Hi Gents,
Just wondering if the turbo gurus on this forum would mind sharing their knowledge with regards to what compressor wheels the OEM RS6 k04 housings can be modified to fit?
As far as I know the largest possible is the 59.5mm billet wheel known as the 8868?
The reason I am asking is I live in the other side of the world and I would like to look into getting a local turbo shop here to rebuild my standard turbos along with other modification, with regards to the other modification I am thinking:
- Clearances turbine housing around turbine wheel.
- Clearanced wastegate and increasing the wastegate flapp
- Upgrading the actuator to 0.8bar base pressure.
- Back cut the turbine wheel
Basically I am looking at building the most performance orientated turbo I can posible while retaining the OEM housings as i have looked into upgrading to GT's or some thing bigger and this requires nothing short of converting the car to manual along with other modifications. And yes this is for a genuine C5 RS6.
I look forward to anyones input and I appreciate you help in advance.
