Results 1 to 2 of 2
    Veteran Member Three Rings Coors's Avatar
    Aug 21 2008
    04 A4 USP 6MT
    Philly
    Clutch Pedal goes Pop
    Posted in A6 section but got no action...
    I push down the clutch and feel through my foot something, what I would describe as a popping sensation.
    If I listen carefully I can hear it pop right at the point of disengagement (i.e. pushing clutch pedal down).
    The clutch behaves normally otherwise. And the popping sensation/sound goes away after driving car for a little while.
    Any clue what would cause this?
    Fluid level is normal. It's a relatively new RS4 clutch and PP, installed roughly 4kmiles ago.
    Slave, SAC out of wack? What else is in there that could cause this?
    The greatest trick the Devil ever pulled was convincing the world he didn't exist, then poof he is gone.
    __________________________________________________ ________________________________
    GIAC BI File/TT 225 Injectors/034 HFC/Forge007/ER FMIC/JHM Short Throw/B5 S4 Motor Mounts/podi/AFE Dry/...
    [Sold] '01.5 6MT C5 A6/RS4'd/GIAC Stage 3 Minus w/ alot of mods
    Dec 06 2007
    Calgary, AB, Canada
    Could be a TO bearing that isn't working quite right, a slave cylinder that is binding a bit, possibly even a broken tooth on the PP. It's really hard to diagnose these things over the interweb...
