Results 1 to 13 of 13
    Oct 22 2009
    LA
    Thumbs down went to change spark plugs...broke hood lach from inside..HELP PLEASE
    so i pulled my hood release from inside and it just made a pop noise and broke the cable i'm guessing.
    anyone know how i can get it open and change the cable? any DIYs? i searched and only found ones for the outside latch
    thanks everyone
    a little boom.
    Veteran Member Four Rings gtsingh91's Avatar
    Sep 27 2008
    2005 A4 1.8TQM, 2001 A4 1.8TQM, 2007 350Z
    Long Island, NY
    have a friend push down on the hood and you try to get a grip on the cable from inside the car and pull hard..it should budge but if not you gotta go from underneath and get a loooong screw driver and try to unhook the latch. goodluck
    Instagram: @_vishis
    2001 Audi A4 1.8T Quattro - 5 Speed - Silver
    2005 Audi A4 1.8T Quattro - 6 Speed - Revo Stage II+ - Light Silver Metallic
    2000 Audi S4 2.7TT 6 Speed - EPL Stage II - Hibiscus Red Pearl SOLD
    Dec 19 2007
    York, PA
    so did the cable snap or did the release latch break?
    Oct 22 2009
    LA
    the cable snapped..the release latch isnt pulling anything when i pull it
    anyone know a DIY? or is it really simple to do?..i dont know much about cars and dont want to mess anything up
    a little boom.
    Veteran Member Three Rings rbj325's Avatar
    Aug 12 2008
    Rochester, NY
    If you take off the belly pan and reach your arm up you should be able to work the latch mechanism with your hand or a screwdriver. I've done this before as well.
    E85!
    "I got four cylinders when I need them and four cylinders when I don't"
    Oct 22 2009
    LA
    just looked at the latch inside and wire is still hooked up to it..does this still mean the cable broke from the latch inside or that it broke some where else down the line?
    a little boom.
    Veteran Member Four Rings wolfdog's Avatar
    Nov 22 2006
    I'm not sure if this will help you but here's a picture of the hood release from inside the engine bay facing out. The area circled in red is a plastic holder/cover that hides the other end of the cable. When you pull the hood release, this is the latch connection. There is a DIY around somewhere that uses a screwdriver to release the hood from outside the front BUT I would try reaching up under the car and seeing what you can do to release it.
    2002 A4 TQMS
    Motoza 1+ w/Genesis 380s, 034 HFC, K&N drop-in, 710N, Neuspeed snub, StopTech SS lines w/Hawk HPS, Conti DWS, full Votex, Pioneer FH-X700BT, DDM 35W 4500K HID
    12/23/09 - My car has been phenomenal to me. Runs strong. Don't think I'm ever going to sell it. Rather throw $7k into it for a refresh than buy a new A4 that has no dipstick.
    12/5/10 - 100k miles & counting!
    9/22/13 - 146k+ & running strong w/a new TB, water pump, etc.
    Oct 22 2009
    LA
    will try in the morning..thanks a lot everyone
    a little boom.
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    The best thing for you to do is to remove the front grll. And use a short 10mm wrench and slowly unscrew the 3 acorn nots that hold on the latch.
    Took me like 15 minutes, since its slow, tedious wrenching
    -Sami-
    Oct 22 2009
    LA
    will the grill just come off if i pull on it?
    a little boom.
    Veteran Member Three Rings Carlitos's Avatar
    Sep 17 2006
    B6 A4 1.8T
    San Juan, PR
    best solution for this problem...
    my hood latch has some history in giving me problems and I always solve it with a short 10mm wrench, a beer and a cigarette and just accept that I'm not going anywhere for the next 20minutes.
    PS: this is my first post I think in the last couple of months
    FlexTuning
    Amulet 1.8TM
    BAT#46
    Sep 17 2006
    B6 A4 1.8T
    San Juan, PR
    mine does
    FlexTuning
    Amulet 1.8TM
    BAT#46
    Oct 22 2009
    LA
    alright ill give that a try...so there are just three nuts on the latch?
    a little boom.
