Page 1 of 10 123 ... LastLast
Results 1 to 40 of 361
    Stage 2 Banner Advertiser Four Rings Arin@APR's Avatar
    Aug 23 2008
    Auburn, AL
    APR Stage II Exhaust Programming - Development Update with Dyno Results!
    Several days back APR showed the world a teaser of the new APR Performance RSC Turboback Exhaust Systems in both Dual Exit and Single Exit Configurations.
    The APR RSC Turboback Exhaust Systems were so free flowing the Engineers were able to make safe calibration changes which resulted in the following:
    1. Significantly reduced turbocharger spool time over both stock software and APR stage 1 software.
    On the days of testing, stage 1 torque levels at 2400 RPM's were met and exceded at 2000 RPM's (400 RPM's Sooner!) simply by running APR stage 2 software with the RSC Turboback Exhaust System
    2. Significantly increased and broadened the torque curve compared to both stock and APR stage 1 software.
    -On the days of testing, stage 2 torque levels rose 89 FT-LBS under the curve compared to stock software. Peak torque rose from 267 ft-lbs to 355 ft-lbs, for a 88 FT-LBS peak increase.
    -On the days of testing, stage 2 torque levels rose 66 FT-LBS under the curve compared to stage 1 software. Peak torque rose from 334 ft-lbs to 355 ft-lbs, for a 21 FT-LBS peak increase.
    3. Significantly increased horsepower, especially the area under the curve compared to both stock and APR stage 1 software.
    -On the days of testing, stage 2 torque levels rose 50 HP under the curve compared to stock software. Peak power rose from 212 hp to 248 hp, for a 36 hp peak increase.
    -On the days of testing, stage 2 torque levels rose 27 HP under the curve compared to stage 1 software. Peak power rose from 235 hp to 248 hp, for a 13 hp peak increase.
    All of our data was collected on back to back runs and are the results of average data. Data was also collected on the same car during several days of testing. Gains between runs were in some cases higher but we have chosen to show you an average of what you'll expect to see as data can change between runs based on countless variables.
    Now for the dyno charts of our development progress!
    APR Stage 2 ECU Upgrade with APR RSC Performance Turboback Exhaust System vs Stock ECU and Stock Exhaust.
    APR chose to represented at the crank with a modest 12% fixed Drivetrain loss. on a QUATTRO TIPTRONIC B8 A4. Click here to see All Wheel Tiptronic data.
    APR Stage 2 ECU Upgrade with APR RSC Performance Turboback Exhaust System vs Stock ECU and Stock Exhaust. (GAINS ONLY)
    APR Stage 2 ECU Upgrade with APR RSC Performance Turboback Exhaust System vs APR Stag 1 ECU Upgrade and Stock Exhaust.
    APR Stage 2 ECU Upgrade with APR RSC Performance Turboback Exhaust System vs APR Stag 1 ECU Upgrade and Stock Exhaust. (GAINS ONLY)
    This thread will be updated as development progresses.
    APR Stage II ECU Upgrade is a FREE Upgrade for APR Stage 1 Customers!
    Exhaust availability and pricing will be released in the near future.
    GoAPR.com | Facebook | YouTube | Twitter | Instagram
    Phone: (800) 680-7921 Local Phone: +1 (334) 502-5181 Fax: +1 (334) 502-5180
    Address: APR LLC, 4800 US HWY 280 West, Opelika, AL 36801
    Veteran Member Four Rings Ryan_T's Avatar
    May 11 2009
    09 A4 2.0T
    T.O - Canada
    Ryan - flickr
    Veteran Member Four Rings k9lovr's Avatar
    Aug 30 2009
    14 ML350 Bluetec, 17 MKVII
    Fredericksburg, VA
    Excuse my ignorance, but when you say all wheel horsepower and torque, do you mean at the wheel? So for the Stage 2 at the wheel hp would be 218? If incorrect please explain.
    [B]Current: Shopping now....
    Jul 11 2005
    04 Audi S4, 04 VW R32, etc....
    Auburn
    Quote Originally Posted by k9lovr View Post
    Jah, dis is correct.
    Registered User Four Rings Skyler@Achtuning's Avatar
    Feb 14 2007
    Redmond WA
    Wow, that is a huge low/midrange gain!
    May 11 2009
    09 A4 2.0T
    T.O - Canada
    So, do you have a a more jello-ed eta?
    Ryan - flickr
    Jul 11 2005
    Auburn
    Quote Originally Posted by Ryan_T View Post
    End of the month, first week of July'ish.
    Mar 05 2009
    Earth
    any idea on what the gains for the exhaust system by itself are? ....it's kind of hard to see what improvement the exhaust vs. software has on the overall improvement. Also, there are several of us that are already running 'equivalent' free flowing exhaust systems (HFC/test-pipe + exhaust) and would like to know what the software improvements are independent of the your exhaust or if it would be beneficial to swap to your exhaust system vs. the competition.
    May 11 2009
    09 A4 2.0T
    T.O - Canada
    ^ only one way to find out. Take the demo.
    Ryan - flickr
    Mar 05 2009
    Earth
    demo? I already have APR "stage 1.5" with an exhaust/HFC etc. ....the question is what gains being shown are APR exhaust only vs. just the software upgrade. I suppose I could do my own Dyno testing before/after the true Stage 2 but I figured APR might know already before I spent the money :)
    Aug 23 2008
    Auburn, AL
    Quote Originally Posted by cory_can View Post
    It was not possibly to accurately measure the gains of the exhaust system alone on stage 1 software. MED17, the engine management system, has control routines in place for controlling boost. When installing the exhaust only on the stage 1 software the turbo was spooling up so fast and overshooting boost so much the throttle plate was shutting. This further iterates the need to properly design software for the hardware you're running, especially if that hardware flows amazingly compared to stock.
    Software and Hardware must Mesh! We create both. You win.
    Mar 05 2009
    Earth
    Quote Originally Posted by Arin@APR View Post
    It was not possibly to accurately measure the gains of the exhaust system alone on stage 1 software. MED17, the engine management system, has control routines in place for controlling boost. When installing the exhaust only on the stage 1 software the turbo was spooling up so fast and overshooting boost so much the throttle plate was shutting. This further iterates the need to properly design software for the hardware you're running.
    makes sense....since the manufacturer of my exhaust system is an APR dealer I'm sure they'll do some of their own testing to check "compatibility". Regardless, I'm sure most decent exhaust systems are reducing turbo back pressure enough that your updated software will be beneficial
    Veteran Member Three Rings dirtysoil's Avatar
    May 23 2009
    23 Tiguan; 22 RS5; 18 SQ5
    Indpls, IN
    So is the Stage 2 file available now, or did I miss something????
    Jul 11 2005
    Auburn
    there is some debate regarding that in comparison to RSC though. Traditional exhaust systems use a lot of packing materials and baffles to control the sound volume and frequency. RSC allows for a "straight pipe" style exhaust with no baffles or very little packing material resulting in a lot more flow.
    For example, we have decided to offer a RSC exhaust for the B5 S4 simply because its hard to fit a large enough diameter traditional exhaust system on that car and the guys with 600+ hp really need extra flow. RSC allows for this with a diameter size that works for the B5 chassis.
    Jul 11 2005
    Auburn
    Quote Originally Posted by dirtysoil View Post
    Its heading towards the DPP server but its not officially available just yet. Give us some time for some final testing and to make all of the different ecu's available. I'm not sure how long that will take but 3 weeks seems a safe bet.
    Veteran Member Four Rings Nght&Day-B8's Avatar
    Aug 05 2009
    Miami, Fl
    This is honestly the best news ive heard all day. Arin, Keith.. you guys just made my day lol
    EDIT: the numbers shown is JUST with an exhaust and the new map correct.. No other supporting mods were on these cars? Also what was changed on the new file specifically, any advanced timing, raised boost, etc?
    Active Member Two Rings blrs25's Avatar
    Aug 27 2009
    Chicago
    Keith or Arin ** Can you speak to the difference in power numbers we might see from the single vs dual exit exhausts? I'm assuming it would be a negligible difference, if any, but always best to ask. Thanks.
    Audi A4 - Meteor Grey, Quattro, Tip, Prem Plus, sport pkg and B&O
    Current Mods: Llumar ATC 35% Tint around / APR Stage 1 / EuroCode Intercooler Pipe
    Mods to come: Something...
    Aug 23 2008
    Auburn, AL
    Quote Originally Posted by Nght&Day-B8 View Post
    EDIT: the numbers shown is JUST with an exhaust and the new map correct? No other supporting mods were on these cars?
    Vehicle:
    2010 B8 A4
    Engine:
    2.0 TFSI Valve Lift
    Drivetrain:
    Quattro
    Transmission:
    Tiptronic
    Fuel:
    93 (R+M)/2
    Mods:
    APR RSC Performance Dual Exit TBE
    Everything else stock. :)
    Aug 23 2008
    Auburn, AL
    Quote Originally Posted by blrs25 View Post
    They averaged about the same so none was seen as significantly more powerful than the other.
    Aug 05 2009
    Miami, Fl
    Vehicle:
    2010 B8 A4
    Engine:
    2.0 TFSI Valve Lift
    Drivetrain:
    Quattro
    Transmission:
    Tiptronic
    Fuel:
    93 (R+M)/2
    Mods:
    Beautiful, cant wait :) what was changed on the new file specifically if you dont mind me asking.. any advanced timing, raised boost, etc?
    Deactivated Four Rings Kay15's Avatar
    Jun 12 2009
    Audi A6
    Norway
    So do you guys at least know if it will be dual outlet single tips"? Or will it only be Quad and Single outlet Dual Tips?
    So how much will the upgrade cost someone who already has the stage 1.5?
    So the freer flowing exhaust kind of has a hiccup if not properly tuned. The new stage 2 ecu program will have the optimal performance? Wonder how much more power it will pull from the original, and yea I also am curious as to how much power the exhaust makes over stock, hmm...
    Aug 23 2008
    Auburn, AL
    To name a few:
    Boost control
    Boost levels
    Valve Lift Operation
    Ignition Timing
    Compensation Mapping
    Air Fuel Ratio
    Fuel delivery
    EGT Protection Mapping
    ETC..
    Essentially, a lot of stuff. :)
    Aug 23 2008
    Auburn, AL
    Quote Originally Posted by Kavan View Post
    So far Dual and Quad. We are working to see if we can offer a Dual exit Single tip but no ETA.
    Free
    So the freer flowing exhaust kind of has a hiccup if not properly tuned. The new stage 2 ecu fix will have the optimal performance?
    The Exhaust is too much for stage 1 tuning so you'll want our stage 2 software. This will also deliver optimal performance. :)
    Mar 02 2007
    Fresno, CA
    Quote Originally Posted by Keith@APR View Post
    Considering how long 2 weeks takes using the APR calendar we'll be lucky to see this released before the end of the year!
    Established Member Two Rings johntnethk's Avatar
    Aug 24 2009
    '09 A4 2.0t AWD, '11 G37S
    Can't wait to see someone with all the current "Stage II" mods + this software.
    If I remember correctly, another member dynoed a 245awhp / 260awtq with GIAC Stage I, AWE catback, and AWE FMIC, on 91 oct.
    Hoping a B8 with APR Stage II, HFC+catback / APR RSC, and an Eurocode / AWE FMIC could possibly push 260awhp / 275awtq on 91.
    APR Stg.1/EuroCode Quadtips/EuroCode HFC/KW V1/StaSiS RSB/VMR 710 19x8.5+Hankook EVO/OEM Black Optic Grill/OEM Blk Plate/OSIR CF Splitter/OSIR CF Valence/Rieger Spoiler/RS6 Steering Wheel
    Shipping: OSIR CF Side Sills, RS6 Pedals
    Aug 23 2008
    Auburn, AL
    We are putting down over 300 ft-lbs to all 4 wheels on a tiptronic with just the chip and exhaust so if someone has more mods, and APR tuning, they'll be WAY over 275 ft-lbs. :)
    Aug 24 2009
    Yikes.
    Quick question. Would the tip be able to safely handle this much power (since you're already putting out over 300 ft-lbs)?
    I'm running the APR 91oct Stage I software (229hp/332tq). Assuming the math is correct, Stage II + exhaust would be somewhere around 243hp/354tq on 91. With an FMIC, probably looking at somewhere around 260hp/370tq.
    A little worried because I read somewhere that our tip may only handle up to 340ft-lbs?
    Note: According to a friend of mine, the B8 tip is the exact same transmission as the one used in the C6 RS6, with the only difference being the torque converter (which if I remember correctly handles up to 620lb-tq). Could be an option for us tip owners.
    Account Terminated Four Rings
    Jul 04 2009
    2009 B8 Aruba Blue (discontiuned) 2.0T
    Would this benifit if the vehcile already has a test pipe in place, coupled with stock exhaust?
    Mar 02 2007
    Fresno, CA
    Quote Originally Posted by naemcivic View Post
    I think this is going to be a FAQ, along with whether this file can be run with a completely stock exhaust system and/or various components of competitor exhaust systems. Hopefully APR reps can comment.
    Veteran Member Four Rings DavidB8's Avatar
    Nov 06 2009
    Oakville, ON, Canada
    Well I think the exhaust is a portion of it. The CAT is going to play a large part. I just don't feel like piecing together cat from here and a pipe from there to get this all together. It would be nice for an all in one CAT and downpipe to be available.
    Reaching Me:Please don't ask me questions on the forum or send me private messages as it may be a while before I respond.
    If you need something email me directly at [email protected] I don't frequent this forum very often.
    www.audienthusiasts.com
    Oct 04 2009
    Macau
    Exhaust availability and pricing will be released in the near future.[/QUOTE]
    But my local dealer here said it's no way for free upgrade from Stage one to Stage two wo, can u confirm on it?
    Veteran Member Four Rings JetBlue's Avatar
    May 03 2004
    Carlsbad
    The answer to that is easy. Your milage will vary if you are not running this exact setup. APR has no idea how it will work since they did not design for it. The real answer is probably yes you will see more gains with stage 2 vs stage 1.5 while running an HFC or test pipe maybe more maybe less.
    "The American Republic will endure until the day Congress discovers that it can bribe the public with the public's money." Alexis de Tocqueville
    Aug 05 2009
    Miami, Fl
    A question i havnt seen asked.. Will there be different octane files or just a 93 octane? Im fine with 93, but i liked being able to run 100oct with meth injection.
    Quote Originally Posted by mikechan929 View Post
    Careful with that, some dealers will charge you a "labor fee" and say its not free for the new file, it honestly doesnt take over 10 mins to hook up a computer and upload a new file. Try calling other dealers.
    Sep 09 2009
    09 RDX
    Rhode Island
    Way to go APR! Now I need to start saving for all the new mods. Are you guys going to be at Waterfest with the exhaust?
    Jun 12 2009
    Audi A6
    Norway
    APR Stage 2 Upgrade Free.. I currently only have the 91 program I will most def be adding the 94 with the Stage 2 Upgrade when I go in.
    What I am trying to figure out some how is how much freer flowing air is coming out of this exhaust compared to the EuroCodes and AWE. Because I know alot of us have either a EuroCode or AWE exhaust, and I want to know how much of an impact that may have. So many questions this is worse then knowing your bdays coming up in a week and you already know what your parents got you!.. Gimmie Gimmie!
    Jul 17 2009
    Venezuela
    wow this makes me happy but a K04 or gt2871r should do this car justice
    May 11 2009
    09 A4 2.0T
    T.O - Canada
    If the selling dealer didn't want to honor the 'free' 10 minutes, what's the chance a completely new dealer will be willing to do it? As far as they're concerned, you're even more of a stranger.
    Ryan - flickr
    Aug 05 2009
    Miami, Fl
    Quote Originally Posted by leviathan18 View Post
    GT28
    Well, there is a local APR dealer in miami that will charge a "labor fee" when on the other hand Wolfcars Motorsports will do it for free... after all it is a free upgrade.
    Jul 04 2009
    As the days gone by, and now with this Stage 2 tune launch inching closer, I am thinking rather I need an FMIC upgrade? Because APR suggested their exhaust and tune to be paired up to be optimized. Upgraded FMIC is really needed or not? I am on a budget here for mods. I just want to know the order of mods. Exhaust+stage 2 first or FMIC?
    Active Member Two Rings SleeperA4's Avatar
    Nov 22 2009
    Sydney Australia
    In relation to some of the comments about the Stage II tune being necessary does this apply to both the turbo back and cat back options?
    2009 Ice Silver B8 A4 2.0 TFSI quattro
    7 speed s tronic - s line exterior package - s line interior package - sports suspension - RS 6 style 19" wheels - Sunroof - MMI with AMI
    Evolve Technik Tune - BMC Panel Filter - Invisible Car Bra - AWE Exhaust - EuroCode Intercooler Pipe - Rear lip spoiler - other bits and pieces.
