Originally Posted by
cory_can
Since you (or the APR dealer) was in communication with APR regarding this matter is there any way that you could get more details on the issue? You mentioned an ECU code version but you weren't sure of the specifics. Having an APR tuned 2009 model makes me quite interested in this topic AND very leery of going to the dealer....since they have a tendency of re-flashing with "updates" without asking.
I am going to email/call APR tomorrow regarding this issue, and see if they can come up with anything for me. I'm not talking about ECU code version, but the actual unit. I could go ahead and use VAGCOM and pull up the specific model of my ECU so there would be a better understanding in the situation.
off
So at one point the dealer did a factory released reflash your car?
Yes, the ECU was reflash because my car was having random stalling problem, end up it wasnt the engine but the transmission.
DavidB8
Thats crap (sorry for being blunt). I pulled my ECU and there is no way you can tell it was pulled. Well right now you can because I haven't put the new security straps on but there doesn't have to be any pry marks. If they are cutting and ripping them out then they are rushing. Besides there is no law about pulling out your ECU. That wont void your warranty and they still can't tell if there is a program when it's locked. All they can do is look at you in a strange sinister way.
To bad all dealers weren't like the one I got my car from. They had a done up A4 and R8 in the show room and knew all the mods that were out there. Hell they even asked me if I had all the codes I needed for the popular vag com stuff.
If you have an automatic my understanding is that you don't even have the security straps and screws on the ECU which means it's two clips to release the ECU.
Anyways think about what your next step would be but don't let pulling the ECU be your deciding factor.
I'm not talking about the ECU unit itself being removed from the car. I'm talking about after removing the ECU fro m the car, you would need to cut the seal on the ECU lid and pry the lid so you could gain access to the internals of the ECU. (I was told by the APR dealer, not guessing).
