Results 1 to 16 of 16
    Jul 18 2009
    D2 S8, E61 535xi, B5 S4
    Subdivisions, NW burbs
    18 X 8 ET 35 OZ Futuras
    will these work on a B5 S4? Pretty sure spacers (10 mm) will be needed to clear front brakes and to even things out 15 mm out back.
    final ET of 25 / 20 . Will this require rolling and or pulling with the factory set drop of Stasis SS?
    Thank you very much for any help and insight. I really want to make these work, but don't think it will
    Deactivated Four Rings
    Oct 06 2006
    South Bend, IN
    All the OZ models we carry that fit S4 are ET35 with no spacer needed.....have you done a test fit or is that not possible ?
    Jul 18 2009
    nope, not possible. they are in NC and I am in CA. the seller has stated that he had them on a W8 Passat and needed to run spacers to clear the brakes (same as B5 S4). I just don't think I can pull them off w/o fender mods.
    Oct 06 2006
    South Bend, IN
    Yep, at ET20 you'll need to do some work for sure.........
    Jul 18 2009
    Thumbs up
    Thanks for the input, Doc. Still waivering on my decision though.
    If there is anyone else out there with first hand knowledge running these (OZ Futura 3-pc) please chime in
    Oct 06 2006
    South Bend, IN
    Don't have access to the wheel drawings anymore, sorry
    Jul 18 2009
    no worries. thanks for trying though. have not given up on them yet. might just be forced to do some fender mods. personally i like a more aggressive stance anyway
    Veteran Member Four Rings JEmm's Avatar
    Apr 27 2009
    I'm confused why they wouldn't work. 18x8 et 35 is a pretty standard size for b5 a4/s4's...
    -Jeff
    Jul 18 2009
    Quote Originally Posted by JEmm View Post
    from original post: Pretty sure spacers (10 mm) will be needed to clear front brakes and to even things out 15 mm out back.
    final ET of 25 / 20.
    Apr 27 2009
    Quote Originally Posted by happy2B5 View Post
    I know, I got that. I'm saying, I don't see why you should need spacers because that size before spacers is pretty standard for B5's...
    And before you just go out and buy spacers, use some washers and keep stacking them until you clear so you know what to get.
    -Jeff
    Jul 18 2009
    I follow. The Futuras are very flush or flat on the inside and have minimal if any curvature. The seller is going to take his Passat W8 (same Girling brakes as our cars) and show me photos of the brake clearance this weeked. I'll make my final decision from that point. Seller is actually including a set of 10 and 15 mm spacers in the deal anyway.
    Apr 27 2009
    O ok, makes sense then. I'd go for it. Even if you have to roll a little up front I think it'd look even better nice and wide
    -Jeff
    Veteran Member Three Rings Jazzman's Avatar
    Feb 12 2004
    Montreal, Canada
    I had a set on my B6 and they cleared my S4 brakes (not by much but they did).
    Jul 18 2009
    wow, nice! I am pretty sure I am going to need spacers. I took the plunge anyway. They are on the way as we speak.
    Feb 06 2009
    Charlotte
    where is said set of OZ's here in NC ;)
    Jul 18 2009
    yes...please enlighten me. you from ILL INI
