Results 1 to 19 of 19
    Jun 21 2009
    Topeka, KS
    W8 Swap is it possible
    So my 1.8T is in need of a re-build. Looking at several thousand for a re-build so was looking for motors to swap in and cam across a W8 motor local to me, that has everything, harness, ecu, alternator, starter ac compressor, etc. I researched online about the problems the motor has relating to the cam timing and sensors but what I'm wondering is would it fit and can it be made to work? I saw reference that the W8 chassis is basically an a6 Chassis. I searched around on here but found nothing on it. everyone is doing 4.2 swaps no W8. Thinking there is probably reasons for it but hey never hurts to ask right?
    -Will the harness/ecu swap into my car and still run the cluster ETC.
    -Will the motor bolt up to my quattro 5SPD trans
    -if the answer to above is no then how much hacking, splicing and or modifying would it take?
    Senior Member Three Rings PSU S4's Avatar
    Feb 03 2009
    2001.5 Imola RS4 Body 034 STK Avant 2001.5 S4 Nogaro Stage 3 Avant
    Philadelphia
    sounds like an awesome swap, plus fab work would be cool to see. if you do it start a build thread please
    Veteran Member Four Rings NeedingAnAudi's Avatar
    Mar 16 2009
    99.5 A4 4.2QM, 01 Nogaro RSFaux Avant, 15 Q7 TDI Sport Edition
    Valparaiso, IN
    It is possible, since the passat w8 is built on the same chassis. After I put a rod through the block I almost bought a wrecked passat to do this build, ended up not doing it and rebuild the 1.8. I wanted to be the first one to do it but if you have a cheap w8, I say go for it
    Brilliant Black 99.5 A4 Project V8
    Nogaro Blue 01.5 S4 B5 RSFaux
    Glacier White 15 Q7 TDI Sport Edition
    Poopoo Brown 80 5000s Diesel
    Audi R8 certified technician - PM for work local to Chicago/Northwest IN
    Alex
    Jun 21 2009
    Topeka, KS
    Guy wants 1500 for the motor. its got 65K miles on it.
    Senior Member Two Rings bmx_a4's Avatar
    Aug 19 2008
    Sheridan, WY
    That's a steal for that motor! Especially if it comes with all those accessories.
    2006 Jetta TDI
    2000 Brilliant Black S4
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    The swap shouldn't be that difficult since the A4 and Passat are virtually identical up front. The concerns I would have with the swap are directly related to the W8 being very rare, a pain to work on, and the lack of aftermarket or even factory support. If left stock or lightly modded (exhaust) it should be a very unique and somewhat reliable car. I would love to see it.
    Jim
    I Do Werk.
    Jun 21 2009
    Topeka, KS
    If i grabbed it i would leave it mostly stock. would make up a decent heat shield with intake and re-use most of my current 3" borla exhaust. and of course no cats. I'm also wondering how the gearing in my 1.8T transmission would work with this motor. another concern is emissions.
    Veteran Member Four Rings JEmm's Avatar
    Apr 27 2009
    Quote Originally Posted by sgt_g View Post
    I would consider swapping in an 01e or a 5 speed 2.8 trans for some longer gears.
    -Jeff
    May 16 2008
    South Texas
    Yes the W8 is possible.. But why? although unique it's proven to be a problematic engine (one reason why VW discontinued it after only 3 years of production). A 4.2 would yield better results in the end power wise.
    Jun 21 2009
    Topeka, KS
    why? well cause i can i guess. I'm always about different and doing things that no one else has done. the power it makes is what my power goals are with my a4 anyway. I'm going to research further into its issues for reliability and what not to see exactly what i would be getting into.
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Victor, this would be sick! You probably would need the whole front end stuff, like radiator etc, and probably an adapter for the transmission.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Mar 16 2009
    Valparaiso, IN
    See if you can get the 6 speed from the W8. That would be the way to go
    Alex
    Jun 21 2009
    Topeka, KS
    Quote Originally Posted by NeedingAnAudi View Post
    The W8 was never sold with a 6SPD in the US.
    Aug 13 2008
    Indiana
    It can be done. I want to see it because it would be sick. Also you need to get W8 winter wheels and quad tip exhaust =). Is it worth it? Not really from what I've heard the W8 isn't too great a motor. Although I really think it would be worth it for the uniqueness myself. If you just want some extra power and don't plan on any future modding then its probably worth a shot. I would look at a wiring diagram of the ECU's side by side to see if the cluster portion is the same. and depending on the year of your car the clusters having or not having LCD's could be but probably wont be a problem. Also you may very likely need to get a custom fly wheel. I say thats minor for what your getting but I think they use the same bell housing.
    Oh and you must get a W8 badge in place of the front quattro badge and just debadge the back.
    -Nic
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    One big step forward for you is that your 2001 A4 has Me7 management. w/o that it would be loco to do this. You can do the swap and be different or just buy a used transverse 1.8T (which are typicall healthier than ones from Passats/A4s) for $1000 or so.
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Mar 16 2009
    Valparaiso, IN
    Oh yes it was, I almost bought one. Look here
    http://cgi.ebay.com/ebaymotors/ws/eB...&category=6020
    Alex
    Mar 09 2004
    nw michigan.
    Why ditch the cats if you are worried about emissions? Just run a set of better aftermarket ones.
    Jim
    I Do Werk.
    Jun 21 2009
    Topeka, KS
    Sadly the motor that i was going to sell to fund this project turned out to have two broken valves. :( So i'm left with swapping around parts and making my 1.8T work. but going to at least pick up a ko4. :)
    Veteran Member Three Rings BlkBullitt's Avatar
    Feb 06 2009
    2007 Q7
    Cleveland, OH
    Quote Originally Posted by Scotty@Advanced View Post
    +1
    Not only is the W8 problematic, but also...
    1. There are little to no replacement parts available for them when they do go bad
    2. There is little to no aftermarket support for them since they were produced in such limited numbers
    3. They have little to no performance aftermarket
    More people would probably look into them if they were more solid and didn't cost an arm and a leg to get parts to fix them when they do have problems. I'm all about the idea of a unique swap, but honestly unless you like the idea of having a sweet W8 swapped A4 that doesn't run and basically requires you to buy a new W8 engine when/if the one you put in has issues you're really better off staying away from them.
    2002 Audi S4 Brilliant Black Avant 6MT[/b]
    B5 A4 / S4 Headlight and HID Thread | B5 A4 / S4 Center Console Thread
