Results 1 to 13 of 13
    Jun 08 2004
    96 Nissan 240SX
    Montreal
    Differences between a C5 Rs6 Plus and a C5 RS6
    For those who were ever interested in knowing what the differences were in the RS6 Plus vs the Rs6
    Code:
    2004 Audi RS6 plus 	See all Audi models
    Wheelbase 	2759 mm 	108.6 in
    Track 	front 	1578 mm 	62.1 in
    rear 	1587 mm 	62.5 in
    Length 	4852 mm 	191 in
    Width 	1850 mm 	72.8 in
    Height 	1452 mm 	57.2 in
    Length:wheelbase ratio 	1.76
    Ground clearance
    Kerb weight 	1880 kg 	4145 lb
    Weight distribution
    (Front)
    Fuel capacity 	82 litres 	18 UK Gal 	21.7 US Gal
    aerodynamics
    Drag coefficient 	0.350
    Frontal area 	2.20 m2
    Cx 	0.77
    engine
    Bore × stroke 	84.50 mm × 93.00 mm
    3.33 in × 3.66 in
    Cylinders 	V-8
    Displacement 	4.2 litre
    4172 cc
    (254.591 cu in)
    Type 	DOHC
    Key:
    SOHC
        Single overhead camshaft
    DOHC
        Double overhead camshaft
    OHV
        Overhead valves
    TS
        Two stroke
    SV
        Side valves
    Sl
        Sleeve valves
    oise
        Overhead inlet side exhaust
    See more...
    5 valves per cylinder
    40 valves in total
    Construction
    Sump 	Wet sumped
    Compression ratio 	9.80:1
    Fuel system 	SMPFi
    Maximum power 	479.6 PS (473.0 bhp) (352.7 kW)
    @ 6000-6400 rpm
    Specific output 	113.4 bhp/litre
    1.86 bhp/cu in
    Maximum torque 	560.0 Nm (413 ft·lb) (57.1 kgm)
    @ 1950-6000 rpm
    bmep 	1686.8 kPa (244.6 psi)
    Specific torque 	134.23 Nm/litre
    Maximum rpm
    Manufacturer 	Audi
    Code
    Main bearings
    Coolant 	Water
    Bore/stroke ratio 	0.91
    Unitary capacity 	521.5 cc/cylinder
    Aspiration 	Turbo
    Compressor type 	twin turbochargers
    Intercooler 	Y
    Catalytic converter 	Y
    performance
    0-50 mph (80 km/h) 	3.60 s
    0-60 mph
    0-100 km/h 	4.90 s
    0-100 mph 	10.70 s
    80-120 km/h (50-70 mph) in top
    Standing ¼mile 	12.50 s
    @ 107.50 mph
    Standing km
    Top speed 	280 km/h (174 mph)
    Fuel consumption 	21.8/10.4/14.6 l/100km urban/extra-urban/overall
    CO2 Emissions 	350.0 g/km
    Carfolio Calculated CO2 ?
    Power-to-weight 	251.6 bhp/ton
    chassis
    Engine location 	Front
    Engine alignment 	Longitudinal
    Drive 	AWD
    Key:
    FWD
        Front wheel drive
    RWD
        Rear wheel drive
    AWD
        All wheel drive
    4WD
        Four wheel drive
    Steering 	rack & pinion PAS
    Turns lock-to-lock 	2.500
    Turning circle 	11.70 m
    Suspension 	front 	I.4Li.CS.ARB.
    rear 	I.DW.ARB.
    	Key:
    I
        Independent
    LA
        Live axle
    dD
        de Dion axle
    W
        Wishbone
    DW
        Double wishbones
    CS
        Coil springs
    ARB
        Anti-roll bar
    LS
        Leaf springs
    SE
        Semi-elliptic leaf springs
    See more...
    Wheels 	front 	9J x 19
    rear 	9J x 19
    Tyres	front 	255/35 R 19
    rear 	255/35 R 19
    Brakes F/R 	VeDi/VeDi-S-ABS
    Key:
    Ve
        Ventilated
    Di
        Disc (Disk)
    Dr
        Drum
    S
        Servo-assisted
    ABS
        Anti-lock Braking System
    Brake ∅	front 	365 mm
    rear	335 mm
    Braked area
    Transmission 	5A
    Top gear ratio 	0.80
    Final drive ratio 	3.20
    Code:
    Carfolio.com ID	93720
    bodywork
    2002 Audi RS6 	See all Audi models
    Type	4/5S SAL
    Key:
    SAL
        Saloon (Sedan)
    FHC
        Fixed-head coupé
    DHC
        Drop-head coupé (Convertible)
    HBK
        Hatchback
    EST
        Estate (Station Wagon)
    See more...
    Designer
    Number of doors 	4
    dimensions & weight
    Height 	1387 mm 	54.6 in
    Ground clearance
    Kerb weight 	1840 kg 	4057 lb
    Weight distribution
    (Front)
    aerodynamics
    Drag coefficient 	0.340
    Frontal area
    Cx
    engine
    3.33 in × 3.66 in
    Cylinders 	V-8
    4172 cc
    (254.591 cu in)
    Type 	DOHC
    Key:
    SOHC
    DOHC
    OHV
        Overhead valves
    TS
        Two stroke
    SV
        Side valves
    Sl
        Sleeve valves
    oise
    See more...
    40 valves in total
    Construction
    Sump
    Compression ratio 	9.30:1
    Fuel system 	SMPFi
    Maximum power
    (EEC) 	450.2 PS (444.0 bhp) (331.1 kW)
    @ 5700-6400 rpm
    Specific output 	106.4 bhp/litre
    1.74 bhp/cu in
    Maximum torque
    (EEC) 	560.0 Nm (413 ft·lb) (57.1 kgm)
    @ 1950-5500 rpm
    Maximum rpm
    Manufacturer 	Audi
    Code
    Main bearings
    Coolant 	Water
    Aspiration 	Turbo
    Compressor type 	2 turbochargers
    Intercooler
    performance
    0-50 mph (80 km/h)
    0-60 mph
    0-100 km/h 	4.90 s
    0-100 mph
    Standing ¼mile
    Standing km
    Top speed 	250 km/h (155 mph)
    Power-to-weight 	241.3 bhp/ton
    chassis
    Drive 	AWD
    Key:
    FWD
        Front wheel drive
    RWD
        Rear wheel drive
    AWD
        All wheel drive
    4WD
        Four wheel drive
    Turns lock-to-lock
    Turning circle 	11.40 m
    rear 	I.DW.ARB.
    	Key:
    I
        Independent
    LA
        Live axle
    dD
        de Dion axle
    W
        Wishbone
    DW
        Double wishbones
    CS
        Coil springs
    ARB
        Anti-roll bar
    LS
        Leaf springs
    SE
    See more...
    Wheels 	front 	8.5J x 18
    rear 	8.5J x 18
    Tyres	front 	255/40 R 18
    rear 	255/40 R 18
    Key:
    Ve
        Ventilated
    Di
        Disc (Disk)
    Dr
        Drum
    S
        Servo-assisted
    ABS
    Brake ∅	front
    rear
    Braked area
    Transmission 	5A
    Top gear ratio 	0.80
    Jun 20 2009
    Audi RS6 C5 and Audi S6 C5
    Sydney
    It is interesting information but it's wrong.... Where did you get it from?
    As examples:
    Final drive ratio it states as 3.20:1 when in ETKA the rear Diff ratio and Gearbox Pinion Gear is 4.11:1
    Also there is no difference between the following Block&bottom end, Cylinder Heads and head gasket based on ETKA all the parts are exactly the same, hence how can the compression ratios be different?
    I would be surprised if there are not just a few minor changes to trims and drilled rotors std as well as an ECU remap to get the additional ~31kw in power.
    May 16 2008
    South Texas
    Quote Originally Posted by milka View Post
    As examples:
    Yeah that's a load of crap.
    The big differences:
    More HP due to a retune
    Wheels
    Interior had a few more options like funkadelic leather.
    RNS-E versus NAV plus
    Punched brake rotors
    Oct 02 2005
    The Moon
    Only performance differences are different ecu map, and comes standard with the additional oil coolers behind the intercoolers, which are on all US spec RS6's. Drilled rotors are standard ( as they are in the US) and SE exhaust standard as well.
    Also there was an optional sport suspension kit which lowered the car 10mm.
    Feb 23 2008
    San Jose, CA
    +1 to Scott
    Jun 20 2009
    Sydney
    Yeah, but I think that unless the US spec ones are different from the Aus spec ones then they are not oil coolers behind the intercoolers but are actually additional radiators.....
    Jun 20 2009
    Sydney
    Scotty, are you saying my post is a load of crap? Because you pretty much just agreed with what I posted? Or are you just agreeing with my post?
    Quote Originally Posted by Scotty@Advanced View Post
    Wheels
