Page 6 of 15 FirstFirst ... 45678 ... LastLast
Results 201 to 240 of 599
  1. #201
    Veteran Member Four Rings ericpaulyoung's Avatar
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    Quote Originally Posted by ultraleggera a4 View Post
    Listen be more optimistic for our platform, there is a way and I'm going to show you, I dont want to reveal everything but along with the fueling, I'm getting an APR machined head.
    Well, you would be way better off buying a Frakenturbo or a CTS K04, or similar with that cash. WAAAAAY more bang for your buck if your choice is between a ported head and K03 vs. a stock head and a K04 variant. I would be willing to bet that you will likely see less then a 10 whp increase slapping a ported head on a K03 build, and it will cost you 2k. I like the ported heads, but the they are definitely not the bottle neck on a K03 build.
    Eric
    Epy
  2. #202
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    hahahahahahaha dear god this is unreal
  3. #203
    Senior Member Three Rings ultraleggera a4's Avatar
    Feb 27 2012
    Aurora, Colorado
    Im not going for cheap power im going for max power. You don't think I know that all ready, the turbo selection is the final peace after I max out the k03 for fun. I'm doing this the right way building it from the inside out so I came achieve the k03 record. also this motor going to be transplanted into a donor car. I must have quattro.
    239whp / 284wtq dyno proven (uncorrected)~270whp/305wtq with new goodies dyno results will be coming soon
    Stock K03
  4. #204
    Feb 27 2012
    Aurora, Colorado
    Quote Originally Posted by drumnjuny View Post
    Why not I have the money for it so what the hell, Im not going to get into a pissing contest with you but those are my personal goals.
    Stock K03
  5. #205
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    yeah i can get behind that... max out the CVT then swap it with the k03 max out the quattro 6MT and then go big turbo. just seems like a lot of time lol
  6. #206
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    Re: The B7 A4 Dyno Thread
    It's still hard to believe it could be possible though. You can hit 25-30 psi on a K03, it is possible. But it is so far out of its efficiency range at that point, I don't think any amount of cooling and fueling could hold it for more than a second. Don't get me wrong, I hope you prove every one of us wrong. Maybe there is that much room left in tuning, since no one ever really does custom stage 2 tunes. Would really be a game changer though, if custom tuning could net you 50 or so more whp than OTS tunes.
    Sent from my porcelain throne.
    2021 Audi S4, P34 Intake
  7. #207
    Feb 27 2012
    Aurora, Colorado
    And thats what I'm here for , and there is a way just lower combustion temps along with compression ratio.
    The reason I have higher horsepower is because I have lighter piston and rod combination, so I lost torque due to less rotational mass being moved
    Stock K03
  8. #208
    Feb 27 2012
    Aurora, Colorado
    I have nothing but time and I've only been working on my a4 for a year and a half
    Stock K03
  9. #209
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    You are right on the money; the K03 simply cannot push the air. Doesn't matter what you do, you will never have the flow to produce the power.
    There is a way, though I am hesitant to mention it. I don't know you and can't tell if you would be interested, but there is a story about this stuff called nitrous. A 100 shot system might get you there. Remember the wisdom from Vin Diesel in the opening scenes of the Fast and the Furious part I, you don't want to shoot your wad too quick. Hold off until about 4000 rpms when the K03 starts to drop like a hot potato, then let the first 100 shot go!, follow this with another, and another until you hit 6300 rpms (this is max power for our cars). With the ported head, a 4" straight pipe exhaust, and the right cone filter, you can probably make your goals.
    You gotta pay to play, but from your posts I can tell you already know this. Good luck, and God Speed! I am excited to see the dyno, with each nitro shot just ploughing up the chart with horsepower screaming to 350 awhp. I can hear Michael Buffer yelling in the background "the new world champion of K03 dynos..."
    Please, please, get a video of the dyno run. It is sure to be da bomb!
    - Eric
    Epy
  10. #210
    Feb 27 2012
    Aurora, Colorado
    Nitrous might be the last resort lmao [>_<]
    Quote Originally Posted by ericpaulyoung View Post
    - Eric
    The i will most likely use c16 to get my end result, lmao if that doesnt f*uck it, nitrous it is.
    Seriously i hope you guys just accept it when it does happen and dont put me down im just looking for the max potential of the FSI platform, and still have a very high efficiency.
    Stock K03
  11. #211
    Established Member Two Rings NODO-GT's Avatar
    Jul 30 2010
    Audi A4 B7 2.0T Quattro 6MT
    Tbilisi
    I bought PerfExpert App and did dyno measures with it, turned out to be pretty accurate!
    I did several runs and got consistent results +-3HP.
    Although I doubt Peak HP would be at top end... :)
    2005.5 Audi A4 B7 2.0TFSI Quattro 6MT
    |Visuals: Lip Spoiler CF / Headlight Blackout + Clear Corner / LED Number Plate / Smoked LED Tail Lights / RS4 Grill / Night Braker Plus / S-line Door Blades / Gunmetal RS4 18" Wheels|
    |Performance: ECU Tune / Test Pipe / K&N Air Filter / Vast Perfromance Stage II Clutch / S-line Suspension|
    |Maitenance: BSH PCV FIX / Diverter Valve Revision D / Fuel Pump Cam Follower / Purge Valve N80 / Seafoam / Coil Packs Revision F / Spark Plugs NGK BKR7EIX|
  12. #212
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    Man that is cool. Peak hp for our cars is at 6300 rpms, so it is in the right spot too.
    - Eric
    Epy
  13. #213
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    Here is my first try with the app.
    Epy
  14. #214
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    That was using a curb weight of 3280 pounds. I will have to get an actual weight so that it calculates a more accurate value. What did you use in the app for weight?
    Epy
  15. #215
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    And a second run
    Epy
  16. #216
    Veteran Member Four Rings A-BlacK_MambA-4's Avatar
    Jan 22 2011
    '05.5 A4 2.0T Tip Revo Stage 2; Wifes 2013 Chevy Cruze
    Ohio
    Wow reading up on that app it looks really cool and reliable when they compared it to an actual dyno. So is it just a second gear pull I'm assuming to get the numbers?
    -JOEL
    The Real Black Mamba
  17. #217
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    Ya those were second gear runs. I just flashed a tune with a 30 psi max, so we will see how it looks.
    Eric
    Epy
  18. #218
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    OK, upped the boost on the top end to hold pressure more, and added more meth (and adding it earlier too), and it is feeling fast. I picked up the top end to hold 27-28 psi closer to redline, and it helped the top end. Still not at 30 psi and my wastegate duty at 6000 is 87%, so I don't have much headroom left. I am going to try lifting the duty limit to 95% by 6500 rpms, and see if I can get the turbo with a solid 30 psi up by redline. That should get me close to 400 awhp. Once I get the app based dyno showing consistent 400 awhp, I will schedule a real dyno up in Portland :)
    Epy
  19. #219
    Jul 30 2010
    Tbilisi
    WOW,
    Amazing power ericpaulyoung :)
    glad you liked the App. So I guess it should be pretty reliable as long as you set it up right and make a good clean run.
    I filled Advanced setting for car (did quite a lot of searching to get reliable numbers) and it looks like this:
    Crub weight I used was 1490kg which is same as your 3280 pounds.
    You can see I added 160kg of additional weight, which should be correct as I had 1 passenger in car + fuel in trunk and other small stuff in the car.
    And second gear ratio was set to: 2.053
    Smoothing was set to - normal
    Also I used 2.8 Pitch for S-Line suspension and 18inch low profile rubber...
    Also how do you think, is 240HP normal for my A4 with only Tune and Test Pipe?
    I'm feeling like I'm down on power, also sometimes I get underboost check light...
  20. #220
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    It is definitely a fun app, though I can get different results depending on if the phone is inclined or flat. Since it is using the acceleration, it "can" be accurate, but I would say it is "for information only" type of measurement. Gotta play around with it some more to see if I can make exactly the same numbers each time, but right now it is pretty good.
    As for your numbers, I would check out the first page of this thread. It has a bunch of dynos for different setups.
    Thanks for showing me the app, it is fun for sure! :) As long as it is consistent, I am going to use it to judge the different setups I try. That is what is really important to me, being able to measure if the car is getting better or not.
    - Eric
    Epy
  21. #221
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    wow that's fucking awesome haha, but if it uses GPS then haha idk how accurate it could be. even 50lbs difference might make a huge difference! btw i think our cars are considerably heavier than 3280? 3550 dry is what i remember. the FrontTrak might be 3200 but quattro is definitely higher. that 300 lbs should definitely affect your dyno a bunch! you'll be over 400awhp if u make the adjustment to the weight
  22. #222
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    Ya I changed it to 3800 pounds. I am actually more interested in consistency than absolute numbers. That way I have another method to measure performance changes while I tune. I don't think the 2863 will push enough air for 400 awhp, but it gets work done down low for sure. I expect the top end highest hp number I will see on a real dyno will be somewhere in the 380 awhp range. I will be happy for anything over 350 awhp though :)
    - Eric
    Epy
  23. #223
    Veteran Member Four Rings fordyoz's Avatar
    Apr 20 2011
    Philadelphia
    sickkk i just got this. looking forward to playing around
    Borg Warner EFR6758 B7 A4
  24. #224
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    - Eric
    i would love to be in the 350+ range
  25. #225
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    huh? You want to decrease your hp? ;/
    Epy
  26. #226
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    haha no... i'm at wastegate pressure due to my boost fluctuation issue, on a base file, have an oil leak, still have my startup issues, i would like to get my car back anywhere near 350awhp lol. soon, though!!
  27. #227
    Dec 03 2008
    2018 SQ5
    Yeah. I have weighed my car on a truck scale. Always at 3600 lb without me in it.
  28. #228
    May 21 2012
    Houston, Tx
    Quote Originally Posted by NODO-GT View Post
    Does this app work with WIFI OBD2? I've been using DashCommand and it's been fairly accurate on the dyno numbers. However it doesn't do 0-60 1/4 mile and such. Just wondering if it's worth the money to get this app. Also wondering how accurate it really can be with out OBD2 interface on performance parameters.
    B7 A4 2.0T Quattro
    GIAC, Snow Performance W/M, RAI DP, ST Coilovers, RS4 Sway,Ti 18x8's,
    Stoptech Slotted Sport Kit
  29. #229
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    Nope, it works by measuring the actual acceleration of the vehicle and then doing an F=MA calculation. To get the rpm's, it uses the gear ratio that you specify and just back calculates it.
    Eric
    Epy
  30. #230
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    haha consistency and accuracy are two separate concepts though. not sure i would trust the precise measurements of a (most likely integrated) phone GPS chip...
  31. #231
    Veteran Member Four Rings alphaVR's Avatar
    Sep 12 2012
    Stage 3 F21 B5 S4
    Cleveland, OH
    AutoInterests in our area had a Dyno day at Smokey's Dyno & Performance here in Akron... had a BLAST, with me, a bunch of my friends, and a ton of others getting their cars on the rollers. Since i just got the car 2 months ago, I really wanted to see what it was doing on pump (93oct) gas, especially since I know its running pig rich and in dire need of a retune.
    Here's my dyno sheet from 2 pulls they did. Top is A/F ratio, buttom hp/torque.
    Overall Im really satisfied with what it did, but know that the car has a LOT of power left to be made. Im planning on taking my car back to Smokey's in early sept to get a full dyno tune and see how far the retune will take the car.
    Car Info:
    2008 Audi A4 2.0T Quattro Avant (w/ AWE Stage 3 Turbo Kit)
    GT 2871R Turbo
    AWE Tuning Stage 3 Manifold
    RS4 Injectors
    High-flow cat to 3" catback
    AWE/ER FMIC
    GIAC Pump Gas Tune
    Runs ~20lbs of boost
    FTWLTBDWICTW
    21 Toyota Tacoma TRD Sport | Daily Driver
    17 Audi S3 | Nano Napalm | The New Hotness
    00 Honda Civic | Track Rat[/SIZE]
  32. #232
    Established Member Two Rings stupdfresh's Avatar
    Jul 05 2011
    Annapolis MD
    So I download the PerfExpert app before I went APR Stage 2+ (got the car flashed today) and I did some before/after logs using the app... the HP and TQ numbers I got originally seemed pretty accurate for a stock b7 (shown below)
    All variables remained constant between runs (expect the weather conditions):
    **pulled specs from http://www.audiworld.com/model/a4/07/A4_tech.pdf**
    Car Weight: 3550 lb
    Additional Weight: 190lb (just me in the car and I weight ~165lb)
    Displacement: 1984 cc
    Wheel dimensions: 235/35R18
    Cd: 0.33
    Transmission: All Wheel Drive
    Final Drive Ration: 3.889
    Measure beginning rev: 2000 rpm
    Pitch: 3
    2nd Gear Ratio: 2.053
    Phone Placement: As the instructions read... "Place phone angled in the direction of travel between 0 and 90 deg". (I used the center console cup holder, with the phone angled in the cup holder its creates a nice snug fit)
    Stock A4 2.0T w/ RAI Test Pipe, Stasis Cat Back Exhaust
    7/26/13
    Average of 3 runs (all three runs were +-5/5 hp/tq)
    One of the Dyno Charts
    APR Stage 2+ 2007 A4 w/ RAI Test Pipe, Stasis Cat Back Exhaust
    7/30/13
    Average of 3 runs (all three runs were +-5/10 hp/tq)
    I know these numbers arent exact but its a good tool for showing your delta gain. I plan on getting carbon clean and FMIC soon, I will post results.
    2007 A4 2.0T 6spd, Stasis/Koni Street Sport Coilovers, RS4 Sway, Stasis Exhust, RAI Test Pipe, APR Stage II+
  33. #233
    Oct 29 2005
    10speed
    San Francisco, CA
    That is actually probably pretty accurate
    - Clint
  34. #234
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    Quote Originally Posted by alphaVR View Post
    Car Info:
    GT 2871R Turbo
    RS4 Injectors
    AWE/ER FMIC
    GIAC Pump Gas Tune
    You are waaaaay rich past 4000 rpm's. Dyno looks great but you would get measurable increases if you brought that AFR up to a Lambda of .82 - .84
    Eric
    Epy
  35. #235
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    Here is my latest with the new intake and running .83 lambda with 30 psi boost.
    Epy
  36. #236
    Sep 12 2012
    Stage 3 F21 B5 S4
    Cleveland, OH
    Eric
    Yup... thats why the same guys who did the dyno will be doing a full retune of the car in early sept. 300 at the wheels should be fairly easy to get to, and im pretty excited about that.
    My only concern is not knowing where the limits of the engine is... namely with stock internals. I don't want to go past a threshold im not aware of and break the engine. That would REALLY suck...
    That dyno graph you posted... is that measuring wheel or crank HP?
    FTWLTBDWICTW
  37. #237
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    whoa there, did you just say stock internals?
    Umm, I wouldn't push it at all actually, at least not until you got some fresh rods/rings/journals in there. From the spin up I am guessing you have a .84 AR, and this should smooth the peak out (looks nice and smooth right now), but still, the rods in our cars are pure unadulterated crap.
    It is an estimate only, and it is at the crank. I use the most good looking correction (DIN 70020), with SAE J1349 correction factors the peak estimated power is 388 hp at 6287 for that run. The app is a total estimate, and I just use it for back to back comparison of one run against another to see if changes I make are good or bad. So basically I just use it as a more accurate version of the butt dyno :)
    So 388 crank hp would be 302 awhp with a 22% drive train loss (which is about right for our quatros).
    Epy
  38. #238
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    Are those dyno charts you show corrected or uncorrected?
    Epy
  39. #239
    Sep 12 2012
    Stage 3 F21 B5 S4
    Cleveland, OH
    uncorrected from their superflo dyno. so what you see is what I have at the wheels.
    if my internals need addressed before i get retuned i need to know asap so I can cancel my appointment. Its one or the other right now... I thought these engines were good for the power on stock stuff at the boost/power im running...
    FTWLTBDWICTW
  40. #240
    Feb 06 2009
    328d, Tacoma
    Woodland Park, Colorado
    If you stay on the OTS tune, you are fine. If you are having a custom tune that aims at maxing your build, I'd reccomend rods at a min.
    EFR 6758 by UM
    Info:
    Build
    Pics
    Feat'd AZ'er
