Results 1 to 7 of 7
    Veteran Member Three Rings ccomengee86's Avatar
    Feb 17 2009
    '03 allroad 2.7T
    Dayton, OH
    DIY: Sportec Lower Air Vent mod
    All credit goes to V8weight
    Quote Originally Posted by V8weight View Post
    I saw that the Sportec RS600 as well as their intercooler kit come with these lower engine shield vents. I figured I could replicate them for a lot less money, like $8.00. All it took was some 1"x1" angle aluminum, and some 3/16" rivets. First layout a pattern (I used 3/4" masking tape).
    Next cut out the openings (I used a pneumatic mini sawzall, but a keyhole saw would work), and then clean up your cuts with a file.
    Then cut the aluminum angle stock to fit the openings, mark your holes, drill, then rivet them in place.
    I also wanted to redo those rubber brake cooling dams that were scraped off of my lower shield, so I sacrificed an Impala front air dam that I found at work. It's a heavy plastic rather than the rubber that they were originally made of.
    And done.
    Original Thread >>> Click Here
    Veteran Member Four Rings khalimadeath's Avatar
    Nov 18 2009
    70 VW Bus, 64 VW Bus, 13 Q7, 18 S5 SB
    Reno NV
    sombody wants to be a mod
    -Zach-
    The C5 Union////////////
    The United States Constitution
    (c) 1791. All Rights Reserved
    Veteran Member Three Rings V8weight's Avatar
    Nov 16 2008
    Hudson, WI
    Here's a couple of diagrams that I made with my crayons to illustrate the dimensions of the vents and the way that they work. Hope this helps anyone interested in this cheap and simple modification.
    - Pat -
    2016 RS7
    -Previous-
    2013 S6 Prestige, 2010 A6 Prestige/Sport package, 2012 A4 Avant S/line, 1991 Coupe Quattro, E55 AMG, 2009 A4 Prestige, B5 S4 avant, B6 S4, C5 RS6, B6 S4 avant, 71 El Camino SS
    Veteran Member Three Rings patrick23's Avatar
    Dec 09 2009
    2004 Audi A6 S-line, 2001 Nissan Pathfinder SE, 1999 Subaru Legacy Outack Limited
    val-des-monts quebec
    good stuff guys I'm going to try this one
    Veteran Member Four Rings audirs's Avatar
    Mar 22 2005
    Kitchener, Ontario
    looks great man. have you considered running mesh over the slots? maybe like an rs style from lltek. looks very functional but id be a bit worried about debris bouncing in. giant rocks or some bull shit. i can see belts in the pic, other then that id consider doing something like this when i replace my cover aswell
    Q5 3.0T S-line
    VW Tiguan R-Line
    A6 2.7T AWE Stage 3
    Coupe Quattro
    Nov 16 2008
    Hudson, WI
    Quote Originally Posted by audirs View Post
    I'm still running sans screen, but I did this mod on another local RS6 and he had me add this screen. Keeps the rabbits out. The problem I see with running a screen is that the only thing available is steel, there isn't any aluminum mesh available that I could find. This presents the potential for cross contamination between the aluminum and the steel, so eventually the aluminum will start to corrode, as will the screen, to the point of eventually falling off. The winter salt will only accelerate this.
    - Pat -
    2016 RS7
    -Previous-
    Feb 17 2009
    '03 allroad 2.7T
    Dayton, OH
    did you really draw that? that's amazing.
