Results 1 to 8 of 8
    Established Member Two Rings Mixta's Avatar
    Mar 18 2010
    '97 Caddy Cat
    Atown, PNW
    Widest tire on a B5 S4? (18's)
    Hello, what is the widest tire i can run on a S4 with stock brakes with a 18in wheel on a 37 et offset? 034 said if i had 17s i could go all the way to 255 but what about 18's
    Veteran Member Four Rings L0U's Avatar
    Sep 03 2009
    18 R8 RWS, 20 RS3, 21 RS6, 04 Ducati SS1000DS
    the width has nothing to do with the height. So 255 will fit in 18s as well. The width of the rim can be limiting though. et37, but how wide is this rim?
    2021 Suzuka RS6
    2020 Nardo RS3
    2018 Ibis R8 RWS
    Deactivated Four Rings
    Oct 06 2006
    South Bend, IN
    we don't recommend anything bigger than 245/35-18, but there are plenty of guys that have run the 255 with a fender lip roll.....
    Mar 18 2010
    '97 Caddy Cat
    Atown, PNW
    Quote Originally Posted by L0U View Post
    Thanks for the replies guys, the wheel is a BBS VZ 18x8 with a 37 et
    Veteran Member Four Rings JEmm's Avatar
    Apr 27 2009
    Quote Originally Posted by Mixta View Post
    I don't know if you'd really want to put a 255 on an 8" wide wheel. Might look bloated.
    -Jeff
    Mar 18 2010
    '97 Caddy Cat
    Atown, PNW
    Quote Originally Posted by JEmm View Post
    Very true i guess i just got quickly obsessed with the idea of wide meats, plus with AWD how much of a contact patch is really needed...
    Apr 27 2009
    Well, I'm all for that wide, meaty stance look and unless it's a track rat I don't know if it's gonna hurt, but with that narrow of a wheel it just won't look right or do you any good performance wise.
    Didn't see this before, that's really just not true. I know this is extreme but, I'm sure I could fit a wider tire in a 16 than in a 19... I'm not sure exactly what your getting at but as the wheel gets closer to the fender it's not gonna fit in as wide of a tire as it would with a smaller (diameter) wheel. I'm sure at some point it's going to hit control arms so your screwed regardless but I feel like a 255/40/16 would fit easier than a 255/40/18. I'm sure it's still doable with maybe a spacer and a roll/pull but not as easy as a 16 or 17.
    -Jeff
    Oct 27 2006
    Neptune Beach, FL
    The design of the rear spindle on the B5 models reduces the possible width of the tire as the tire increases in height....i.e. a wider tire could be used with a 16 than with an 18.
    01 AR 6MT Stage 3
    2 x 01 Audi S4 stock
    98 A4 2.8QM stripped for Lemons Race
    97 A4 1.8TQM w/ Garrett t3t04e-50, on to better places
