Results 1 to 40 of 1094
    Jan 20 2010
    Texas
    Quote Originally Posted by Kandiru View Post
    Will be navigating and watching DVDs among other things. Will post after i get her done.
    Does this adapter provide for a video signal as well? If not, are you intending to use an XCarLink for the video? More info, please. This sounds interesting.
    Installed: Grocery Hooks, BLESK Plate bulbs, iPhone Extension, VAG-Com, Luminics JDM Yellow Fogs, Chrome Grille Inserts, Rear 12v power, Underseat Storage, Folding Side Mirrors, B&O Tweeters, E-Codes with BLESK 5000K, Audi Hill Hold, S-Line Rear Bumper, Warning Triangle, DIS Stalk, Full-Function Rear Power Locks, ADS, Mirror with Compass, Q5 Wheels
    Veteran Member Three Rings Kandiru's Avatar
    Mar 28 2010
    Isolation, OH
    Quote Originally Posted by TexasEric View Post
    The above adapter will solely input purely digital sweet undistiorted (albeit compressed, oh sweet SACDs) sound, i will splice an old high quality RGB cable to link video like this:
    Mini-DVI to HMDI adapter > ViewHD VHD-H2YVs (5v will get it from the Carnetix)> RGB to Xcarlink inputs.
    This way i will have an extra HDMI port which i will extend with a male-female cable for that PlayStation or
    whatever we need.
    Wish me luck, at least the ViewHD is highly rated on Amazon and i doubt it will fail me.
    http://www.amazon.com/ViewHD-Compone...6479943&sr=1-5
    Sxxx, with so much hardware i will be scratching my head to find locations for all components as i also have
    a long range N wireless adapter i plan sticking into the center vent side by side with the GPS antenna.
    I promised myself to keep it custom, with everything recessed in the dash (AMI and BT adapter will be hidden), and
    the Mac Mini painted black in the single-DIN
    slot along with the extra HDMI, USB port extension from Mac, and another USB from the Carnetix PSU (to allow
    me tweaking the PSU with my Windows laptop via PowerMoni) neatly tucked in the little space to the right of the Mini,
    fyi the fat Mac Mini (03-10 2009) is 6.5x6.5x2", all sorts of neat delays, and even battery
    voltage based shutoffs can be programmed. A 5v fan will blow air into the glovebox via the holes at back of the shelf.
    Right now i need to wait for everything to arrive, the rear cam install will be done with the Bosch ParkPilot acoustic parking,
    just have an awful time finding Audi 0C0C paint to cover the sensors.
    Unfortunately chronic insomnia with my job is a problem, but i promised myself to drive around with glovebox off if i have to,
    i have not once botched installs d/t fatigue and desire to finish quickly.
    Hey gurus, can i start the Xcarlink with this button mounted behing the E-Brake button, it is so cool and matching, i will use
    it for the Mac Mini with the Y splicer to start it, the PSU will turn it off delayed after ignition off :
    http://www.amazon.com/gp/product/B00...=A9WD26COETCRX
    2012 S4 6MT Monsoon/Silver-Alc./Diff+B&O+airbags, Mods:R8 V10 St.Wheel, JHM Shifter, Summer: S5 Double Spokes 8T0601025H - Bridgestone RE-11 245/35R19 (ET32), Winter: Hollow Spokes 8K00714994EE - Dunlop 255/35R19 with BFI-5mm-Fr+10mm-Rear & RAD 35mm bolts/locks, Customcargrills upper/lower/L-fog radiators protection, Oil Dipstick, RS4 pedals x4 & Autovation Heel Guard, Seat Bins, Trunk Triangle, Laminx fronts+fogs+edges+bumper, Windesa Sonniboy 8K Curtains
