Results 1 to 36 of 36
    Veteran Member Four Rings EUROaleksey's Avatar
    Aug 10 2007
    Toronto, Ontario
    Exclamation Problems with Unitronic Stage-II file...
    so im at HS Tuning right now.. i had Unitronic stage 1+ flash for a week and the car ran great, spiking 18psi and holding 17psi through every gear... Today we swapped the injectors to tt225's, and flashed my car with stage 2 file.... went for a test drive - im spiking 15psi and holding 14psi..... Jeff (HS Tuning owner) talked to someone at Unitronic and turns out there was a ecu revision something something..... we flashed my car again with revised file, went for a test drive, and im still spiking 15 and holding 14..... called Unitronic guys but noone answers anymore, cause its 6 pm....
    guys who have stage II, did u have any issues like this?... do u have any input at all?...
    maybe someone from Uni is online?.. i need help guys... its a 3 hour drive 1-way for me, its really becoming a pain in the ass..... we emailed boost-logs to Lavi at Unitronic but we havent got a response yet....
    as of right now we're flashing my car back to stage 1+ and swapping the injectors back... im kinda dissapointed, but we still wanna figure out why its doing what its doing...
    any help will be greatly apreciated...
    Aug 10 2007
    Toronto, Ontario
    bump
    Jun 22 2009
    Dundalk, MD
    hey man, I'll check on this Monday for you
    Aug 10 2007
    Toronto, Ontario
    sounds good... next time im gonna drive down there will be next saturday, so no rush... i apreciate it Clint the guys at HS Tuning will also try to figure it out..
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    log requested vs actual boost (block 115) and post it up
    2019 SQ5 Prestige
    Veteran Member Three Rings davidlizard's Avatar
    May 01 2008
    2004 A4 ultrasport 6speed
    Winter
    sorry for you, I can't help but I can say that I've never had any issues with my Uni's stage2 and it's most often peaks at 20-21psi... good luck!
    Unitronic stage 2+ / Borg Warner K04 / Milltek / ATP 3" testpipe / Racetec FMIC / Forge TIP / Carbonio / Forge DV / 386cc / 034 25mm rear sway /Joey moded / Podi / JHM 350mm BBK & SS lines / STaSIS street sport/ Michelin Pilot Super Sport / ECS Tuning lightweight flywheel + RA4 clutch kit /
    034 engine & trans mounts / 034 snub mount / 034 front & rear link / Apikol rear diff mount / JHM solid short shifter
    Aug 10 2007
    Toronto, Ontario
    texas boy, logs are on hs tuning's laptop, ill get them... but requested and actual numbers were way off... ill post them in a day or two.. thanks anyways, ill keep u posted..
    david, thats whats f*cked... 100% of people gave only positive reviews... looks like im the 1st one to have issues.. but im sure we'll get it resolved this coming week..
    Veteran Member Four Rings a4darkness's Avatar
    Dec 01 2007
    San Jose CA
    Damn, that sucks. Seems a bit of of character for Uni... their off the shelf files are usually pretty plug in play.
    /awaiting updates
    Apr 01 2007
    houston texas
    Quote Originally Posted by EUROaleksey View Post
    you probably have a boost leak that started the day you got an upgraded flash. I was pushing 18psi for 3 years on my diode mod set up with zero issues and the day i got REVO my jet suction pump went bad. Im sure something similar is going on in your case
    2019 SQ5 Prestige
    Senior Member Two Rings deltaforcehall's Avatar
    May 07 2007
    1988 VW GTi 16v (sold), 2003 Audi A4 BT Elim Uni 630cc (sold)
    Lakewood, Ohio
    Hmmm I am eager to see how this pans out... as Jeff is supposed to have Unitronic do my software for my big turbo a4..
    Jul 14 2009
    Pasadena
    too many people have been having undoubtable problem with unitronic....being in Canada and not easily reachable they need to step up their game. work on customer service and move to america where the real fucking business is. no offense the rest of the paying world
    anyways back to real topic of the thread check all lines first go back to stage 1 see what happens and then if all else fails hit up uni
    IG: @matthewee
    Account Terminated Four Rings
    Feb 12 2009
    03 Audi A4 1.8T
    East Coast
    reason y i went Revo
    Jul 14 2009
    Pasadena
    me too
    IG: @matthewee
    May 07 2007
    Lakewood, Ohio
    Quote Originally Posted by itsmatt33 View Post
    I emailed them 3 times in a week with no reply asking information on their big turbo products from two different emails just to make sure spam wasnt catching them
    I think in the end this will prob turn me to another company such as Revo as well unfortunately - I hear their customer service is bangin and they know wtf they are doing when it comes to some gtrs elim kits
    Jul 14 2009
    Pasadena
    revo customer service is amazing trust from me .....i dealt first hand
    IG: @matthewee
    Senior Member Three Rings Greek Yayo's Avatar
    Aug 14 2008
    Audi A4 1.8T
    Suffolk, New York
    ima about to get injectors in and stage 2 flash... i have stage 1+ and im spikin 17 holding 16... hope the software for stage 2 isnt F**ked up for me as well
    SpooledYu
    Jun 22 2009
    Dundalk, MD
    The problems are mostly the fact that they do things that most other companies do not. All of their files are awesome.
    OP, did you ever figure out your problem?
    Aug 10 2007
    Toronto, Ontario
    no still havent.. we emailed boost logs to uni, requested and actual numbers were way off... still waiting for an answer :-/
    my N75 is fine, and i know its not a boost leak, cause as soon as we swapped injectors back and flashed it back to 1+, im spiking 17 and holding 16 again... so its gotta be the file itself..
    its too early to bash Uni for this, the only thing - i wish they worked a little faster as far as getting back to customers about problems/question.....
    Aug 10 2007
    Toronto, Ontario
    ill touch you :P
    Feb 12 2009
    03 Audi A4 1.8T
    East Coast
    ill touch you :P
    LOL..... if its with RS4s OK
    May 07 2007
    Lakewood, Ohio
    you an me both , i wrote them 2 emails and pm'd then on vortex a few times as well still no reply, i'll prob go revo route, as I got in touch the first time and someone talked to me and informed me of some things as well
    In Limbo Four Rings
    Sep 27 2006
    2005 Audi B6 1.8t Ultrasport
    New Jersey
    I don't get why yu guys don't follow up with a phone call. Write the email, no response then call! Everytime I cal tech @Uni they are there giving great support.
    Jun 22 2009
    Dundalk, MD
    Quote Originally Posted by deltaforcehall View Post
    have I not been responding quick enough?
    To the OP, is your requested where it should be?
    Jun 22 2009
    Dundalk, MD
    May 07 2007
    Lakewood, Ohio
    Quote Originally Posted by [email protected]. View Post
    Clint you are rock solid dude.... And answer any question I have had for you! I'm talking about emailing/calling Unitronic themselves... I've had no luck at all getting a call back or email back
    Veteran Member Four Rings IVRINGS's Avatar
    Mar 27 2009
    Columbus, Ohio
    This sucks to hear since I want to send my ECU out for Stage 2 and immo delete.
    Aug 10 2007
    Toronto, Ontario
    well a week later - no news from uni, and no calls from HS Tuning... things are looking awesome :-/ going to actually call unitronic monday.. but most likely they'll say "its a hardware problem" and ill be stuck with stage 1+ since i dont think they'll give a refund.. (would be awesome though)
    In Limbo Four Rings
    Sep 27 2006
    New Jersey
    uni gives a full refund if you come back in 30 days
    i still dont get the problem youre having.
    i wanted to go stage 2+ as well but this kinda sucks.
    May 07 2007
    Lakewood, Ohio
    sometimes jeff takes a long time to get back with you, but he usually always does though. I am waiting on hearing from him too. Don't feel bad.
    So you got charged? Even thought the shit didn't work!?
    Aug 10 2007
    Toronto, Ontario
    for stage 1+ yeah i did get charged.. for stage 2 is was an extra 100 which i didnt have to pay since it didnt work... but im gonna try and get rid of 1+ as well and get my money back and go to revo.. uni just lost a client.. all cause some numbnutts is runnibg communications department..
    Apr 01 2007
    houston texas
    ^^haha well thats business
    2019 SQ5 Prestige
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    Wish all the <insert name brand> fanboy bashing would stop and actually try to understand what the problem is and how it can be fixed. It would be useful information that could benefit everyone.
    USP CLUB MEMBER #34
    Jul 14 2009
    Pasadena
    revo spring special for the win!
    IG: @matthewee
    May 07 2007
    Lakewood, Ohio
    Quote Originally Posted by CyberPMG View Post
    I think he's bashing <customer service> and not <insert brand name>
    jus sayin..
    I'm sure its something dumb w/ the file that can be fixed once they get in touch w/ you alexsy
    Oct 08 2009
    Mass
    So what ever happened with this? A whole lot of problems on this forum and not many solutions.
