Results 1 to 6 of 6
    Established Member Two Rings hockeyguy's Avatar
    Mar 28 2006
    Calgary, Alberta, Canada
    Quick VMR offset Question
    Tried searching, but way too many "VMR OFFSET" threads come up without finding the right info.
    I have an 08 b7 a4 s-line that will be dropped soon with the koni fsd/eibach setup and I was wondering if the et35 or et38 offset would work better for the V708 RS4 reps?
    Thanks in advance.
    Veteran Member Three Rings NastyNate's Avatar
    May 26 2009
    ET35 is the one designed for our cars.
    Veteran Member Four Rings Vorsprung's Avatar
    Feb 26 2008
    Raptor, FD RX7
    Long_Island/NY
    35s
    -Ian
    Veteran Member Four Rings TH85's Avatar
    Oct 02 2006
    2008 A4 2.0T
    Chicago
    Quote Originally Posted by hockeyguy View Post
    Thanks in advance.
    good question cause i have that supsenion on now and will be getting the 708's in 19's
    koni fsd/eibach suspension
    Mar 28 2006
    thanks guys
    Jun 14 2005
    Anaheim, CA
    Our v708's are offered in 8.5et38, depending on the wheel model, we either have +35 or +38 for the A4/S4's, both work great. Between 38 and 35, there's only a 3mm difference, you wouldn't be able to tell with your naked eye.
    Brandon @ VMR Wheels
