Results 1 to 4 of 4
    Veteran Member Three Rings BLopes07's Avatar
    Nov 08 2009
    North Jersey
    carbon build up question
    my 2006 a4 b7 is on 73,xxx and the carbon build up has been on my mind and im worried about it. A buddy of mine says autozone and other car places have products that can clean that up. Is that correct and if so which product(s) would work
    and what else should i be worried about ive read that at 75 its a good time to change timing belt and water pump. is that correct?
    thanks guys appreciate help
    [Audi 2006 A4 2.0T]-Revo Stage 2-custom borla exhaust-034 Silicon Turbo Inlet Hose-034 Test Pipe-Oem Piston Diverter-Carbonio-VMR Boost Gauge-v8 coils
    -Full S.Line Conversion-S4 Door Blades-Deval Lip-Oem Titanium Rims--H&R Coils-Titanium Grille-ECS Drilled and Slotted Rotars
    Established Member Two Rings V32's Avatar
    Jan 31 2010
    I actually just got my Timing Belt, pulley, tensioner, water pump changed and I'm at 43k miles. A lot of people had problems early too. If you never got this done before and you're still not having any problems with it, you should just get it checked out. If it's still good then there is no need to waste money on them at this time in my opinion.
    As for the carbon build up, I also got the dealership to do the cleaning service for me. Cost $180. The car run better now. I was missing out. Now it's time for APR trial
    Nov 08 2009
    North Jersey
    so the only way of cleaning the build up is through dealer i guess
    i thought they must have some products to clean that shit up lol
    Jan 31 2010
    This is the thread that talks about Carbon Build up http://www.audizine.com/forum/showth...B7-A4-2.0T-3.2
    Seems like most of the products that you could buy and use yourself won't do much. BG Fuel/Air Induction Service seems to be the best option out there and that's what I got the dealership to do for me. Go here http://www.bgfindashop.com/locator/index.php and see who can do that service for you.
    Mar 24 2010
    Chelsea, MI
    My dealer did it for $120. I have 110k miles and had it done at the same time as the timing belt & tensioners.
    Unfortunately I had some bad motor mounts so it's hard for me to tell what made my car run so much smoother, and my guess is that I just feel less vibration due to new mounts.
    At any rate, you can't really do it yourself, you need to have the air induction cleaning to really get to the buildup.
