Results 1 to 12 of 12
    Established Member Two Rings P.H.D.'s Avatar
    Feb 01 2009
    B6 denim 1.8t FWD
    Milton
    B6 OR B7 lowest possible ride height stock suspension
    As the title says people i am looking for, i believe, sport springs
    i have a b6 1.8t FWD and it is a 4x4 ! Need to remedy this but i also am not going for a slammed look
    just a nice euro ride height
    pm me with details... im sure lots of guys on coils have this laying around in the garage
    im located in the west end of the gta and obviously would prefer local!!
    THANX FOR LOOKING
    -P-
    Last edited by P.H.D.; 03-24-2010 at 07:56 AM. Reason: corrected spring type and highlighted FWD
    Veteran Member Four Rings headshok2002's Avatar
    Jan 22 2005
    2010 VW Passat Highline wagon
    Sudbury, ON
    Well, I don't think you'll have an easy time finding this because you're FWD and FWD A4's are not very common in North America--certainly not in Canada, anyways.
    I thought I saw a set of Teins but after digging them up in Kijiji they were for a FWD B5.
    And fyi, Ultrasport suspension is no different than sport suspension. The lowest OEM suspension you will find is 2002 Sport. Iirc, though, in 02 Audi used Eibach springs... so you could just buy those. I presume you are currently non-sport so you'd want to find some sport shocks as well (from any year 02-08 I think). Sport shocks are red... again, just fyi...
    Veteran Member Three Rings orangelmo's Avatar
    Jul 05 2007
    Stouffville
    I have my sport springs and shocks from my 03 A4 if you want. Let me know
    Feb 01 2009
    B6 denim 1.8t FWD
    Milton
    headshok2002
    so if i understand correctly the quattro suspension differs from the fwd?
    i just assumed that all b6 and b7's had the same basic set up in just diff trim levels.
    my last vehicle was just stupid low and i am not looking for that...i would be very happy with just the look of the sport suspension for now!
    thank-you for your input
    -P-
    Feb 01 2009
    B6 denim 1.8t FWD
    Milton
    orangelmo
    pm sent
    Jan 22 2005
    Sudbury, ON
    Yeah, you need FWD specific suspension. Anything from a Quattro car will not fit your car. Check any website like hrsprings.com and go select your vehicle... do the same for a quattro and observe the different part #'s.
    If you were to buy coils you could select your own height... I never recommend coils to people who think they're going to raise/lower with each change of season. They usually seize to the point that it is EXTREMELY difficult to change the ride height after a year or two. But for you... they might be perfect.
    Jan 22 2005
    Sudbury, ON
    Quote Originally Posted by P.H.D. View Post
    pm sent
    Haha, in his info it shows him with a Quattro car. They definitely will not fit.
    Feb 01 2009
    B6 denim 1.8t FWD
    Milton
    headshok2002
    pm sent
    which is exactally what i told him...i wasnt sure if they would work and i am waiting to see how this thread pans out!
    lol
    i appreciate all the info though man
    -P-
    Jan 22 2005
    Sudbury, ON
    Glad to help.
    If I come across anything I will let you know.
    I'd definitely check eBay if I were you... as well as some US forums. Lots of FWD A4's in the southern USA.
    Jul 05 2007
    Stouffville
    Turns out they will fit judging by the responses on the board. The differences are in the rear spring rates. The quattro rear springs are stiffer due to the added weight. Some actually say a quattro kit might be more bennificial on a FWD since it should compensate more for if you have heavy loads in your trunk ex. stereo sub system. Again, just what I read from posts on the board
    Jan 22 2005
    Sudbury, ON
    Quote Originally Posted by orangelmo View Post
    That would make sense... would definitely use stiffer springs to control all that extra weight back there. I've only ever heard that they are not interchangeable... perhaps that is not the case.
    Feb 01 2009
    B6 denim 1.8t FWD
    Milton
    hmmmm... the plot thickens!!!
