Results 1 to 7 of 7
    Jul 08 2009
    Wisconsin
    Where to jack a 2008 A4 vs. using "widowmaker"
    I have a 2008 A4 2.0QM, and just swapped my winter tires for my summer's. I used the little jack that comes in the trunk which is a bit scary. Is there a place I can place a floor jack to jack the car up that won't bend the pinch weld area that the factory jack uses. Or put another way, when the audi dealer puts an A4 on the lift, where do they lift it from? Thanks!
    Veteran Member Four Rings Tusin's Avatar
    Mar 16 2009
    Anchorage, AK
    I put a hockey puck on my floor jack and use the pinch welds. It does still beat them up a little though. What I still need to do is cut a 1/4" groove into the puck. And the dealer will lift your car via the pinch weld as well, but they have pads with grooves cut into them.
    You can also jack it up via the subframe (where it bolts to the chassis). Do a search on the B6 forum for jacking locations (our cars are pretty much the same in that respect).
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    read the manual, it explicitly states the locations........
    .... and do yourself a favor and invest in 80 floor jacks/stands....
    Jul 08 2009
    Wisconsin
    What are "80 floor jack/stands"?
    Veteran Member Four Rings akasch's Avatar
    Jan 30 2008
    Santa Clara, CA
    Quote Originally Posted by ilmonster View Post
    one floor jack, and two jackstands that cost about $80
    Veteran Member Three Rings felondnb's Avatar
    Jan 12 2008
    London, UK
    I can't get a conventional trolley jack under my car without using the OEM little jack to raise it up enough to slide the trolley under. I need one of those slim profile trolley jacks - the place I had my tyres fitted recently had a couple & they did the trick.
    Phantom Black Audi A4 2.0T FSi Quattro S-Line Special Edition
    Jun 15 2011
    East Bay of SF, CA
    Holy thread revival but best one to answer my question: would this set from Sears be a decent replacement for the widowmaker? I changed a flat in my garage over the weekend using the one in the trunk and the ****** buckled, scraping the shit out of the driver's side front. Funny thing was I could sense it slipping and actually tried to hold the car up with one hand while lowering the jack with the other!!! So want a new jack and jack stands:
    http://www.sears.com/shc/s/p_10153_1...3&blockType=G3
    Any issues with this and the pinch weld used on the 08? Best location to place jack stands for working on the front of the car? Other recommendations?
    Thanks for assistance
