modified the adaptation to where only the brake light lights up, not turn signal, and when I use the turn signal it would use the brake lights too, so no left out LEDs. The three LEDs that light up with the brake lights still looks weird, but I figure as long as it looks the same on both sides it'll be somewhat ok.
And to answer you question, I think you can make the RoW lights perform in the same manner as US, but not the other way around.
