Results 1 to 32 of 32
    Veteran Member Four Rings Trigger Happy's Avatar
    Jun 17 2008
    2K S4
    Rockville, MD
    Timing belt jumped a tooth
    So my timing belt jumped a tooth. How do I realign the timing belt without the cam lock bar? I'm doing this NOW so I really need quick responses if possible. Thanks guys
    "Clearly, a liger is not as practical as a Katana. S4s can't carry ligers. fucking 500lb cat in my backseat using my alcantara as a scratch post for its HUGE FUCKING CLAWS? I dont' think so bro"
    Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall and torque is how far you take the wall with you.
    2000 s4
    Fairfield, CT
    its really hard unless you have marks that where painted on. just do it right and rent or borrow a cam bar and lock pin. not something you wanna mess up
    i heart my s4
    Active Member Four Rings ThirdStrike's Avatar
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    you can 1) pull the valve cover off and line up the tick marks on the cam shafts - easy route
    2) make a mark on the sprocket and cover plate, slide the belt off the sprocket and turn it back a tooth by hand.
    either way without a locking bar good luck getting the belt back on without moving the sprocket. its a bitch.
    how do you know you jumped a tooth????
    00110100011100100110100101101110011001110111001100 001101000010100000110100001010
    Oct 06 2004
    Minnesota
    Make sure your valves are not bent. I just did the full valve job on my S
    Instagram r_michals
    '12 Q7 TDI- Glacier White
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Quote Originally Posted by A4Rob View Post
    1 tooth wont bend/strike valves.....
    Veteran Member Three Rings sparkyvw's Avatar
    Feb 11 2008
    B8 avant,964,B5 wb s4, mk2 vr, mk3 vr
    Palm Beach Gardens FL
    Quote Originally Posted by ThirdStrike View Post
    Niether will jumping 5 teeth.
    Cloud9Helicopters South Florida
    ROTIFORM AIRLIFT
    May 06 2004
    W124s
    PA
    Interested too, how do you know it jumped one tooth without the cam locking bar? And more importantly, why did it jump one tooth?
    Keep right pass left, it's the law!!
    Jun 17 2008
    2K S4
    Rockville, MD
    Not sure y it jumped, but my cam position sensor was throwing a "cam in wrong place" code right after I screwed a piece of sheet metal into my timing belt cover to cover the hole left by the old fan assembly. I'm getting the cam lock bar tomorrow and one of my buddies who is a Audi tech is comin over to help. I'm not sure if it only jumped one tooth, but as it ran I doubt it. Idle was slightly off, only I noticed. I'm going to do a compression test tomorrow.
    Oct 06 2004
    Minnesota
    One tooth wont, but it doesn't take much more to give them a nice new shape:
    Instagram r_michals
    Veteran Member Four Rings bigern45's Avatar
    Sep 28 2009
    B5S4 stage 3, B9S5 Sportback
    ky
    Quote Originally Posted by sparkyvw View Post
    lol.. 5 will for sure.. 2 off itll run bad.. 3 off youve def bent a valve somewhere..
    RS6 hybrids and corn
    Dec 06 2007
    Calgary, AB, Canada
    I wouldn't be so sure about that
    OP,
    You have to be really careful about where you insert screws into the TB cover. The TB must have hit the screw and jumped the sprocket. Make sure you check the belt for damage.
    Jun 17 2008
    2K S4
    Rockville, MD
    Quote Originally Posted by The_Jerbel View Post
    OP,
    Thats exactly what I think happened. I'm only 5Kish away from needing a timing belt anyways so I figured just do the full timing belt job now and not worry about it. The timing belt thats in there looks fine, no obvious damage anywhere. Question: at TDC are the cam sprockets wings supposed to be completely horizontal or have a slight angle to them?
    Jun 17 2008
    2K S4
    Rockville, MD
    So am I correct in thinking that if the holes on the cam lock bar match up with the holes on the wings of the cam sprocket the timing is spot on? This is with the crank at TDC.
    Dec 06 2007
    Calgary, AB, Canada
    Yessir.
    Veteran Member Four Rings DiscoPotato's Avatar
    Sep 16 2009
    Delray Beach, FL
    id really suggest to get a camlock bar. Timing is something you cannot mess with.
    Quote Originally Posted by Trigger Happy View Post
    Exactly.
    1996 A4 - Rolled into the woods
    2001.5 S4 - Stolen
    2001 STG3+ S4 - Sold
    2011 M3 - Blown up
    2017 S3 [11.990 @ 112.38mph] - Current
    Jun 17 2008
    2K S4
    Rockville, MD
    Quote Originally Posted by DiscoPotato View Post
    Exactly.
    Where could I get one on the cheap? I would much perfer to just rent or borrow it from somewhere. Anyone in the DC or Altoona/State college area have one that they would lend out?
    Veteran Member Four Rings TWiST's Avatar
    Jun 08 2007
    the timing belt can look fine and still be stretched out, my first timing belt job was done according to the maint schedule I just did my second one at 197,000 miles and after marking everything and putting everything back on it was a hair to the clockwise which shows me that the stretched belt was out of perfect timing, Now she is running great and I have not had any sputters in the drive thru like I was starting to get before.
    Veteran Member Four Rings awd2ks4's Avatar
    Aug 24 2008
    2000 S4, Blown LS2 240sx hatch, LS3 240sx vert, 02 wrx
    Santa cruz
    Purems rents them
    Feb 11 2008
    i am sure on that. As iv done it as the tensonner arm bolt snapped. Had zero damage. Slapped on a new belt arm and bolt fired it up perfectly fine.
    ROTIFORM AIRLIFT
    Dec 06 2007
    Calgary, AB, Canada
    How long did the engine run for after the bolt snapped?
    Sep 16 2009
    Delray Beach, FL
    I would lend mine to you but im all the way in Jersey.
    2001.5 S4 - Stolen
    2011 M3 - Blown up
    Feb 11 2008
    About 10/20 miles then a good half hour sat in the drive on idle trying to find out why it was running shitty and should different when i rev'd it lol.
    ROTIFORM AIRLIFT
    Dec 06 2007
    Calgary, AB, Canada
    hmmm, interesting. So you're sure your belt skipped 5 teeth? That should cause damage...
    Jun 17 2008
    2K S4
    Rockville, MD
    As soon as you hit boost did it sound like your valves were smacking your pistons? Mine kinda sounded like that only more like engine knock, but not really. Kinda hard to explain.
    Feb 11 2008
    Yep as i rang mike at vast in a panic thinking id have to rebuild it after i took the covers of and the left side cam was nearly a quarter turn out.
    Nope the only only reason i knew something was up was the exhaust sound sounded really strange like it was misfiring but it wasnt.
    ROTIFORM AIRLIFT
    Active Member One Ring petracca's Avatar
    Mar 23 2010
    01.5 S4, MB 190E 2.3-16
    Tucson & Berkeley
    Quote Originally Posted by bigern45 View Post
    Yep. And 4 teeth off destroys all 30 valves. That totaled my silver S4.
    Dec 06 2007
    Calgary, AB, Canada
    I think you got lucky.
    Feb 11 2008
    ooo i know i got very very lucky indeed.
    ROTIFORM AIRLIFT
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    these motors are called "interference" for a reason.. sparkyvw is the one whom got lucky. I've never heard of an interference engine that can withstand more than 2 teeth off on a timing sprocket.
    with a 1.8t its a definite 2 tooth limit or pistons will strike valves...
    Feb 11 2008
    Im thinking it has something to do with the different pistons i have in. Thats why i got lucky.
    ROTIFORM AIRLIFT
    Dec 06 2007
    Calgary, AB, Canada
    LOL, yeah, that'll do it. You running low-compression pistons, by any chance?
    Feb 11 2008
    nooooo of course not
    ROTIFORM AIRLIFT
