Page 2 of 8 FirstFirst 1234 ... LastLast
Results 41 to 80 of 292
  1. #41
    Established Member Two Rings pocket Hercules's Avatar
    Mar 14 2009
    Wa
    WOW looks amazing
  2. #42
    Senior Member Three Rings werewolves182's Avatar
    Jul 01 2008
    Annapolis, MD
    I think I need new underwear, OP, your avant is simply gorgeous!
    1999.5 Volcano Mica A4 1.8t: SOLD
    2000 Nogaro S4 6sp: RIP thanks to a very icy road. PARTING OUT!
    1999 Santorin A6 Avant: SOLD
    2000 Gold A6 4.2 Sport: Parting out
    2001 Black A6 4.2 Sport 6sp
  3. #43
    Veteran Member Four Rings steveo_01vwgolf's Avatar
    Nov 14 2008
    2013 Durango R/T, 07 600RR
    Port Orchard, WA
    very nice. I too am a fan of the blue and black contrast!
    steve
    2004 S4 6MT, AWE non-res catback exhaust, EuroGear C/F vented hood, Deval c/f roof spoiler, Hawk HPS street pads, DTH RS4 rearsway, Apikol Rear-diff mount, Apikol snub mount, Eclipse AVN726e nav unit/dvd, ECS smoked side markers, Joey's Piggie Pipes, Tein Basic Coilovers, OEM Euro tails, 19" Forgestar F05 wheels, JHM racing pedals, JHM stainless steel weighted shift knob, JHM Tune, JHM intake spacers, JHM lwcp, JHM LW front rotors, JHM short shifter
  4. #44
    Veteran Member Three Rings lENrok1's Avatar
    Nov 30 2007
    B7 DTM S4, VW MK2
    Florida
    TayTay, let's turn AZ into Stanceworks.....lmao!
  5. #45
    Dec 31 2008
    PA
    looks are personal prefeence, if you like it, cool
    but my concern, it's not safe, the max rim for that tire is 9.5, and that's pushing it
    the bead is not seated properly, that is dangerous
  6. #46
    Veteran Member Four Rings CONTROL TWO's Avatar
    Oct 01 2006
    Cayman S
    SJ
    Quote Originally Posted by RBSileighty View Post
    I wouldn't exactly call mine a lowrider but mine's not high by any means... 245/35/19 V12 Evo's on a 19x9.5 +33
    ...but I hear ya... I am mostly limited by my inner clearance (I pulled my front fenders to make it fit), so I'm sure it's right there with the 10's... what's the offset? Get the spacer on there and pull out the roller... then wrap um in 245's... just my opinion
    I don't rub at all btw...
    yeah 245 on the 10's would push the inner corner too close ot the suspension.. 9.5 with a spacer and rolled fenders is enough for a 245, but youre just asking to rub thru the tire if you do it on 10's.. theres no room to pull his fenders any significant amount if theyre already rolled (which im 99% sure thye are), so poke is the only option
    -Grant
    ig: g_strachan
  7. #47
    Nov 30 2007
    B7 DTM S4, VW MK2
    Florida
    Quote Originally Posted by ArthurPE View Post
    OMG you tires are going to fall off!
  8. #48
    Senior Member Two Rings Naudi04's Avatar
    Dec 02 2009
    2004 S4 6MT
    Oregon
    Looking good TayTay!
    My MKIII jetta had the tires stretched about like yours and it was dumped also on coil overs. Couldn't really push the corners with that setup in fear, but it's a really nice way to tuck the tire under the fender like you did.
    2004 Audi S4 6MT 40k miles, Light Silver (Metallic) w/Black-Silver Alcantara
    For Sale <- click link
  9. #49
    Dec 31 2008
    PA
    Quote Originally Posted by lENrok1 View Post
    let's hope not
    but if they do I'm sure we'll be reading about it on here, but perhaps not from him
  10. #50
    Jan 14 2009
    Audi's
    That looks amazing! My car is going lower tomorrow now hahaha
  11. #51
    Veteran Member Four Rings Retsujou's Avatar
    Dec 07 2008
    08 RS4 Tit/Exec/Prem/Carbon
    Mississauga
    I know low is a lifestyle but that simply does not do it for me. Never liked the tucked look and the tire stretched look. I do like the colour combination though
    08 B7 Cherry Black Pearl RS4 + JHM Lightweight Flywheel + JHM Stage III Clutch + VAST Piggie Pipes + K&N High Flow Airfilter + APR Stage II (Testpipe tune) + Hueper Optik 30% + Magnaflow X-Pipe + Centre Resonator Delete + Deflap + HAWK Ceramic front/rear + Stoptech Steel Brake lines + V4 LED Headlights (blackout/clear corner)
  12. #52
    Veteran Member Three Rings Mr Hyde's Avatar
    Oct 20 2009
    Long Island
    Not feeling the huge gap between the edge of the rim, and the actual tire. Its so big that it doesn't look like its seated properly.
    On my cars when I bought rims, I always went wider so that I could fit the widest possible rubber on it. Dont understand the point of a 10 inch wide rim, if you can only put a 235 wide tire on it.
    Just call me.............Mr Hyde
    2007 Mugello Blue Pearl RS4
    JHM 2.75" HFC // JHM Resonated Exhaust // APR 93 // KW V3 // RS6 Flatbottom // V1// LI-S4 Concealed Display // Stoptech Aerohats // Carbotech Pads // Ventureshield // Apikol Diff Mount // ECS Diff Carrier Mount inserts // 034 Tranny Mount // 034 Rear Sway //RS5 20x9" Titan Rotors
  13. #53
    Senior Member Three Rings Brian@rotiform's Avatar
    Nov 13 2009
    Westminster, CA
    Nice Taytay!
    For all you guys saying the tires are too thin. How about a 275/30/19 on a 10"?
    Or if that's too low.
  14. #54
    Feb 06 2010
    keep it up, cars sick man. I just scooped up a set of AERO II's which are 18's my car will be dumped as low if not lower, tires will be stretched as well. I like what you did here props
  15. #55
    Veteran Member Three Rings TayTay's Avatar
    Jun 28 2009
    Palm Beach Gardens, Florida
    hmm im pretty sure the tires are safe. It seats fine and is holding air. If you think this is a lot of stretch you havent seen anything. Honestly I dont push this car at any ride height because it simply sucks at it.
    2013 AUDI S4
    MISANO RED Silver/Black Napa
    6mt | MMI | Advanced Key | Sports Diff | 19" Peelers
  16. #56
    Oct 01 2006
    Cayman S
    SJ
    Quote Originally Posted by TayTay View Post
    i dont think they understand your purpose for the avant .. but that being said, ive done canyon runs with the same setup as you (raised about 0.5in) and the tires have been fine.. people are def overreacting to the stretched tires
    -Grant
    ig: g_strachan
  17. #57
    Dec 02 2009
    2004 S4 6MT
    Oregon
    Those are stretched quite a bit (they hold air yes, but safe...for cruising straight lines daily, yes). But if you took a corner at a decent speed I bet you would think differently about having that much stretch just for the looks. You'll feel your car lean (even with sway/strut/coilover) and that's your tires shifting under weight. Still looks killer though, just saying don't ever push the handling ability with a setup like that.
  18. #58
    Feb 12 2004
    2018 M3 CS, i3 REx
    Orange County CA
    First off, I think it looks really good! I love the color combo, and I would personally keep the chrome trim. It keeps it classy. Second of all the stretched look doesn't look bad to me, but it doesn't add too much either. If there are safety concerns I would just get a normal size since the stretched look doesn't add that much more in the way of aesthetics. In other words, your car would still look killer with or without the stretched look. Third of all, I'm afraid that I am in the "too low" club. If it rubs, it's too low for me. Period. That's just me and my driving style. If I knew I was rubbing on hard corners then I don't like the feeling that I have to dial it down. I just like the feeling that everything is 100% in working order with no issues.
    Former:
    BMW F80 M3 CS
    BMW F80 M3
    BMW I01 i3 REx
    BMW F30 340i M Sport ZTR
    Audi B7 S4 25Quattro
    Audi B5 A4
  19. #59
    May 13 2008
    MQBs
    San Francisco
    Slam, drop, poke, stretch, dip shit. All words that go together.
  20. #60
    May 13 2008
    MQBs
    San Francisco
    So your stance prevents you from driving your car the way it's supposed to.. Alright.....
    You're retarded.. it's official.
  21. #61
    Senior Member Three Rings ozo101's Avatar
    Jan 24 2009
    nj
    x2 on all that , too low, hate the poke and then stretch? wtf ! so now stretching is an audi thing also , F that! it sucks
    Quote Originally Posted by CaptDistraction View Post
    stretch poke and stance FTL. Just not feeling it. Wheelface looks great on the blue.
    Drop den Vorschlaghammer!
  22. #62
    Dec 24 2008
    S4
    West of NY
    How does it handle in hard twisty road driving with this setup?
  23. #63
    Jun 28 2009
    Quote Originally Posted by Kookie View Post
    Hmm i drive my car like i want to. Honestly I dont see the point in driving this car in the turns fast thats not why I got it. If i wanted something fast and fun in the turns i would have gotten an M3 or something smaller and rwd.
    2013 AUDI S4
  24. #64
    Veteran Member Four Rings staticuxo's Avatar
    Sep 16 2008
    screw the haters.. shit looks dope.
    B9 S4 - DAYTONA | BLACK OPTICS | ABT HAS | AWE TRACK w/ RES DP
    B8.5 SQ5 - SEPANG | BLACK OPTICS | KW SC | AWE TOURING | ROC-EURO | VORSTEINER V-FF 103 21x10.5 | CONTI DWS06 295/35-21
    C5 A6 - 4.2L | 6MT SWAP | H&R | OEM TTRS ROTORS 19x9
    PREVIOUS:
    B7 S4 AVANT 6MT | B8.5 S4 6MT | B8 S4 S-TRONIC | B8 S5 6MT | B7 S4 6MT | B7 A4 6MT
  25. #65
    Feb 01 2008
    04 Audi A4 cab
    Chicago
    Not sure why people insist on making their lux sport sedans look like 10 year old VWs. Also it seems that majority of this shit originates out of florida; not sure what's going on over there.
    This "euro tuning" look that people in the US jack off to is nothing but a local variety of rice; tards that can only afford 10 year old cars and tires 2cm too narrow. I'm european and those clowns are certainly not something to emulate; not any more than JDM nonsense for hondas.
    Finally any time you get responses that people dismiss as "haters" or that it's "unique", you did something retarded. This rule never fails.
  26. #66
    Feb 01 2008
    04 Audi A4 cab
    Chicago
    Quote Originally Posted by Brian@rotiform View Post
    Nice Taytay!
    ^ that looks way classy
  27. #67
    Nov 13 2009
    Westminster, CA
    Guys - please stay away from the personal attacks and name calling. If you don't like the style of Taytay's car fine. Click that back button and move on. The stretch debate does not need to be relived for the millionth time either.
    Thanks
  28. #68
    Dec 31 2008
    PA
    the main issue with too wide rim vs too narrow tire is not only holding air, but having the bead securely seated
    there IS a reason they give an approved rim width...not conforming may void warranty or DOT certification
    the issue is when the tire looses air or deflates, then it's the bead that locates/secures the tire to the rim...it's a safety issue
    a blowout/deflate at 70 is bad enough, if the tire leaves the rim it only gets worse
    with rubbing the likelyhood of this happening increases, due to the damage the rubbing does over time...
    all I was trying to do was give you fair warning, you're a big boy...some people don't know things intrinsically, until explained, that's all I was attempting to do, no insult intended
    lecture over
    side note: car looks good, I would raise it a bit for drivability, but it looks cool
    the rims are great, I have them in silver and couldn't be more pleased...I run 265/35/19
  29. #69
    Dec 31 2008
    PA
    uncalled for
    people make choices
    his is style > absolute handling
    who's to say he's 'wrong'? his car, his choice
  30. #70
    Veteran Member Four Rings mtndog's Avatar
    Jan 22 2009
    992 GTS, F90 M5c, G05 X5 M60
    pnw
    uncalled for
    people make choices
    Albert's quote can be applied to this setup! "Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe."
  31. #71
    Nov 30 2007
    B7 DTM S4, VW MK2
    Florida
    Thanks
    Thank you Brian
    Ignorance is bliss. When people don't understand something, they choose to disagree with it because it's not the "normal". Obviously we choose to run this set-up with the intent of driving it a certain way. The euro scene consist of many things. Everyone chooses their lane ....
    So like Brian stated, if you don't like or disagree click the back button and look for threads you like. As the Post title says, "Go on.........ask me if i rub" Answer is: Fuck yes, and I love it. (You Ain't dubbing, if you ain't rubbing.....lol
  32. #72
    Feb 01 2008
    04 Audi A4 cab
    Chicago
    Thank you Brian
    This is what im talking about - what the hell is going in florida? Fast and furious happened loooong time ago...
  33. #73
    Nov 30 2007
    B7 DTM S4, VW MK2
    Florida
    Btw threads like this kind of inspire me to bag my s4. A V8 on bags.....ahhhhh shiiiiiiittttt!
  34. #74
    Veteran Member Three Rings pattrick02's Avatar
    Aug 22 2009
    South Florida
    poke. stretch. slam. that set-up/stance looks sick! makes me want to do the same...i have to see this in person! and i would probably throw those spacers in there and dial in some more negative camber, too.
    No more S4. :(
    World's quickest & fastest TSI in the works, and never ending.
  35. #75
    Nov 30 2007
    B7 DTM S4, VW MK2
    Florida
    Quote Originally Posted by halik View Post
    if your referring to our style as fast and furious your bugging. Last I checked we don't have crazy wings and body kits with neon. In fact we are all oem. Do your research before you decide to run your mouth.Or better yet stop by a blockbuster and rent yourself the movie. Maybe you'll get a clue!
    So because I lower my car maybe and inch more and run a more aggressive wheel I'm fast and furious? I'll use mtndog quote : Albert's quote: "Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe."
  36. #76
    Senior Member Three Rings JeST's Avatar
    Feb 08 2010
    1995 Supra
    Zoo York
    Although I can respect the work that's been put into the car it's definitely not my style.
    Current:
    2000 Nogaro on Nogaro 6 speed B5 S4
    1994 Toyota Supra 6 speed
    '07 6spd S4 DTM Brilliant Red/Black on Black Alcantara
    '03 M3 VF Supercharged AW/Cinn
    '03 Lexus IS300 GGP GTE/6spd Getrag (615rwhp/520rwtq @ 19psi pump gas)
  37. #77
    Feb 01 2008
    04 Audi A4 cab
    Chicago
    Err wat?
    And yes, regarding the issue of running tires soo narrow that the bead can pop off, that quote is very apropos. The slam/poke/stretch nonsense is the ed hardy of car modifications.... sweet belt buckle bro.
  38. #78
    May 13 2008
    MQBs
    San Francisco
    Err wat?
    And yes, regarding the issue of running tires soo narrow that the bead can pop off, that quote is very apropos. The slam/poke nonsense is the ed hardy of car modifications.... sweet belt buckle bro.
    +1. That low, I'd love to see how long his suspension components last. Or that fateful day he DOESN'T see that monster pot hole...
    Ask me how many B6/B7's I've seen at my dealer getting new transmissions because of a pot hole, or rock.. Florida isn't as Utah, but none the less..
    I guess I'm just more of flush/functional type of guy as opposed to using incorrect sizes on my car and in his words, ruining the ride of the car.. Since when does this car not handle well? Mine handles great.. I mean, it's no time attack car, but sure as hell feels solid through the corners..
    You should have bought an M3 TayTay
  39. #79
    Feb 01 2008
    04 Audi A4 cab
    Chicago
    You should have bought a Passat TayTay
    fixed
  40. #80
    May 13 2008
    MQBs
    San Francisco
    uncalled for
    people make choices
    I'm entitled to my opinion as well..
