As some of you AZ members may know, I have been having issues with my car lately. I'd like to thank those who have helped me thus far. Much appriciated. Here is my problem.
Recently I have installed a new OEM head gasket. Compression on the car ('01 A4 1.8T QM) is within spec.
Cylinder head was rebuild and the re-faced and inspected for cracks. Cylinder head bolts (ARP bolts) were torqued in sequence.
The instructions that came with the ARP bolts set were: Stage 1: 45ft-pounds and Stage 2: additional 90 degree turn. Did exactly that.
This is the 3-rd time I change the oil already. Yesterday, while I was at it, I decided to take off the hoses that go to the oil cooler and loop them together to bypass the cooler. I thought that was the problem as before:
http://www.audizine.com/forum/showth...ht=eurotecknik
Well, I idled the car in the garage after changing the oil and bypassing the cooler for about 30 minutes and then turned off without driving it. Oil was fine at that point. Today (the next day) I decided to take the car around the block, and upon coming back home (5 minute drive max) I checked the oil. The dipstick was looking like there were signs of mixing again so I drained my 1 day old oil. Basically, it was looking the same as the picture I have from my old thread. I also see that there is some small amount of oil in the coolant.
My motor is all stock internally and has 89K on the clock. FYI, the head gasket was installed the right way with the VW/Audi logo facing up and on the intake side.
I have ruled out the oil cooler. What else could it be besides the block being cracked internally somewhere between the passages? I mean what are the odd of that being the case? I have never tracked the car. I have had my GTRS for a 1.5 years at 20PSI. But I haven't had much fun with it because my clutch started slipping real bad shortly after.
Any insight into my situation would be great. At this point I am not sure what the next step with my car would be.
Thanks again.
