Results 1 to 9 of 9
    Jun 08 2004
    96 Nissan 240SX
    Montreal
    Quick question about a part
    Guys I posted a thread about this once but it was last year so I'm going to repost I can't find my thread anymore.
    My car has a strange problem I am doing MUCH less Kilometers on my car per tank.
    I used to be able to do between 550 and 600 km per tank now I'm lucky if I reach 350-400
    I changed my timing belt and that is when it started to happen.
    My digital gauge that reads how many kilometers I have left seems to be out of whack though it randomly jumps from say 280 km left on normal driving (60km an hour) to say 340 going lets say 20km or 30km more.
    I THINK one of my sensors is broken but I'm not sure which one can it be the oxygen sensor??
    I also noticed that when the mechanic started my car after the timing belt was put I got a warning that said cylinder 5 misfire. He reset the CEL, I checked a couple of times with my vagcom and I brought it to someone who as a better one than I do and they told me that there is nothing wrong with my cylinder 5.
    So I'm thinking it's some kind of sensor?? Has anyone ever had this problem? Has anyone ever fixed this?
    I was thinking about replacing the O2 sensor and I checked ECS but they have these models
    FRONT PISTON
    Oxygen Sensor - Front Position
    Fits left & right sides
    Brand: Genuine Volkswagen Audi - Corporate Logo
    ES#:1853398
    Mfg#: 1K0998262AB
    170.50
    REAR PISTON
    Oxygen Sensor
    Left rear position, behind catalyst
    Brand: Bosch - Corporate Logo
    ES#:2612
    Mfg#: 078906265F
    130.45
    Oxygen Sensor
    Right rear position, behind catalyst
    ES#:2613
    Mfg#: 078906265G
    110.39
    UNIVERSAL
    Universal 4-Wire Oxygen Sensor
    Four wire universal OBDII Oxygen sensor
    ES#:4566
    Mfg#: 15738
    94.95
    Im not sure which one to buy (if I even need that part to begin with)
    I have a C5 1999 A6 Quattro 2.8L
    170KM
    Timing belt was changed not even 2k ago
    changed the water pump also at the same time.
    Established Member Two Rings SPRX's Avatar
    Aug 11 2009
    A6 2.8 30v quattro AVANT
    Ireland
    If it was oxygen sensor, it would show up in vag-com, and you would have check engine light... All I can recommend is to check timing again, it could be off for few degrees after changing timing belt
    Jun 08 2004
    96 Nissan 240SX
    Montreal
    wouldnt i feel it if the timing belt was misaligned?
    Aug 11 2009
    Ireland
    Don't you feel difference in consumption? ;) If it started after TB job, I would strart from there...
    Jun 08 2004
    96 Nissan 240SX
    Montreal
    Do they have any special tools to see if the timing belt is off or do they have to take everything apart again and see if it is off by eye?
    Basically I just want to know if I have to be prepared to dish out money for this because if it is the timing belt it is obviously the garages fault and they will fix it for me for free. I'm going to complain until they do, but if I bring it somewhere else would they be able to just plug it to a machine and see if the timing belt is off?
    Aug 11 2009
    Ireland
    Not sure about the machine... Mabe the old stule strobe will do the trick, connected to hall sender??? But all they have to do is to take valve covers off and check TDC positions and cam's angles
    Jun 08 2004
    96 Nissan 240SX
    Montreal
    Is this something long? It's not something I would be able to do myself is it?
    Jun 08 2004
    96 Nissan 240SX
    Montreal
    Ok so I plugged my Max Scan to my car yesterday and did the OBDII link to my car.
    I get these messages.
    Power supply terminal 30: voltage too low: p1602 static no define
    16537-163 kwp1281 oxygen (lambda) sensor b2s2: response too slow: p0153
    00526-027 kwp1281 brake light switch-F static- , implausible signal
    P0153 Iso9141 02 sensor ckt Slow response (bank 2 sensor 1)
    My question is can it be that my O2 sensor is giving me this message as a result of another problem OR is it really my O2 sensor that is busted? (I don't get any CEL on my car but my Max Scan gives me this message)
    I was told that sensor one on any bank is the sensor that calculated the richness of the gas and if it incorrectly calculates it I will almost certainly consume more gas than normal.
    Anyone know what these messages mean?
    Jun 08 2004
    96 Nissan 240SX
    Montreal
    These are the pictures of what I get when I plug my max scan in my car.
    sorry for the big pictures
