Results 1 to 35 of 35
    Jan 11 2010
    VILLA RICA GA
    can you trick you egt sensor with a resistor or bypass
    my driverside egt is blown and i need to replace it. I was wondering if you can put a resistor on the harness to trick the ecu or if you can splice the driver side egt into the passenger to bypass the driver side egt? any help is appreicated. also can you use a passenger egt to replace the driverside ecu, is it long enough to work?
    Veteran Member Four Rings s2the4's Avatar
    Nov 02 2006
    01 Stage 3 S4 Silvaro, 01 S4 Avant Nogaro
    Western Mass
    Quote Originally Posted by onearun View Post
    Stop right there if it is broken you should fix it and not half ass it. It will only give you more headaches down the road.
    |MRC-Tuned Stage 3| | RS4 K04 Turbos | | RS4 Y-Pipe | | RS4 Airbox | | RS4 Fuel Pump | | 60lb Siemens injectors | | ER SMIC | | APR Bi-Pipe | | All JHM Goodies | Vogtland GT | | Porsche 993 TT Brakes | | 034 Motor & Trans Mounts|
    ...For now
    417whp @ KTR Ayer, MA 110 octane with open dumps
    clicky
    Jan 11 2010
    VILLA RICA GA
    i just wondering why more people dont try to bypass them. i mean they are more or less like a switch from what i am reading. and they are like 250 plus.
    Jan 29 2007
    08 S4 00 S4
    MD
    If there was a way to do it like this, someone would have discovered and documented it over the past 10+ years this car has been around. They need to be properly written out of the software on the ECU or replaced when they fail, period.
    08 S4- Stock SOLD
    Jan 11 2010
    VILLA RICA GA
    just wondering did not find anything searching, but i did find a guy that did connected one egt to the other to bypass it and said it work with out cel. so just wanted to see if others have tryed it. also it does not really matter how long the car has been around there is always room to innovate new products and procedures. but thanks for the advice. only owned my s4 for couple of months.
    Jan 29 2007
    08 S4 00 S4
    MD
    The only innovation that has come along and will ever come along in the way of these sensors is to code them out via a tune. Same with rear O2 sensors. It needs to be taken out through the software, not in the wiring. EGT sensors are very sensitive to signal inputs and you will throw a code if you try to fool the ECU through the wiring path.
    08 S4- Stock SOLD
    Jan 11 2010
    VILLA RICA GA
    thanks for the heads up that is what i wanted to hear(not really but some things you cant fight). will not mess with them and instead buy a new one. will a passenger side egt be long enough for a replacement for the driverside egt or does it only work the other way around
    Jan 29 2007
    08 S4 00 S4
    MD
    Depending on the year of your car, both sensors could be the same. They mount and are keyed/routed differently after a certain production date, but plenty of people have used them on either side.
    08 S4- Stock SOLD
    Apr 11 2008
    00 s4 90 crx
    High Point, NC
    ^^^That man knows his egt's so id definitely listen to what he has to say!
    2000 Brilliant Black S4
    -DNA Catback, Piggies, Darintake w/ITG panel filter, 710n's, 034 TBB, 034 F hose, Vast clutch, JHM shifter & bushings, Vogtland/Koni's, Hotchkis Sways, ECS 12.5mm spacers
    2010 Honda Civic Ex Sport Auto
    -Stock daily driver/panty dropper
    2014 Fiat 500 Sport
    -Stock cone dodger for now. Suspension coming soon.
    Jan 11 2010
    VILLA RICA GA
    its a 2001.5. are they interchangeable. 6speed
    Jan 29 2007
    08 S4 00 S4
    MD
    08 S4- Stock SOLD
    Jan 11 2010
    VILLA RICA GA
    i read that already but dont know about the length it they both will reach?
    Jan 29 2007
    08 S4 00 S4
    MD
    They are piggy backed for your year, so they should reach either side fine.
    08 S4- Stock SOLD
    Senior Member Three Rings S4NORICE's Avatar
    Dec 10 2008
    2001.5 S4, Factory Five MKIII
    Clifton Park, NY
    Someone on AW actually did try the whole resister thing a while back. From what I read, it looked like way more of a hassle then just replacing the damn things. Yeah, they're expensive, but do you really want to make a rats nest of wiring inside you engine compartment? Not to mention spend hours and hours to get the damn things to send the right signal back to the ECU? Don't do it man, just replace them.
    You can get away with used ones, but it probably won't be long before they fail as well. Last I checked, they go for around $100 used in the classifieds. Back when mine were bad, I just coughed up the dough for brand new ones cause I didn't want to spend 200 on used and have them fail a month later. Knowing my luck, that's exactly what would've happened... In the end you'll be happy that you did it the right way, and chances you won't ever need to replace them again.
    Veteran Member Three Rings VinNyS4's Avatar
    Nov 07 2007
    New York City
    I have the same problem dirivers side egt, is you car throwing a code for it? and do you feel any difference in performance?
    10 b8 s4 6MT sprint blue / black & silver
    Dec 10 2008
    Clifton Park, NY
    Quote Originally Posted by VinNyS4 View Post
    My drivers side was bad and it was throwing a code, but I never got a CEL. I think it takes both of them to fail to throw a CEL, but I'm not really sure. Mine was somewhat intermittent, sometimes it'd be fine, and other times (hot days mostly) it'd act up and throw me in limp cutting boost down to 5psi or so. So yeah, I definitely felt a difference in performance when it was acting up.
    Oct 30 2006
    B8 A4 Avant 6spd
    Quote Originally Posted by mholme View Post
    Yup, they're coded out on my car =D.
    -18 718 GTS
    Oct 30 2006
    B8 A4 Avant 6spd
    The boost becomes choppy and inconsistent, that and the car doesn't pull as hard. Its very noticeable.
    -18 718 GTS
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by S4NORICE View Post
    Exactly. And I don't think the guy on audiworld was ever successful in his attempted hack, but it has been tried. Same with the guy who tried to fool the O2 sensors. That somehow made it to a tech article even though everyone who tried it, it didn't work.
    08 S4- Stock SOLD
    Jan 11 2010
    VILLA RICA GA
    yeah i have inconsistant boost, and if feels really rough at part throttle like crusing and boosting right about 0psi, it feels better at night when it is cooler. but i have a hard time reaching 17psi it only goes to 13-14. and feels like its pulling timing. i have check twice for boost leaks. and i keep getting a code for the driver egt intermitingly going bad.
    Dec 10 2008
    Clifton Park, NY
    Yeah, its toast man. If you decide to buy new ones, genuinevwaudiparts is the cheapest you'll find. I think they only sell the in pairs though. This is the part number 078998124B, it includes both of them.
    Veteran Member Three Rings M.S4's Avatar
    Mar 04 2008
    '11 S4
    MN
    You can connect the signal wires on the two connectors, and plug in the good egt.
    Mine are coded out but for awhile I got a file without the EGT delete.
    GL
    EPL Stage 3 with a bunch of other crap.
    Veteran Member Four Rings TWiST's Avatar
    Jun 08 2007
    This is how I coded out my EGT sensors on my car, so far so good, not much road testing yet though, but when it would throw the fault before it has not for much longer.
    CDATR 0x18196 Configuration byte diagnosis exhaust gas temperature regulation
    CDATS 0x18197 Configuration byte diagnosis exhaust gas temperature sensor
    CLAATR 0x106b0 Error class exhaust gas temperature regulation
    CLAATR2 0x106b1 Error class exhaust gas temperature regulation bank 2
    CLAATS 0x106b4 Error class exhaust gas temperature sensor
    CLAATS2 0x106b5 Error class exhaust gas temperature sensor bank 2
    The 181xx range was the same on my AA box ecu but the 106xx range was a tad different the dummy table starts (I believe) at 1073B on my revision AA box ecu.
    Jan 11 2010
    VILLA RICA GA
    is it just one wire are is it the shielded type? more info on doing this would be great. its not for a permant fix but just a temperary one till i get the money or get it coded out.
    Jun 08 2007
    I can get you sorted out with an EGT delete on your tune if your interested, PM or email me
    Senior Member Two Rings jameskkk3's Avatar
    Jun 16 2009
    EPL stage 3 S4 cooled by Evolution-Racewerks
    have your tuner code them out
    EPL Stage 3+ / Aquamist HFS-6 / ERs / AMC trans rebuild / ASP / ssac / southbend / KW V3s/ hartmann DTM 18's / AMC built Tial 605
    Registered User Three Rings
    Jul 16 2009
    Ferndale, MI
    We've been coding them out for a while no troubles at all...
    Jun 08 2007
    Have to make sure you fueling is good as well cause if you have a forward o2 issue the EGT is the backup to enrich the fuel and if you do not have that backup you really want to make sure things are good encase any unforeseen circumstances may arise.
    Jan 11 2010
    VILLA RICA GA
    i have giac tune, how much to tune it out?
    Senior Member Three Rings diaftia's Avatar
    Oct 19 2007
    Danville, CA
    What does it take to tune it out? Can you do it with a VAG-COM?
    03' RS6 - Mugello Blue, Ebony Interior. 19" V710's
    Sold - 2006 6SP Silver B7 S4 - APR Exhaust, piggies, JHM Tuned, VMR V708's
    Sold - 01.5 B5 S4 6-Speed - Neuspeed Exhaust, GIAC-X ECU, Short Shifter, 034 Diverter valves and TBB, VMR V708's
    Oct 19 2007
    Danville, CA
    Quote Originally Posted by diaftia View Post
    nevermind... just saw this:
    http://www.audizine.com/forum/showth...CU-%28ME7.1%29
    Jun 08 2007
    Unfortunantly no you cannot do this with vagcom you have to have a KWP or Galletto to pull down the bin file change the 6 sections and then flash it back to the ecu, I may be able to help you out, PM or email me. You are in cali I see, that makes things much easier depending how far you are from me.
    I see you did PM me from before sorry been busy at work, I PM'd you back
    Oct 19 2007
    Danville, CA
    Quote Originally Posted by TWiST View Post
    I am in CA but I am in the Bay Area. I think you are in SoCal? Can you do these changes to a stock ECU or do you need to swap things out to put a programmable chip in it? I have a spare stock ECU (GIACX in the car now) that I might be able to fool around with.
    Jun 08 2007
    Check your PM
    Veteran Member Four Rings AudiXS4X01's Avatar
    Nov 11 2006
    01 Audi S4-Santorin Blue
    Tri-State
    No sense in buying new EGT's, its cheaper to just code them out and you'll never have to worry about them again..
