Results 1 to 7 of 7
    Jun 23 2008
    RNS-E Adapter Verification.
    I'm still trying to find what adapters I need for my RNS-E I am purchasing. I have Non-Bose and not sure if I need all 3 of these connectors for my unit to work properly?
    Radio antenna adapter with diversity [50 ohm to FAKRA
    GPS antenna with FAKRA connector
    Symphony II to RNS-E adapter without BOSE
    I searched some OLD AZ threads but still not 100% clear of exactly what adapaters I need. Thanks!
    Dec 06 2007
    Those are all correct.
    I would recommend if u have a roof antenna to run the FAKRA cable to that rather than having an SMD or ISO GPS antenna that is aftermarket. I through experience have found it to be a touch less accurate but it will work.
    -Kirk
    BetaAlphaTau Member #58
    Veteran Member Four Rings Dan1969's Avatar
    Aug 16 2009
    08 Silverado 2500HD 6.6 Diesel
    In the OK Corral
    Quote Originally Posted by AudiA4Turbo22 View Post
    I've had no prob with mine, plus I wasn't looking forward to running the wire all the way to the back of the car.
    OP I believe there's a harness on the classified section.
    17 Jetta S 1.4T, 08 Silvy LTZ 6.6T CCSB
    Previous: 1997 VW Jetta, 2004 Audi A4 3.0Q6MT, 15 Audi A3 2.0T Q DSG
    Jun 23 2008
    Dan, all i've seen are complete RNS-E packages in the classified, if i'm missing something, can you shoot me a PM with the link? Thanks.
    Registered User Four Rings Matt@EuropaParts's Avatar
    Dec 22 2009
    Piscataway, NJ
    Yes, yes, and yes (at least that's everything I have on mine)
    Aug 16 2009
    In the OK Corral
    Yeah, I couldn't find it anymore, it was on there for the longest time, I know someoen will post it again eventually. On the meantime http://www.navparts.com/ sells the parts.
    Jun 23 2008
    Quote Originally Posted by Dan1969 View Post
    Thanks for checking, unfortunately the Radio antenna adapter with diversity [50 ohm to FAKRA] is out of stock, so I guess my unit won't be going in all at once.
