Results 1 to 11 of 11
    Veteran Member Three Rings Larson7.62's Avatar
    May 22 2008
    2008 Audi A4
    Bellevue, WA
    CC help (updated question!)
    I finally got an extension for my ratchet that will fit through the hole to get the third screw for the headlight, but now any torx bits have a connector that won't fit through. What do you guys use? Where did you get it? I've checked out sears and a couple automotive stores.
    Brilliant Black 2008 Audi A4 6MT S-Line/APR Tuned/Carbonio Intake
    Veteran Member Three Rings clemsongt's Avatar
    Mar 09 2009
    05.5 A4 2.0TMT RIP: 88 MX6 GT
    Irmo, SC
    Get a very long 3/32" (I think that's right...might need to verify...) straight blade screw driver. I got a Kobalt one from lowes, so I know they carry one.
    HTH
    EDIT: As stated below 3/16" is the correct size for the screwdriver.
    Disclaimer: In no way shape or form is the comment above representative of an automotive expert. It is merely the understanding and/or opinion of an automotive enthusiast, and as such, the knowledge he/she possesses may or may not actually be the truth.
    Established Member Two Rings cheesefan's Avatar
    Nov 17 2009
    Kensingon, MD
    If you get just a torx bit, you can put 1 layer of duct tape around it and stick it into a 1/4" socket. That's what I had to do.
    Veteran Member Four Rings xULx's Avatar
    Jan 20 2010
    07 Brilliant Black A4
    San Diego
    yep that screw sucks. Took me a few hours to get one of them out.
    -Jesse
    Veteran Member Four Rings arce909's Avatar
    Oct 08 2008
    So-Cal
    I use a long flat head screw driver.... I works great!!!... I'll check what size & let u know....
    Established Member Two Rings 6speed4u's Avatar
    Oct 20 2009
    06 A4 2.0T, 07 A3 S-LIne
    Orlando, Fl
    2 things real quick.... 1, that screw doesnt have to come all the way out, just loosen it 3-4 turns. 2, use a smaller (2") extension and finagel it behind then plug it into you longer extension shooting through the hole. Ive had mine off about 4 times lately and its becomming easier every time I do it.. hope that helped
    06 A4, 2.0 T, MT, APR Stage 1, APR Exhaust, RS4 Rear Sway bar, VMR Test Pipe and vent pod Boost gage, 10% tint, CC, Rev D DV
    07 A3 S-Line DSG, 20% Tint, wife's...............
    May 22 2008
    2008 Audi A4
    Bellevue, WA
    Bought a 3/16" screwdriver, we'll see if that works. It was the only one there that looked like it might fit.
    DUH! an Audi
    los angeles, CA
    before I made my tool, I used a long extension with the bit at the end and it worked.
    May 22 2008
    2008 Audi A4
    Bellevue, WA
    Done with the CC, but I have a problem. The drivers side headlight rear upper corner is not up against the fender. Also, it seems like the bumper won't go back on. Any advice?
    Oct 16 2008
    South Florida - Ft Lauderdale
    Quote Originally Posted by Larson7.62 View Post
    Give a bit more gap to the 2 center posts. Once the bumper is back in place, the headlight will align
    Phil
    May 22 2008
    2008 Audi A4
    Bellevue, WA
    Thanks phil, got it back on. I think I may have accidentally touched the height adjustment posts, so I had to spend some time messing with those. I'll try to get some pics tomorrow. I tried the "bumping" method, and ended up breaking the two tabs, and the cap didn't even come out. So I took your advice from the DIY, and it worked perfectly. Looks so much better, now I just got to get some color matched sidemarkers.
