The 01 (AWM) engine has both a map and MAF sensor. And you can't move the MAF to the other side of the engine and expect your car to run properly (I really don't know what would happen if you did that, or even know why anyone would attempt such a task). The MAF is located on the throttle inlet to the turbo and measure the amount of air it takes into the intake. You need this there for your ECU to have proper readings of air to fuel ratio.
The MAF can't and won't compensate for anything (other than it's original purpose). It is simply there to read how much air you are taking into your system. It's just a sensor, but an important one. What you can do, is move the the by pass valve (diverter valve/blow off valve) to the cold side of your intercooler piping. It is supposed to grant better throttle reponse when coming on and off the throttle quickly, due to the blow back having less travel (so, what I was told). And it is in an easier location for service, removal, and so forth. But none of this will grant you any more hp/tq than what you already have. You need to do actual mods to achieve this, and not just move things around.
Adding an larger turbo will grant you more hp/tq obviously, and that seems like what you want to do. I would personally suggest you stay away from the k04-15 turbo, and look for something larger. With an ECU flash for the stock turbo, the AWM (01 motor) will have maybe 25chp less power than that of the k04-15. But there is a substantial torque difference. I would suggest you look into the Eliminator setups, if not going full frame custom.
Clicky Click. With the AWM, you have the option of going MAFless. Meaning you can remove the throttole inlet pipe, things associated with it, and just slap on a filter onto the compressor inlet. This is due to the fact that you have a wideband primary 02 sensor (only in the 01 for the B5 A4) and a map sensor. The drawback is, you will not have precise load calculations at idle. But while cruising, things are all the same (or maybe cruising load differs also???). So, you won't have a clean calm idle. You will also need to do something about your pcv system. Then other things associated with it stays the same, such as tune, larger injectors, different fpr, upgraded clutch, different intercooler setup, etc. Or you can get a tune which requires a MAF and do it just like how all the other B5 A4 guys do it.
My suggestion is to learn more about your vehicle before you jump into modding it. And welcome to Audizine!
