Results 1 to 18 of 18
    Established Member Two Rings rmv6's Avatar
    Aug 05 2009
    2001 Allroad
    Grand Rapids, MI
    drive shaft drama
    i need a new center drive shaft, or to rebuild one. i see that blauparts has a rebuild kit for 399. any one know the prices of a new one or where to get one? it seems that 400 oughta be close to the price of a new shaft. i'm trying raxles.com but they seem to think i'm talking about one of the front axles
    Veteran Member Four Rings awd2ks4's Avatar
    Aug 24 2008
    2000 S4, Blown LS2 240sx hatch, LS3 240sx vert, 02 wrx
    Santa cruz
    What are your symptoms?
    Jan 29 2007
    08 S4 00 S4
    MD
    Try to clarify with raxles what exactly you need. A new propeller shaft is like 1300 bucks. Blau's rebuild kit looks like a reasonable alternative though, assuming you aren't paying for labor.
    08 S4- Stock SOLD
    Established Member Two Rings x610326's Avatar
    Jun 27 2009
    2001 Audi S4 B5
    Streamwood, IL , 60107
    try this. maybe they will help. they are very good company. http://www.advancedautomotion.com/pr...products_id=43
    Veteran Member Four Rings Tiluleshpingen's Avatar
    Nov 14 2006
    97 AS4 ,08 A5 MKVI Jetta
    Land of the Eagles
    get a used one ebay or classified why pay for a new ?
    GIAC-X, STASIS TS,VAST,034 MS
    Account Terminated Four Rings
    Sep 18 2009
    Andrews
    Got a used one cheap just PM me.
    Aug 05 2009
    2001 Allroad
    Grand Rapids, MI
    thanks guys, what i have right now is a general rattling and clunking coming from back end of tranny, right between front seats. only at low rpms and when going into 1st or 2nd gear. the noise is worse when i turn. also have a slight vibe from the same area at highway speeds. got under there and wiggled things a bit and that front cv is quite sloppy. labor won't be an issue as i'll do it myself. anyone have any experience with the one piece drive shafts (advanced auto link above) with any fitment issues?
    Jan 29 2007
    08 S4 00 S4
    MD
    The center bearing is ok? If it's just slop in the front CV joint on the driveshaft where it connects to the transmission, just change that.
    08 S4- Stock SOLD
    Dec 06 2007
    Calgary, AB, Canada
    Did you try wiggling the shaft bearing to check for play?
    Aug 05 2009
    2001 Allroad
    Grand Rapids, MI
    i didn't get to the bearing yet, but the front cv is sloppy. would the bearing wreak havoc and manifest as the play coming all the way up in the front of the shaft? those cv's seem to be kind of pricey, and if it's only a matter of a hundred bucks more for a decent used or rebuilt setup i think i'd be better off going that route. ( i do have to remove the heatshield to access that center bearing right?)
    Dec 06 2007
    Calgary, AB, Canada
    Yessir.
    Feb 02 2009
    Cars other people killed
    capital city wastes
    a loose driveshaft is a terrible thing. it happens on old bimmers where it will graciously inform you its center bearing is broken by banging into your floor until it gets fixed.
    by the front cv being sloppy is it rotational play? up and down play? in and out(hehe)? it could have been damanged by a bad output bearing on the trans or pinion bearing on the rear. or age. they dont go bad too often under normal driving conditions, not sure about racing.
    Aug 05 2009
    2001 Allroad
    Grand Rapids, MI
    it's got rotational play, and up and down play
    Aug 06 2008
    Canadia
    anyone know where you can buy just a U-joint for the shaft?
    the B5 S4 is like the mafia... there is only one way out!
    Veteran Member Four Rings Raacerx's Avatar
    Mar 22 2009
    ex B8.5 SQ5, ex 8V S3, ex 8P A3 VR6, ex B5 STK S4
    Norcal
    replaces the troublesome factory double joint
    The Best Things in Life Are Free... Or Heavily Discounted!
    May 06 2004
    W124s
    PA
    ONce was in the same boat... rediculous noises under the car out of the blue. Almost pulled the trigger on a new driveshaft but they were out of stock/backordered and I'd have to send mine in for a rebuild/core. So I pulled it out to find both front and rear joints were basically dry- the grease was hard and waxy. I cleaned them out didn't find any damaged balls or anything so I put some new grease in there and threw it back together. To my surprise thats all it took to fix it. and now almost a year later noise and vibration are still gone.... knock on wood
    Blau has driveshaft parts as well. If you call them they have all the seperate parts available as well
    http://www.blauparts.com/proddetail.asp?prod=F5C1112
    Keep right pass left, it's the law!!
    Jun 27 2009
    2001 Audi S4 B5
