Results 1 to 7 of 7
Thread: Couple Codes
    May 24 2007
    Southern California
    Couple Codes
    I have two codes that I need some clarification with.
    The first,
    P0106 - Manifold / Barometric Pressure Sensor (G71) / (F96): Implausible Signal
    http://wiki.ross-tech.com/wiki/index...0/P0106/000262
    Pretty basic^^ MAP related. My MAP sensor is very new ~1000-2000k miles old. I cleaned it and popped it back in. Will check code again later.
    The second code and the one I need help with,
    P0238 - Manifold Pressure/Boost Sensor (G31): Signal too High
    http://wiki.ross-tech.com/wiki/index...2/P0238/000568
    I can't get a clear answer on which sensor this is and would like to figure it out. After searching, I was getting all types of answers, the majority of them pointed towards the MAP sensor as well.
    Thanks guys.
    Kyle
    2.0L Revo GTRS Eliminator
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Both are referring to your MAP sensor. On certain engine models the G31 MAP sensor and the G42 IAT are incorporated into the same sensor (G71).
    May 24 2007
    Southern California
    Thank you Fletcher.
    Kyle
    Jan 18 2010
    13 S5 QM, 02 1.8T QM (killed by diesel 4x4), 03 1.8T QM, 84 AE 300ZX Turbo, 65 Ford Galaxie Conv
    Fort Worth, TX
    God old guy is good. Maybe we should all send him some money for his beverage fund. Is it beer or Scotch?
    Established Member Two Rings sleeper's Avatar
    Dec 23 2009
    salt lake city UT
    Did a quick search and found this thread, I am having the same P0238 code. Just wondering what I need to replace to clear this code?
    May 24 2007
    Southern California
    MAP Sensor for me. (well actually it was a wire that connected to the MAP sensor harness that was severed).
    Kyle
    Dec 23 2009
    salt lake city UT
    that actually sounds about right, the car was in a front end wreck, i'll head to the shop now and see what i find. As well as take some pics.
