Results 1 to 21 of 21
    Aug 28 2009
    04 S4, 93 RX-7
    Ebay FMIC better than stock ic for gt28rs?
    I did a lot of searching on this topic and from what I have gathered the boost brothers fmic is decent up to k03 sized turbos. I was wondering what about a gt28rs. I know optimal would be one of the bigger more expensive fmic's but that is not an option right now and won't be while owning this car.
    The a4 is my daily, I have a track car that sucks up most of the mod funds. I am just trying to figure out if buying one of these cheap fmics will give me decent gains for the daily commute.
    Dec 01 2007
    Orange County, NY 10918
    what about RACE TECH or ASP FMIC? They should be sufficent, usually can find a cheap fmic in the classified section.
    C6A6 3.0t Avant
    @avantneil
    @avantoberfest
    @skiguardusa www.skigaurd.com
    Veteran Member Three Rings f15046's Avatar
    Oct 30 2007
    Griffin, GA
    I ran a Ebay core on my A4 with a GT2871r, it did fine and keep the intake temps down, could I have benefited from a better intercooler? Probably. But for $200 bucks the Ebay intercooler and piping kit worked just fine.
    I do work around the South East on your 1.8t or 2.7t, PM for more info
    ** 2001 A4 TQM
    -Fully built 2.0, GT3076, SPA mani, custom 6-puck clutch, Unitronics tune, Walbro 255, and much more
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    with the price of those, he might as well get a larger garrett core. not only will it be larger, but it will be more effecient as well.
    OP, the Ebay coolers(larger ones) will "work" but they will not be optimal.
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Aug 28 2009
    04 S4, 93 RX-7
    Thanks for replies guys. I will have to start watching the classifieds for a used kit.
    My main question was is one of the eBay kits worth $300 or whatever they are vs. keeping the stock one with my setup.
    Oct 30 2007
    Griffin, GA
    You can heatsoak the stock IC with the stock turbo, so with the GT28 you are going to need something better.
    ** 2001 A4 TQM
    Veteran Member Four Rings MmmBoost's Avatar
    Nov 29 2005
    10 A4 Avant S-line, 07 Suzuki GSX-R600, '69 VW Beetle w/ 1.9L aircooled turbo
    Edmonton, AB
    If you have an Ultrasport, I wouldn't go any thicker than a 2" core. I just fit my Racetec intercooler this weekend and it BARELY fit between the rad and the bumper rebar. In fact it was touching....so i stuck some thin strips of rubber between the two so they don't rub.
    ~Chris
    I sold my Audis and bought a Touareg... Catch me over at Club Touareg
    My B6 Avant GT2871R build
    Tumblr
    "Robert Bosch don't fuck around"
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    Spend about $50-$100 more than the BB FMIC and get this plus some piping and t clamps
    http://cgi.ebay.com/ebaymotors/TRV18...item3ef92d23ff
    2019 SQ5 Prestige
    Dec 06 2007
    ^^Treadstone sells better cores for less than that seller.
    -Kirk
    BetaAlphaTau Member #58
    Jun 25 2007
    San Jose, CA
    Quote Originally Posted by f15046 View Post
    Are you running the boost brother kit off of ebay?
    GTRS | Samco DV | FMIC | S4 Door Blade| S4 Brake| Podi Gauge | ST coilover
    Active Member One Ring h2o-pr00f's Avatar
    Oct 29 2009
    Arcadia, CA
    Quote Originally Posted by texasboy21 View Post
    Quote Originally Posted by AudiA4Turbo22 View Post
    Has anybody on here done this yet? Taken a treadstone core and put together their own set up?
    Veteran Member Four Rings manhertm's Avatar
    Jan 21 2007
    "Old Yella"
    san antonio tx
    I think I'm gonna get the BB FMIC, sell the core and get a better core that fits the same dimensions. That's way there's no fab of any kind, just a direct swap. You could still have a Racetec, quality FMIC for under $500. Plus I could probably just sell the BB core in the classifieds for about $75-100.
    ThetaAlphaThetaMember#1
    MY CAR IS ON AN EBAY BUDGET!! DEUTSCH REIS!
    Sep 12 2008
    South Central PA
    Quote Originally Posted by h2o-pr00f View Post
    im in the process. i have a treadstone TR10 setting in the garage right now. but im not going to bother until i drop in rods and get the new turbo setup
    EFR | 7163
    268/260 cams
    I.E. Intake Manifold / 70mm
    BoostManager+
    Meth Head
    Sep 12 2008
    South Central PA
    Quote Originally Posted by leonbtwo View Post
    i am. as long as you dont go WOT thru more than 2 gears, its fine.
    EFR | 7163
    268/260 cams
    BoostManager+
    Meth Head
    Sep 12 2008
    South Central PA
    Quote Originally Posted by manhertm View Post
    im selling a BB FMIC kit...
    EFR | 7163
    268/260 cams
    BoostManager+
    Meth Head
    Jan 21 2007
    "Old Yella"
    san antonio tx
    Quote Originally Posted by Dan[FN]Shank210 View Post
    PM me with a price.
    Sep 12 2008
    South Central PA
    PM me with a price.
    YGPM
    EFR | 7163
    268/260 cams
    BoostManager+
    Meth Head
    Oct 29 2009
    Arcadia, CA
    Interested to see the difference after you change cores
    Sep 12 2008
    South Central PA
    ill post it when it all goes down
    EFR | 7163
    268/260 cams
    BoostManager+
    Meth Head
    Sep 17 2006
    SLC, UT
    bingo!
    this is where everyone mis-interperetes. everyone does one gear pull or maybe two and they see they still have low IAT's. some will even do this in january
    but you do wide open spirited run through a canyon with multiple minutes in WOT and then tell me how your small shit-tastic core does for those IAT's in the July heat.
    Current:
    Previous:
    Sep 12 2008
    South Central PA
    Quote Originally Posted by sean1.8t View Post
    bingo!
    its not good George, its not good.
    lol ask me how i know
    EFR | 7163
    268/260 cams
    BoostManager+
    Meth Head
