Results 1 to 28 of 28
    Veteran Member Four Rings viziers's Avatar
    Jan 27 2007
    2005.5 A4 2.0T, 07 A4 Sprint Blue
    NC
    My intake valves after 134,000 miles....
    I'm very pleasantly surprised and happy that my valves look this good!!
    vizi
    05.5 B7 A4 longest running with no motor issues at 373whp
    Car:Custom JRP Mani & DP, GT3076, FWD to AWD conversion, IE 144/20, Wossner 83.5mm 9.2:1Cr, CM FX400, Ported Head Ferrea valves, EJ VC, EJ S3 Dv Flange, Custom STASIS Exh, Precision 600hp FMIC, RS4 injec, Tial 38mm, 034 SD mounts, Apikol Rear Diff, RS4 Sway, APR Snub Mnt, DO 4 port w/m direct inject, HPFPUpgrade 142bar PRV & StgII HPFP, 1.8 oil pump conv, Crnk dowel pin
    Absolute Automotive Tuned to 373+awhp @23.5psi (Corrected)
    Veteran Member Four Rings B72.0T's Avatar
    Dec 18 2009
    2015 Q7 TDI S-Line Prestige, B8 S4 6MT
    Pennsylvania
    Damn they look good :D
    Jan 27 2007
    NC
    Yea, I figured I was going to be cleaning them for hours....
    vizi
    Veteran Member Four Rings Geoffafa's Avatar
    Aug 31 2007
    The Big Blue Bitch and her mess
    Miami
    Doesn't look bad at all. I just hit 75k on my car and I think around 100k I'm gonna be taking the head off, sending it to get decked and cleaned and dropping ferrea valvetrain in there. Just because its already out. Then the fun starts
    F.T.W.L.T.B.D.W.I.C.T.W.
    IG | @fukn_fafa
    So air is like the hot girl that is no fun in the sack, and good coils is the cute girl that is crazy in the sack. -chrislane
    Jan 27 2007
    NC
    Quote Originally Posted by Geoffafa@Wolfcars View Post
    I wouldn't mind doing the valve train.. Maybe someday....
    vizi
    Veteran Member Four Rings Tusin's Avatar
    Mar 16 2009
    Anchorage, AK
    What have you been running? Catch Can and WM? Or stock? I now now your have a full build going on, but before all that:) Cause those look damn good.
    Jan 27 2007
    NC
    No catch can or W/M the only thing I have used is the BSH stg1 and I only installed that at roughly 111,000 miles...
    vizi
    Veteran Member Four Rings Tanner's Avatar
    Markham, ON
    Okay that is pretty impressive for that mileage.
    What's your driving style? I'm guessing you don't do a lot of short commutes or quick drives where the engine barely warms up?
    Mike
    Jan 09 2009
    FL
    not bad at all
    Jan 27 2007
    NC
    That is correct, I drive 135 miles round trip to work 3 days a week. I also only use the castrol synth oils the dealer uses and it gets changed at the 8k to 10k mark. We will see how that works with the new build....
    vizi
    Jan 27 2007
    NC
    Naw man not bad at all.. Ive been VERY lucky with this early 1st production model A4. I don't burn even a drop of oil at all.........Its one of the reasons I will never sell the car considering all the trouble I hear about others with problems.... The only thing of inconvenience to me is that damn P0089 code which I hope gets taken care of with the new HPFP.
    vizi
    Markham, ON
    Quote Originally Posted by viziers View Post
    Thanks vizi, that seems to reinforce the idea that cars driven for very short commutes will end up seeing this problem much earlier vs long commutes.
    Mike
    Mar 26 2007
    Colorado
    great i drive only 8 miles a day.......
    Jan 04 2010
    Jeep Wrangler, VW Atlas
    Southeastern, CT
    this positive post gives me at least some hope. I'm tired of hearing all the negative threads.
    Jan 27 2007
    NC
    Yup and i'm still on my 2nd cam follower..... I just changed it due to installing all new BT hardware, otherwise the 2nd follower is still looking good... It has the black finish worn off but there was really no major wear on it.... The test now will be to see how long the new follower lasts on the APR HPFP.
    vizi
    Mar 16 2009
    Anchorage, AK
    Hey man I am going to throw this around on a few forums if that is cool? Bobistheoilguy mainly, pretty big thread on deposits.
    I am hoping mine is similar, I have a 05.5 as well, but only with 38k :). What is your build date (if you know if course lol). I do not drive on short commutes, about 15 miles each way to work on a highway. Not a lot of stop and go at all. BUT I am sure what is going to kill me, is that in the winter I have to let my car warm up before driving. I live in Alaska, and I am sorry, no way in hell I can sit in a car that has been sitting out side @ -15+.
    Jan 27 2007
    NC
    Quote Originally Posted by Tusin View Post
    Yeah, Thats no problem throw it around...... I also let my car warm up a bit in the winter..... At the least I let the rpms settle back down before driving it mostly for the oil to circulate(sp?) but also to warm up in the winter.... The build date i'll have to check on....
    vizi
    Veteran Member Three Rings illegitimus's Avatar
    Mar 17 2009
    2006 B7 A4 Quattro Tip S-line
    Boston, MA
    build date is on your manufacturer sticker which is found on a driver's side door jamb. if the sticker is stripped for any reason you can check the seat belt plastic plate. normally, you'll find the build date on there. At most, the date on the seat belt will be a month earlier.
    Feb 12 2006
    09 A4 Avant, 07 A4 Avant, 98 Jetta TDI
    Charlotte, NC
    can you remove the air guide and get a cleaner pic? look good but you can't really see the stem or the backside of the valve...it just slides right out.
    oh yeah and next time clean around the intake manifold before removing it...
    2009 A4 Avant prestige sport, 2007 A4 Avant 2.0T sport, 2001 S4 Avant 6-speed, couple B5 Passat wagons
    Jan 27 2007
    NC
    Quote Originally Posted by aarononymous View Post
    I would but its all been put back together......I can assure you though that what you see on the front of the valve is the same on the rest of it...... yea I know I should have cleaned the debris off the head.. Had to break the shop-vac out to clean all the crap....
    vizi
    Veteran Member Three Rings WayzataAudi's Avatar
    Feb 18 2009
    911SC Targa
    Colorado
    vizi
    Samsies! haha but seriously i havent really had any problems besides that...i consider myself lucky, and i reallllly hope my valves look like that too X)
    I <3 Whatever
    Jan 27 2007
    NC
    You should see the slack i'm gettin on the tex site now.. There are a few of nay sayers questioning the cleanliness of my valves.....lol
    vizi
    Mar 16 2009
    Anchorage, AK
    Curious. So how do you clean the valves? I assume you have to take them out?
    Jan 27 2007
    NC
    From what i've read you can use somthing called GM valve cleaner and a pick of some sort to scrape the carbon off the valves while they are still in the car.. There is more to it but that is the basic idea that i've seen.
    vizi
    Jan 27 2007
    NC
    Ok can someone with better knowledge tell me if this is possible without noticing any ill performance effects?? This was quoted from the vortex site...
    Quote, originally posted by Issam Abed »
    Hate to say this but maybe a failed valve or similar.
    I will grab some images of some of the heads we have here to show a comparison. I mean I am in no way doubting you at all,I just find those valves VERY clean so excuse me if I am a bit curious.
    vizi
    Mar 16 2009
    Anchorage, AK
    I would think you would know if a valve failed. I mean our computers are pretty damn advanced. If everything is working the way it should with no codes, and if you have done logs with a vag-com and those all report normal, well then your car is running like it should.
    Jan 27 2007
    NC
    Thats what I thought..
    vizi
    Mar 16 2009
    Anchorage, AK
    And how messed up is it. That when something looks right on these engines, people think there is something wrong.... hahah wild.
