Originally Posted by
old guy
All you need to do to adjust the tie rod is to loosen the lock nut and turn the connecting rod. The threaded rod connecting the inner and outer tie rod will rotate freely.
hmm, perhaps that is the missing piece in my understanding.. so that threaded rod will rotate freely within the outer tie rod.. from looking at mine, it looks like the outer tie rod and the threaded bolt are one solid piece. As i was trying to take the lock nut off, it was moving the threaded rod and outer tie rod with it so i thought it was 1 solid piece.. hmm. okay.
so it freely rotates in the outer tie rod, but screws into/out of the inner tie rod.. that makes sense..
