Results 1 to 40 of 61
    Oct 10 2004
    05 b6 usp, 99 ml 430, some trucks
    NW Missouri
    How to increase boost?
    I have wondered for some time why us Audi guys have so much trouble making tons of power out of our 1.8t. I've looked at a lot of dyno's from several evo's and they tend to make about the same power as we do (+/-30whp) when matched up with the same turbo. The difference is the evo crowd is really turning up the boost. Most of the audi's I see are running between 21 and 23psi max. Many in the evo crowd like the Garrett GT35r to make the big power. This turbo will also make a ton of boost. Several on the evo scene are cranking them up to 30 35 even 40psi with upgrades internals. They are making 700whp and still streetable, they just turn the boost down to 12-16psi. If I were were to build up the internals on the 1.8t to withstand high boost, how do we adjust it? I always heard you can't use a EBC/MBC. Can you use something like Apr's ECU explorer to change the boost and timing. If I wanted to crank the boost to 36psi, how would you do it?
    Veteran Member Four Rings nadroj81's Avatar
    Feb 12 2004
    Albany
    the make a lot of power with the gt35r but also have larger displacement engines.
    I belevie one of the problems is our ecu's are too smart. The injectors will cut off gas feed, or something like that, and cause the engine to blow. too high air to fuel ratio.
    MOrgie has a large turbo, not sure what kind of power he is putting down.
    also, i bet thier 700hp cars only have that in the very high rpms.
    Registered Member Four Rings
    Mar 05 2004
    2003 Audi A4 1.8TQM
    Calgary
    700whp is pretty much just a dream for 1.8T. The best I heard was 450chp. At 36psi, you neeeeed very strong everything.
    Orange County, CA
    i know you mentioned an upgraded turbo, but if you plan on cranking the k03 to 36psi plan on it exploding. a k03 cannot handle that, its a tiny turbo.
    B5 Parts For Sale
    Oct 10 2004
    NW Missouri
    If I remember right the evo was hitting the 700 mark at a little over 7000 rpm's. They really aren't a high rev engine like a honda. Displacement is only 2.0liters, with the gt35r the lag is pretty bad coming on around 1200 rpms later then stock. We can stroke ours to 2.0liters.
    The highest horsepower I remember a 1.8t hitting was 490whp at the 1.8t challege by Wide Open Motorsports. Atp is hitting 420whp with stock internals with a Garrett gt30xx in a b5 A4 quattro. They just ran a 11.9x through the 1/4 with no nos.
    Oct 10 2004
    NW Missouri
    36psi on the ko3 with a squirt of nos Might as well let it scream for mercy. I plan to install apr's stage 3+ along with some upgraded cams and a port and polish on the head. If the funds come together I would like to put in some dahlback racing connecting rods and pistons. They are rated for 900whp and 9000+rpms. That should do the trick. I figure I have at least two to five years to save my pennies til apr releases the 3+ setup. Til then I will just abuse my ko3.
    Registered Member Three Rings BOOST3D's Avatar
    Jan 22 2005
    2005 1.8T Ultra Sport
    hey B6 USP... you stated.. Atp is hitting 420whp with stock internals with a Garrett gt30xx in a b5 A4 quattro. They just ran a 11.9x through the 1/4 with no nos.
    Any link to .. see the story.. or see what they have into the motor.. woudl love.. to bring mine.. close to 350.... and dotn wanna do any internal work...
    Thanks....
    Oct 10 2004
    NW Missouri
    Sorry I still don't know how to link. You can go to atpturbo.com and look for project 1.8t. Just checked they put down 426whp and 430lbs tq. 1/4 was 11.97 The car is really pretty stock. No cams or headwork at all. It has a upgraded clutch, 3" exhaust, fmic, bigger injectors, and custom tuning software for the big turbo. Be sure to click on "more info" they chart the progress with all the upgrades along the way. Its pretty interesting.
    Veteran Member Four Rings FINA4's Avatar
    Jun 15 2004
    2010 Audi S4, 2010 Mazda5
    Tampere, Finland
    You can just copy paste the URL from another site. This forum will automatically parse it to be a link.
    | 2010 Audi S4
    | Phantom Black Pearl Effect
    | 6-Speed Manual
    | Navigation w/ Camera
    | Bang & Olufsen Sound System
    | 19" Tri-Spoke Wheels
    | Front Plate Filler Panel
    | Solar Gard Ultra Performance Tint
    | STāSIS ECU Tune
    "There's nothing worse than an ordinary life"
    Feb 12 2004
    Albany
    they do thier own software tuning?
    Established Member Four Rings HighPSI's Avatar
    Jun 30 2004
    DC
    your never gonna get a k03 to boost 36lbs or a k04, plus even on a k04 its all hot air after 25lbs anyway
    Veteran Member Four Rings sliverwagon's Avatar
    Feb 06 2005
    EAI Bareknuckle
    Shawnee on Delaware
    this is pretty impresive from what I've seen...
    http://www.atpturbo.com/root/releases/release050304.htm
    Oct 10 2004
    NW Missouri
    Hey guys just kidding on the ko3 hitting 36psi. FINA4, that for the tip on linking. I'll have to give it a try.
    Nadroj81, ATP does do their own tuning, but from what I understand its really not one of their strong suits. You can do much better with Upsolute or Revo BT.
    Feb 12 2004
    Albany
    Hopefully revo willl finalize a BT program.
    Should be interesting if they can tune something larger than the gt28, considering other companies are having trouble...
    Veteran Member Four Rings Awadd9's Avatar
    Oct 04 2004
    North Jersey
    Re: How to increase boost?
    I smell a 5-cyl turbo swap..
    Active Member Two Rings audisick99's Avatar
    Nov 16 2015
    Long island, NY
    Firstly i would advise against trying to run 36 psi on stock ko3 and internals. if you have a gt35r 36 psi is achievable with fuel mapping and ignition timing tuning. I recently found something on ecstuning.com for increasing boost on stock ko3 and im considering buying. I have to do a little more research before i buy it and i was wondering if anybody had any experience with this product. It is a Forge KO3 Adjustable Wastegate Actuator. link: https://www.ecstuning.com/b-forge-pa...FUVYDQodbA0AXA let me know what you think of the product. Thanks
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by audisick99 View Post
    2020 SQ7- Wife's ride
    2008 RS4- I like this car
    2000 S4- Working?
    Dec 30 2014
    Nogaro 2000 S4 6-Speed, Ebony Pearl 2002 A4 5-Speed
    South Carolina
    36 psi isn't necessary to make a lot of power, high 20's will get you in the 400+ range just fine.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by KHARDa4 View Post
    2000 S4- Working?
    Veteran Member Four Rings Wet0willy01's Avatar
    Nov 17 2008
    05 A4 USP, 00 S4, 01 A4, 16 A3
    Shit. I'm doing it wrong.
    -Andrew
    2005 Dolphin Grey Ultra Sport
    630AWHP HTA3582R 1.8L 93+ Meth
    Before camber and tire stretch, there was horsepower and performance.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by Wet0willy01 View Post
    2000 S4- Working?
    Veteran Member Four Rings MCT9891's Avatar
    Jul 06 2009
    2008 VW Jetta Wolfsburg 2.0T 6DSG
    Staten Island, NY
    Your first mistake is comparing a 170 hp luxury car to a 300 hp rally car for the road...
    I've owned a BT b7 a4 (granted, they're restricted by rs4 injectors) and a BT 450 awhp Evo X (stock motor) and I can tell you right now, the difference in motors are HUGE. Making good power in the Evo is 20x easier than the Audi.
    Audi didn't build this motor with high performance in mind, whereas mitsubishi made that it's number 1 priority.
    Also, the 4g63 has been around for over 30 years. 24 of those in Evo's. That's a lot of time for a motor to become "tried and true"
    Lots more time, effort, research, and money have gone into those motors than Audi's 1.8T's.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by MCT9891 View Post
    Audi didn't build this motor with high performance in mind, whereas when mitsubishi made that it's number 1 priority.
    2000 S4- Working?
    Jun 08 2008
    Calgary AB Canada
    11 year old thread bump lols
    2011 Audi A4 Avant // quattro // Garnet Red
    Stock. For now...
    1989 Porsche Carrera 4 // 5 Speed // Guards Red
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by onceover View Post
    2000 S4- Working?
    Jul 06 2009
    Staten Island, NY
    WOW lmao... just realized that. fail.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    2000 S4- Working?
    Jul 06 2009
    Staten Island, NY
    Quote Originally Posted by redline380 View Post
    keep it going lmao
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    Changing the wastegate without adjusting the tune to compensate for the adjusted wastegate pressure will result in overboost conditions and limp mode.
    Rather than changing the wastegate, why not get a tune? Youll get more than double the stock boost pressure and safely make an extra 30-50HP.
    2019 SQ5 Prestige
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    keep it going lmao
    - - - Updated - - -
    Quote Originally Posted by texasboy21 View Post
    2000 S4- Working?
    Jul 06 2009
    Staten Island, NY
    " MCT9891 likes this"
    Dec 30 2014
    South Carolina
    At 22 psi right now close to 400. Once the big port head with return fuel goes on 28 psi I should break 400 easy..
    Jul 06 2009
    Staten Island, NY
    Literally busted out laughing when I saw the update
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    2000 S4- Working?
    Dec 30 2014
    South Carolina
    Kids these days.. Sheesh.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    2000 S4- Working?
    Dec 05 2007
    Rumor going around there was a necro-bump going on. Rumor was true!
    Veteran Member Four Rings blitz2190's Avatar
    Jul 31 2014
    2004 A4 1.8T Quattro, 2.7T swap Stage 3 APR 6 speed
    NH
    Never argue with an idiot, they'll bring you down to their level and beat you with experience.
    2.7T Swap Wiring Guide (Psst this is a link)
    New Build In progress built 2.7 STK 2004 B6 A4- Thread and pic to come
    Jun 27 2011
    #becuzposterischeapanddumb
    I run 40psi on my stock b7 with a k03. Not sure what all you haters are on about! I beat Evo's with NOS all the time!
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Hell that's nothing Chucky. I run nitromethane with my frankenturbo. Crank the boost up to 45 pounds and kick the s*** out of all those GTR's.
