Results 1 to 11 of 11
    Established Member Two Rings snowplow's Avatar
    Jan 21 2009
    Philadelphia
    Bad o2 sensors cause of turbo issue?
    my two front o2 sensors are trashed they have been throwing codes for a very long time, my MPG is acting weird, im trying to think what could be making my turbo scream like it is and make my car not pull like i was. also i found out the ECU i bought was for a triptronic would that make a difference also? is there anything i can do to figure this out? i tried recording the sound of the turbo but couldnt due to poor quality of my camcorder, also i have some back fire when i rev up and the rpms start to fall i have some popping not too loud, really need some one local and qualified to help a fellow AZ guy out. please PM me if your in the philadelphia area!!!
    2000 stage 3- Audi S4
    Veteran Member Four Rings KNaudi's Avatar
    Jan 11 2009
    B5 S4, C6 S6
    Chicago and IN
    why haven't you replaced the 02s that control your fuel/air mix? of course you are going to have weird mileage (by weird, I'm guessing you mean terrible)
    My WTB List:
    -Sport (all black) shift surround for 6MT
    -Sport (all black) ash tray cover
    KNaudi's story
    Veteran Member Four Rings NOTORIOUS VR's Avatar
    Jan 29 2009
    Quote Originally Posted by snowplow View Post
    Sounds like it's finally time to reach into your pockets.... neglect is the last thing you want to do with the B5 S4.
    Buy a VAG-COm cable, pull codes and post, change the O2's, pull the plugs and inspect/change, pressure test and inspect the charge system.... That's the minimum.
    Veteran Member Three Rings lbs4's Avatar
    Jun 14 2009
    01 S4.99 Grand Cherokee.89 240SX
    Vermont
    the screaming your talking about is probably your turbos going. id stay out of boost until you get new ones
    Jan 21 2009
    Philadelphia
    Quote Originally Posted by lbs4 View Post
    i just put ko4 in 500 miles ago
    Sep 16 2005
    Asheville, NC
    Dude, PLEASE tell me you've pressure tested?!? A bunch of people took the time to give you advice in your last thread. Do it...it takes 10 min to build a tester.
    2000 S4 - SSP tuned Stage 3
    CrtchRktRcr: You could turn it into a unicorn with a gigantic pink dildo and i'd still love a b5s4.
    Jan 21 2009
    Philadelphia
    Quote Originally Posted by drkenan View Post
    ill do it now, how do i build one?
    Jan 21 2009
    Philadelphia
    id do it right now if i knew how to build it
    Jan 29 2007
    08 S4 00 S4
    MD
    08 S4- Stock SOLD
    Jan 29 2009
    Senior Member Two Rings xmoox's Avatar
    Aug 11 2008
    2000 audi s4
    Portland OR
    dude thanks I've been wondering how to do that
