Results 1 to 21 of 21
Thread: Perfect
    Veteran Member Four Rings Tanner's Avatar
    '10 S4 / '13 BRZ / '16 Cayman GT4
    Markham, ON
    Perfect
    Well not the actual car sitting in the garage LOL. Finally got around to hanging it up this past weekend ... thanks goes out to afretes for getting us these posters!
    Mike
    Veteran Member Four Rings bunnn's Avatar
    Jan 24 2006
    e92
    Garage is looking cleannn..needs a a lift
    Cheers!
    ~Ben
    Jun 21 2005
    Oakville, Ontario
    Nice, did you plaque the poster?
    Steve
    2005 A4 Avant 1.8T Quattro MT
    Comp Turbo Billet T3/T4 4756 SPA clone manifold Turbosmart ultragate Forge 007 DV 034 SPA 3" downpipe, B6 S4 exhaust AEB head & intake manifold EV14 750cc @ 4bar Snow Performance Meth injection Eurodyne Maestro Bilstein PSS9 OZ ultraleggera matte bronze w/Conti Extreme Contact Sport B5 S4 front brakes 034 street density engine mounts JHM B7 RS4 LWFW + clutch
    Markham, ON
    Got it done at Costco.
    Mike
    Veteran Member Three Rings Tomek6's Avatar
    Dec 29 2006
    2005 A4 USP 6spd
    Looks good
    2005 Audi A4 USP 6spd |Revo Chip|TT 225 Injectors|Evo MS Intake w/ modified stock ram air|Samco Hoses|Forge TIP|Forge DV|VMR TP|Custom SS 2.5" Magnaflow Exhaust|ECS Snub Mount|KW V2 Coilovers|Hotchkis S4 Sways|BBS CH's|3.0 C/D, Slotted Rotors|USP Front, Rear Spoiler and Interior Trim|Cupra R Lip|B7 Rear Valance|DTH Sideskirts|Grilles|E-Codes|S4 Mirrors and Door Blades|S/w Boost Guage w/ Podi Steering Column Pod|
    Veteran Member Four Rings Siggiepop's Avatar
    Aug 20 2007
    B6 A4 . Bus Pass
    Ontario, Canada
    you suffer from OCD too!
    Veteran Member Four Rings NOTORIOUS VR's Avatar
    Jan 29 2009
    not enough crap in your garage lol
    Jun 21 2005
    Oakville, Ontario
    Quote Originally Posted by Tanner View Post
    What if I have an old poster but it has some wrinkles in it...will it still turn out nicely if I take it to Costco to get it plaqued?
    Steve
    Veteran Member Four Rings CONTROL ONE's Avatar
    Sep 19 2008
    2014 BMW M235i 6MT, 2010 Audi S4 6MT
    Toronto, Canada
    How much for plaquing?
    Also, nice finish on the garage floor. What product did you use? My garage floor CREATES dust, it's insane.
    Markham, ON
    Quote Originally Posted by SleeperAvant View Post
    I think you'll still see the wrinkles to some degree, it won't be perfect of course.
    Quote Originally Posted by CONTROL ONE View Post
    How much for plaquing? Also, nice finish on the garage floor. What product did you use? My garage floor CREATES dust, it's insane.
    I think it might have been $60ish for the plaquing, if you give the dimensions to Costco they can probably give you the price over the phone.
    Garage floor - Palgard epoxy (industrial strength) from Pratt & Lambert. Given that's intended for industrial only select stores that carry Pratt & Lambert can bring it in due to licensing from what I learned from RippleChip as he just did his garage floor. Summit Paints up in Aurora (15480 Bayview) carries this stuff. Not cheap..... $90 for the base and another $90 for the activator. Yeah, get it sealed, no more dust, much easier to clean. I have some areas that needs some repair as the epoxy doesn't stick well to the compound I used for repairing the cement in a couple spots.
    Mike
    Veteran Member Three Rings Tamas's Avatar
    Jul 27 2009
    '05 allroad 2.7t 6MT, APR Stage I
    Toronto Ontario Canada -eh?
    Quote Originally Posted by Siggiepop View Post
    Actually if you are truly OCD then it would be "CDO" <- it has to be in alphabetical order after all
    Markham, ON
    Heh, if I was truly OCD, my garage would be MUCH more tidier. You just don't see the crap sitting along the wall behind the car :D
    Mike
    Aug 20 2007
    B6 A4 . Bus Pass
    Ontario, Canada
    haha good stuff
    Sep 19 2008
    Toronto, Canada
    thanks for the info. I wonder how the stuff at CT and HD would compare. As it's a rental house we are in, don't exactly want to spend a fortune on it.
    Markham, ON
    The cheaper stuff might be sufficient. The key is prep work. Don't skip things or rush things, it'll just be wasted effort as the paint will begin to peel off after the next winter.
    Mike
    GTA, Canada
    There are cheaper ones out there, but this really isn't far off. The cheaper kits run from 80-120 for a gallon, short filled with a quart of activator that you mix in to give you the full gallon. The Palgard is 1 to 1, so you end up with 2 gallons, coming in around 90 a gallon.
    In a rental home its worth going the easy route and picking up something from a local CT or HD. Some of them get pretty reasonable reviews, others crap, so do a little research. Spend the time on prep and it will help to prolong the life, just painting it down on the current floor will be a waste.
    Having just finished mine I will say it is totally worth it, cleaned up the garage very nicely. I haven't got pictures yet, but it is still pristine as I haven't brought the car in on it yet. I'll have to get some before i start dragging the dirt from the neighbourhood in.
    Steve if you are interested in a poster let me know, I got a couple and can spare one for you. I can bring it to the next ride.
    RippleChip (Ryan) - Moderator
    Audizine
    01.5 eh4 1.8T || 12 eh5 2.0T
    Markham, ON
    When I was doing some research around this, it appears that the floor paint from Rustoleum is a good alternative. Again, not sure what the price is for this and how it compares to P&L's Palgard. The place that I bought the P&L paint in the past, they also sold the Rustoleum but they did say that the Palgard is much more effective for industrial use, so Rustoleum might be good enough for home use. The Behr stuff didn't get a lot of good reviews, so stay away from that.
    Mike
    Veteran Member Three Rings ducati's Avatar
    Sep 02 2008
    Greater Toronto Area
    Tanner those are 18' or 19" rims..Hyper silver?....
    Markham, ON
    18" hypers from simplytire.
    Mike
    Sep 16 2015
    Cluj-Napoca
    Nice design and tidy. I wish my garage looked like that. :D
    _______________________________________________
    Marius from Agro
    Veteran Member Four Rings afretes's Avatar
    Jun 23 2005
    '19 S5 SB - '15 A3 - '05 Subaru WRX
    Caledon, Canada
    Wow, 2010 Mike!!
    Alex Fretes
    Fleet Manager - ABS
    E-mail: afretes@audibrampton.com - Tel: 647-984-2834
