Results 1 to 27 of 27
    Veteran Member Four Rings gearhead1186's Avatar
    Mar 17 2009
    02 S4, 02 M3
    Queens, NY
    034 Fuel Rails/ev14 72lb Injectors/Aeromotive FPR Install
    034 rails...
    w/ ev14 72lbs injectors.
    needed to use spacers to get the rails/injectors to seat correctly.
    Aeromotive 10 micron fuel filter.
    w/ n249
    Aeromotive A1000 FPR
    Established Member Two Rings Mixta's Avatar
    Mar 18 2010
    '97 Caddy Cat
    Atown, PNW
    that is sure some pretty hardware man, looks ALL top notch...72lbs injectors are you running an OE fuel pump also? How smoothly did the install go?
    Edit: 605s...stock fuel pump...um i think i answered my own question hahah
    Tuning shops>Home shops
    Mar 17 2009
    02 S4, 02 M3
    Queens, NY
    Quote Originally Posted by Mixta View Post
    that is sure some pretty hardware man, looks good, tell us how your new delivery system works for you...72lbs injectors are you running an OE fuel pump also? how smoothly did the install go.
    running a drop in bosch 044. only issue was having to use the spacers on the 034 rails in order to get the injectors to seat properly..
    Veteran Member Four Rings Euro-Tuner's Avatar
    Jan 06 2007
    NH
    why the different fuel filter not OEM?
    Mar 17 2009
    02 S4, 02 M3
    Queens, NY
    Quote Originally Posted by Euro-Tuner View Post
    1. uses AN fittings so I dont have to worry about adapting the stock line anywhere.
    2. dont wanna pull the stock fuel filter ever again. this unscrews and u can change the filter inside in 2 minutes.
    3. flows better than a stocker.
    4. its nice looking.
    Veteran Member Three Rings shokwav09's Avatar
    Jul 26 2009
    hhr, 2013 rs5
    kansas city, missouri
    Quote Originally Posted by gearhead1186 View Post
    i say whose got some nice components for 2.7's is synapse. theyre blow offs and feul pumps are suhweeeet
    Veteran Member Three Rings sparkyvw's Avatar
    Feb 11 2008
    B8 avant,964,B5 wb s4, mk2 vr, mk3 vr
    Palm Beach Gardens FL
    very nice. Something i need to do.
    Cloud9Helicopters South Florida
    ROTIFORM AIRLIFT
    Veteran Member Four Rings BlkdoutS4's Avatar
    Jun 22 2007
    2001.5 S4
    Santa Cruz, Ca
    looks baller... nice work man!
    '01.5 Silver B5 S4 - Follow my build here: http://www.audizine.com/forum/showth...4-Build-Thread
    Veteran Member Three Rings 2kblacks4's Avatar
    Jan 04 2007
    2000 black s4 6spd
    Birmingham Al
    How much was all of that?
    4:11 posi track out back, 750 double pumper, edelbrock intakes, bored over 30, 11 to 1 pop up pistons, turbo jet 390 horse power, where talking some fucking muscle!!
    Mar 18 2010
    '97 Caddy Cat
    Atown, PNW
    Quote Originally Posted by 2kblacks4 View Post
    Considering everything is made out of Expensivium/Unobtainium....alot? Compared to what hes got already into that swheet motor, just a drop in the bucket im asuming
    Veteran Member Four Rings imola's Avatar
    May 23 2007
    Ok, so what part of the car is NOT painted or powdercoated? :) Looks freaking amazing
    sold :(
    Sep 11 2009
    NE
    Damn, that looks super-neat. That rat's nest above the intake manifold sure is a sore in the eye on stockers.
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Looks great!
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Veteran Member Three Rings GarbatyA4's Avatar
    Aug 10 2007
    Ontario Canada
    I'm really liking the aero quip hoses... looks to be so much easier than the edlebrock stainless braided sh!t.
    Do they come in different colours?
    2012 Audi Q5 - Daily (slow AF)
    2013 Mini Cooper S - sold
    2005 BMW 325Ci - sold
    2007 BMW 335i - sold
    2004 VW Golf TDI - sold
    2004 Audi S4 V8 Cabriolet - sold
    2003 Audi A4 1.8T - GT2871R - sold
    2000 GMC Sonoma - sold
    1992 Dodge Stealth RT - sold
    1991 Chevrolet Beretta GTZ - sold
    Established Member Two Rings mhorsfield89's Avatar
    Dec 02 2008
    Durham, NC
    looks super clean.
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    one of your FPR vac lines looks kinda worn
    are you going e85 tuned?
    Mar 17 2009
    02 S4, 02 M3
    Queens, NY
    Thanks for all the kind words.
    I'll put together a list of the parts and the cost when I get a chance..
    Quote Originally Posted by GarbatyA4 View Post
    Yea, the stainless braided lines are overdone in my opinion. wanted to go for a different look. they only come in black and blue.
    Mar 17 2009
    02 S4, 02 M3
    Queens, NY
    Quote Originally Posted by ThirdStrike View Post
    Yea the protective weaving has seen better days but the hose itself is ok. it leak tested ok but i will replace it b4 getting tuned. i wish i had E85 around me. my stock rails were beat up from the previous owner. it looked like he used a screwdriver and a hammer to force seat the injectors and rails... so instead of paying for a new stock rails, I decided to upgrade..
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    yea the protective weaving has seen better days but the hose itself is ok. It leak tested ok but i will replace it b4 getting tuned. I wish i had e85 around me. My stock rails were beat up from the previous owner. It looked like he used a screwdriver and a hammer to force seat the injectors and rails... So instead of paying for a new stock rails, i decided to upgrade..
    20% IDC's FTW
    at what return pressure are you going to set on these things?
    Mar 17 2009
    02 S4, 02 M3
    Queens, NY
    20% IDC's FTW
    right now I have the FPR set a tad over 40psi which is equivalent to the stock 3 bar FPR. the big benefit of the ev14 injectors is that they are tested at 3 bar so there is no need to bump pressure. adjustability is never a bad thing, so if bumping the pressure helps the tune/IDC... it will be bumped higher.
    Veteran Member Three Rings sfored's Avatar
    Dec 30 2004
    Have you fueled the system yet ?
    I had pinhole leaks on the connectors where the AN meets the rail. copper washer etc.. still leaked..
    Mar 17 2009
    02 S4, 02 M3
    Queens, NY
    yea, ive driven the car already. no leaks. you are leaking between the rail and the AN coupler? you should be using an o-ring, not a copper washer.
    Jul 26 2009
    hhr, 2013 rs5
    034 rails...
    w/ n249
    you could make the feul system a return line setup too couldnt you?
    Senior Member Three Rings BlackS4TT(Josh)'s Avatar
    Jan 24 2006
    Ohio
    Is that FPR installed correctly? Looks like the outlets of each fuel rail go into the FPR. Where does it bleed fuel pressure to? Is there a return port on the FPR we can't see in these pics?
    B7 S4 Avant
    Mar 17 2009
    02 S4, 02 M3
    Queens, NY
    Quote Originally Posted by shokwav09 View Post
    Quote Originally Posted by BlackS4TT(Josh) View Post
    it is a return system. the line on the bottom of the FPR taps into the stock return line.
    Jan 24 2006
    Ohio
    Oh ok. I only saw two ports on the FPR in this pic, so i was confused. Thanks for the clarification.
    B7 S4 Avant
    Jul 26 2009
    hhr, 2013 rs5
    i thought so. i wasnt paying attention to your pics until after i posted. damn my hyperness
